Question about Muratec F320 Plain Paper LED Fax
Switching to paper tray 2
Our Muratec fax F-320 doesn't twitch automatically to tray two when tray one is empty. We can't find how to switch.
    Genius:
  • 1,218 Answers
The machine will only switch to tray 2 IF BOTH TRAYS are set to the same paper size "OR" if the paper sizes are different, the machine will switch to the lower (14") tray when it recieves a document which is 14" long.
You may have the same paper in both trays.... but do you have them both programmed for the same size??? When you select the top and then the bottom tray are they saying they are the same size.????
Posted on Jun 07, 2010
Configure HP 4050 printer to prompt 'load paper'
You'll have to change the paper TYPE of tray 3 to a different type as in tray 2.
Jul 28, 2010 | HP LaserJet 4050 Printer
Hello our Muratec F-320 will print faxes with a
lIFT THE BLACK PLASTIC COVER ON TOP OF THE TONER AND DRUM CARTRIDGES. UNDERNEATH THE COVER CLEAN THE ROW OF "EYES" RUNNING FRONT TO BACK. SHOULD FIX IT...PROBABLY HAVE SOME TONER ON THE GLASS EYES.
Jun 24, 2010 | Muratec F-300 Fax
Muratec f320 states: fax ready please call service it continues to send faxes but is not receiving
F-320 "Please call Service".....Press PROGRAM,*,6.....Press PROGRAM to select "Service Call"....error message will now be displayed.
Most common is #02 (Heater Error) which means you have a defective fuser.
Press PROGRAM to show any other error messages.
Press "STOP" TO EXIT.
May 14, 2010 | Muratec F320 Plain Paper LED Fax
How do I have printer switch from empty paper tray 1 to the full 550 paper tray 2
Make sure the paper type and size in both trays are the same. If you are using letter size for both trays, make sure the settings in tray 1 and 2 are the same. If the settings are the same and it still fails to grab from the full tray change the engine settings in diag mode. Hope this helps but if you need more assistance, leave a comment and I'll get back to it. Thanks.
May 10, 2010 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
Hi. You need to do tray linking. When one linked tray is empty, paper feeds from the next linked tray. The size and type settings for all trays must be set from the Paper Menu. To set the paper type or size:
1. On the home screen, touch Menu button
2. Touch Paper Menu
3. Touch Paper Size/Type.
Note: To link the multipurpose feeder, Configure MP must be set to Cassette in order for MP Feeder Size or MP
Feeder Type to appear as a menu item.
4. Touch the right or left arrows to select the same size paper from all paper sources to be linked.
5. Touch the right or left arrows to select the same type paper from all paper sources to be linked.
Note: When the Size and Type settings are the same for any trays, the trays are automatically linked.
6. Touch Submit.
Submitting changes appears.
7. Touch Home to return to the home screen.
Hope this helps.
Mar 16, 2010 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
Need to forward faxes to another fax machine
Fax forwarding is not a feature of the F-320.
Mar 24, 2009 | Muratec F320 Plain Paper LED Fax
Printer Trays
I have the same problem. Tray 2 shows "!" and doesn not print. PLEASE HELP!
Jul 02, 2008 | Lexmark T632 Laser Printer
Muratex F98 Optional Paper Tray
THE PROB WITH THE PAPER TRY WOULD HAVETO BE FIXED FIRST...YOUR ONLY OTHER OPTION IS TO REMOVE THE 2nd 500 SHEET TRAY COMPLETLY AND ONLY WORK WITH THE 150 SHEET TRAY.
Jan 23, 2008 | Muratec F98 Plain Paper Laser Fax
Paper Feed Not Automatically Switching to Multi-Purpose Tray
Sounds like the paper out sensor for the cassette is either broken or jammed. Pull out the cassette tip the machine on its back and you should see a black arm hanging down. This should be able to swing back and fourth freely. Unless it is missing or broken.
Jun 08, 2007 | Canon LaserClass 2050 Plain Paper Fax
Muratec F320 Plain Paper LED Fax Logo
113 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
Ben
Ben
Adorjani Laszlo
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
