Question about HP Office Equipment & Supplies
Try to print--scanner failure appears
Copier worked for years, then would print from computer but not from pages, then wont print at all and scanner failure message pops up
  • 371 Answers
I think your printer has been, for some time now, trying to tell you something and the scanner failure message
is the last in a series of messages.
First, the copier and the printer and the scanner worked fine, "for years",
Then, the copier stopped accepting scans, while printing from data sent by your computer.
Then, you received a scanner failure message again, and will not accept data from your computer, and
"won't print at all"
Your printer/scanner/copier/fax has needed service for some time after years of continuous service.
Evaluate now, based on its initial cost and the lesser cost of All In Ones whether you have already
obtained sufficient service to amortize the cost over time, and you may conclude that service is eitherr
cost effective or ineffective at this time.
Posted on Apr 17, 2009
I have a Samsung SCX-5635 multi-function printer/copier/fax & scanner. It worked great with my old IBM desktop computer running XP. However, a few days ago I upgraded to a new HP custom built HP...
Are you sure the driver is set to A4 paper and not Letter Size. Letter size is the default. Letter size being larger than A4 would mean the print would be off the bottom so you wont see it. Could be as simple as that.
Apr 23, 2011 | Samsung SCX-5635FN All-In-One Laser...
Line down the left side of the photocopies
If this only occurs with copies (not with printed jobs), then your problem is most likely dust/dirt on the scanner (not necessarily the glass), or on the optics that feed the image to the scanner. If it's on print jobs also, it could be a simple image drum problem (they wear out over time, and frequently manifest their impending failure with vertical lines appearing down printed/copied pages.
Aug 13, 2009 | Brother MFC-7440N Laser Printer
Scan failure
try scanning from your printer/scanner program on the computer. My scanner will not work stand alone, but does work this way
May 11, 2009 | Office Equipment & Supplies
Hp officejet 5610 Wont scan . Print. Copy
your printer is dead and is uneconomical to repair. sorry
Jan 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Cartridge Aligment Failure
Then printer successfully printed alligment page you must to put this list on scanner glass to confimation and calibration of printing heads and press "Start or OK", without this part of procedure yours printer will be show error message.
Aug 29, 2008 | HP 190 Copier
Scanner Failure
The only thing I can surgest is that you check installed programs I found that the 750 is very fussy about being the only kid on the block. Maybe worth trying a commercial program that says it will remove "junk" from your hard drive
Aug 24, 2008 | HP PSC 750 All-In-One InkJet Printer
Scanner
1. try to print a test page.
2. if test page ok, turn of all of your firewall application, then check if panasonic communication utility is running as seen
on task bar (blue colored icon near at the volume control)
3. if it is running, double click it (PCU). scanner configuration must appear
4. the scanner configuration details about how you receive the document (popup or etc), program to open (you may even use adobe pdf reader), and the display name of your computer that will be seen on scanner directory of the machine.
May 22, 2008 | Panasonic Workio DP-3530 Copier
Dell 810 not printing
Dear chibihamster, It seems that there is some loose connection in your printer. If you have a little knowledge in hardware, please open your printer carefully, check all the connected cable specially the printer head connector. The best way is that disconnect the printer head cable and reconnect it again. Do not do anything in your scanner circuit area, otherwise it will create you more problems. If this doesn't solve your problem, please contact the manufacturer. GOOD LUCK!!
Aug 31, 2007 | Dell 810 All-In-One InkJet Printer
Test page and scanner
Hey satz, Take that test page, and put it into scanner, (Printed area will be on mirror side) then press scan button "Bottom left side of your printer". After stopping the fluctuation of light you will never face that problem. This error appears when you turn out the cartridge from your printer. sanjeev manglamenterprises@hotmail.com
Apr 24, 2007 | HP PSC 1315 All-In-One InkJet Printer
482 people viewed this question
Seeker5211
Seeker5211
