Question about Refrigerators
Where can i buy a small chest freezer to work properly in an outside brick shed
    Guru:
  • 1,524 Answers
Any freezer will work with the addition of a "garage thermostat". This comes with a heater attached.
Posted on Apr 24, 2009
Where are the cooling lines for a frigidaire chest freezer model#GLFC2027FW6?
they run around the entire perimeter... Just put something heavy on the top of it.
Aug 09, 2014 | Frigidaire 13 cu. ft. / 368 liter Chest...
Hi we have recently moved to a house an we have inherited a fairly new whirlpool chest freezer which works very well but there is a lot of condensation on the outside which results in small pools of water...
The insulation between the inside and the outside of the freezer haas become water logged, This can be twmporarilly remedied by switching off the freezer and letting the insulation dry out for a few weeks, less in hot dry climates, but the solution is temporary and the problem will reoccur. To have the foam replaced means a complete strip down of the freezer and is seldom worth the cost. I am sorry, but you will probably have to get used to living with the problem. Incidently, it does make inroads into your electricity bills.
Jan 16, 2011 | Whirlpool 21.6 cu. ft. / 612 liter Chest...
Whirlpool Chest freezer problem, Wet all over on the outside, kept in a shed outside could this be the problem. The freezer works fine, but is constantly dripping, and there is still frost inside, where is...
Sorry to read about your problem, I hope this helps you out.
yes.. condensation issue
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Whirlpool 21.6 cu. ft. / 612 liter Chest...
I need to store a upright freezer outside
Good day,
Due to the fact the tubing is embedded in the walls and made of steel, which can deteriorate over time, it should be left running.
Poor second choice is a very dry, warm environment.
Feb 27, 2010 | Magic Chef 7 cu. ft. / 198 liter Chest...
I have a chest freezer that i want to place outside but need to l
fridge/freezers are designed to operate at plus 10c to 35c .a shed will just about do but will not work at its best.have you thought about a " lean to " to store your freezer in.do NOT drill hole in freezer walls.
Feb 21, 2010 | Freezers
Chest Freezer not freezing
check the temp dial. and set to a lower temp. *be mindful of the surrounding temp of the freezer. it will not work properly if it is in 125 degree surrounding air. * check the coils on the freezer and make sure that they are clean. this allows for proper heat transfer from the inside of the box to the outside air. also check to see if the blower is running. * Check to see if there are signs of oil around the freezer, if so contact a service tech
Nov 14, 2009 | Freezers
My chest freezer shut off (the outside light was
Try to plug somthing that you know it works ,in that outlet ,and if it doesn't work or goes on and off , the problem is in the outlet, but if works without trouble ,the problem could be in the freezer plug , the cord or the cord conections to the freezer.
Sep 13, 2009 | Kenmore Freezer 8.8 cu. ft. Chest Freezer...
Outside of chest freezer gets hot
it is normal for outside to get hot. that is where the condensor coils are located. if unit is working don't worry.
Jul 26, 2009 | GE Freezers
FREEZER NOT FREEZING CONTENTS
I have a similar problem with danby and have been unable to get help - I now HATE Danby Chest Freezers
Mar 10, 2009 | Danby 5.5 cu. ft. / 156 liter Chest...
Rust On Bottom Of Chest Freezer
id sand it paint it with white rustolm and go from there and no it couldn't there is a layer of foam between the bottom of the outside and in side
Feb 11, 2008 | Freezers
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
