Question about Sharp 27H-S200 TV
Sharp TV Can not turn TV on: We had a power black out, the power came back on in the middle of the night, and the TV was turned off at the unit (ie not with the remote). Since then we have not been able to turn the TV back on, the remote can't turn it on, and pressing the power on and off at the unit (and pressing the program button) won't turn it on. What can we do? Any suggestions gratefully received. Cheers, Andy.
  • miffanway Sep 17, 2007
    Thank you Paul. I think I may have confused the issue. When the power came back on the TV was working (broadcasting static really loudly) and we couldn't find the remote, that's why it was turned off at the unit. We had been told that we may have trouble turning the TV back on if we turned it off at the unit.
    Cheers,
    Miff.
    Thanks Paul, I shall give it a go.
    Cheers,
    Miff.
  • 3 Answers
It could be a blown fuse, sometimes when power is restored a power spike occurs this can blow fuses in appliances. Check power to either side of main fuse. Then progressivly check all other minor fuses Cheers Paul
Posted on Sep 17, 2007
  • boysie Sep 17, 2007
    Some TV's have a protection circuit on them in case of power outage etc. This could have been activated, If so generally if you unplug the unit and wait 15 to 30 mins this circuit resets itself. If this does not happen then the circuit may be faulty causing no power to the unit
    hope that helps
    cheers paul
SOURCE:
Need help with Sharp TV that wont turn on. Model LC-65LE645U
Have you taken the back off and tested the fuse on the power board?
Feb 07, 2018 | Sharp Televison & Video
No picture, has sound. Black screen with green lines.
Probably a power supply issue in a 7-year-old TV
Feb 13, 2014 | Sharp LC Televison & Video
TV turns on in the middle of the night
  1. If the TV has a timer option, ensure it is disabled.
  2. Check the remote control to see if any of the buttons are stuck that may be interfering with the TV.
  3. Unplug the power cord of the TV from the AC wall outlet for 60 seconds.
  4. Plug the power cord back into the AC outlet.
  5. Attempt to turn on the TV.
  6. Remove all remote controls from the room where the TV is located.
OR
unplug all HDMI sources to see if a device is sending signals in the middle of the night
Oct 03, 2012 | Toymax Magnavox 37MF231D 37 in. LCD TV
Sharp standard tv turns off by itself. have to
if you know how to solder,resolder the vertical section of your tv especialy the IC.i think it is TDA 3657 it is an IC with 7 to 9 legs
Jul 29, 2009 | Televison & Video
Sony Trinitron turns on in the middle of the night for no reason
maybe the people next door have a powerful remote, and when they turn their tv off a night it turns yours on?
Dec 11, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Black square
If the picture can be seen on the sides of the black square you need to go to the menu and find the text and turn it off
Usually in the closed caption section
Mar 12, 2008 | JVC AV-27230 27" TV
Blinking power light.
i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
did you find a solution?
Mar 06, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Screen turns black after 5-10 minutes
check the power options in os from control panel whether the option "turn off the monitor" is in "after 5 mins" if so make it never....
if not check in bios power and frequency control properties...
Feb 06, 2008 | Sharp ll-m17w1u 17" Flat Panel LCD Monitor
JVC 48" rear projection AV48WP30 is HAUNTED
Dear Losing Sleep, The symptoms you're describing sounds like a bad tac switch or two. You might notice a bit of a pattern also, consistent with temp changes. (ie: up in the early AM when house got cooler, and bingo set is on). It's not an expensive repair. Tac switches are an item under a buck a piece. However, this is NOT something you want to tackle yourself... This TV is actually built to self destruct if a less than educated tech opens the back. If you remove the rear cover while the power is on you will destroy all DVI programing inside the DVI (Digital Input Module). The only way to restore the programming is to send the unit to JVC. There is a light sensor inside the TV and when the back is removed with the power on the data is erased from the eprom. You might even take it an extra mile when calling around to find a shop to work on it by asking if they know the correct procedure for opening the back of your TV - - If they do know their answer will be something like this: First turn off set and remove power cord then short pins 1 and 2 on the SB connector of digital input module. Before replacing the rear panel remember to remove the short on the SB connector. Do not turn power on until the rear panel is inserted into the cabinet. If you have to work inside the set with power on remove the two cables going to the DVI module. When you find the right shop take the unit in yourself - you'll save a few bucks that way. Hope this helps. Bill
Jun 19, 2007 | JVC AV-48WP30 48" Rear Projection...
Televison & Video Logo
88 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
