Question about Pioneer GM-5200T Car Audio Amplifier
I was hocking up a other amp to my first one and to wiers toched and the red ligt came on and it makes no noise
  • 4 Answers
Possible not compatable with each other, wrong amount amp, too much power that cause it to disable amp (protection)
Posted on Apr 20, 2009
RED LIGT KEEP BLINKING ON TV
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Sep 18, 2015 | Televison & Video
Amp turns on but no output
1 make sure its hocked up properly .2 see i if the protection comes on.. with out the speaker wires hocked up if it does the u have a bad amp.3 if the amp protection light is off with out the speaker being hocked up and after hocking up the speaker it comes on the u have bad wiring to your speaker or a bad speaker
Jun 14, 2013 | Jl Audio 500/1 Car Audio Amplifier
How many wieres go to the starter on a 1995 lincon town car
the small wire attaches to the small solenoid lug and the two large battery cables in red connect to the one large stud on the solenoid
Aug 23, 2012 | Lincoln Town Car Cars & Trucks
Havin problem with a1200 class a/b amp it ligts green and red at same time after hooking in remote how doi fixdo i need diagram to fix
Make sure you don't have any shorts on your speaker wires or rca cables. Unplug one at a time, the turn on power until it stays green with no protect light, then you know what input is causing the short. If you remove all speaker wires and rca wires and all you have connected is the ground, power(12volts) and remote and it still lights up red/green(in protect mode) then your problem is the amp.
Mar 09, 2010 | Car Audio & Video
My Garmin 765 does not turn-on or light-up on the car or when conected to the PC. The PC is not recognizing it, as usual, as a mass storage unit. Pushing the knob to ligt up the GPS, is useless. The unit...
i have nuvi 715 got the sam prablem i cut batterey conictin plug back with out batterey cut usb cable charger red wier and attatched wire to it to use it as trigger signal then conect push off swetch releas on to red wire off batterey push tow times to get it start
Feb 20, 2010 | Garmin nuvi 765T GPS Receiver
Green and red ligts flash when powerd up also
hello there's a couple of things that could be wrong .the high pitch noise could be the convegance chip shorted out these are 2 big black chips connected to a metal frame called a heatsink the other could be the lamp burn't out
shaun
Oct 21, 2009 | Sony Grand WEGA KF50SX300 50" Television
How do you wier up a bench grinder
I would suggest (just from you saying you dont know wireing that well) you should have someone else do it. But if you are determined white to white black to black(or red) make sure you are grounded and check amp to make sure you have the right breaker. I think you should get someone to help you as electrical fires are #1 on home fires .
I hope I helped
Oct 02, 2009 | Clarke Power Products Grinders
The red ligt on with water inside
FROM TROUBLESHOOTING SECTION OF MANUAL:
Humidifier power light is staying red and not turning green Humidifier is working than stops: ? Ensure that water level sensor is assembled properly. ? Clean water float ? Call service center and request replacement water float
Jan 23, 2009 | Crane Frog EE-3191 1 Gallon Humidifier
Power protection......from what?
check youre wiers + and -
Feb 06, 2008 | Car Audio & Video
Pioneer GM-5200T Car Audio Amplifier Logo
53 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
