I've got a modern tv, correct cable, all connected up to tv, but no picture of my desktop on tv. Settings are 16 bit, 800X600 rev. Help!
  • 3 Answers
On your remote control there should be a button that says input or some sort of menu. when you select it it will probaly say tv, vcr etc, see if there is an option for pc in the list. if it shows a menu that says antenna, go to the option for the connector you have connected it to on the back of the tv, ie, scart 1, then it should show.
Posted on Apr 18, 2009
At 1440x1200 resolution the monitor (719Sw) visualizes fine, but a window appears saying "input not supported". Does my cpu not support this monitor. Its a P4, 32.99 ghz 504 mb ram machine
Restart the computer
2 While the computer is loading, press "F8" key on the keyboard right before the
computer reads the hard drive or press the "F8" key multiple times in 1 second
interval until the "Windows Advanced Options Menu" appears on the screen
3 Under "Windows Advanced Options Menu", using the arrow key on the
keyboard, select "Enable VGA Mode" then press Enter. Select "Windows 2000
or Windows XP" for your operating system.
4 Wait while the computer is loading and once the computer finishes loading,
5 Right Click anywhere on the blank area on the desktop then click "Properties"
6 Click on "Settings"
7 Click on "Advanced"
8 Click on "Adapter"
9 Click on "List All Modes..."
10 We recommend that for 15" LCD's select 1024x768, True Color (32 Bit) 60
Hz or 1024x768, High Color (16 Bit), 60 Hertz; For 17" & 18" LCD's select
1280x1024, True Color (32 Bit), 60 hertz, or 1280x1024, High Color (16 Bit)
60 Hertz, or
640x480, 256 colors, 60Hertz or 75Hertz
640x480, High Color (16 bit), 60Hertz or 75Hertz
640x480, True Color (32 bit), 60Hertz or 75Hertz
800x600, 256 Colors, 60Hertz or 75Hertz
800x600, High Color (16 bit), 60Hertz or 75Hertz
800x600, True Color (32 bit), 60Hertz or 75Hertz
1024x768, 256 colors, 60Hertz
1024x768, High Color (16 bit), 60Hertz
1024x768, True Color (32 bit), 60Hertz
11 Additional Valid Modes for use only with 17" & 18" LCD Monitor
1280x1024, 256 colors, 60Hertz
1280x1024, High Color (16 bit), 60Hertz
1280x1024, True Color (32 bit), 60Hertz
May 17, 2011 | AOC 917Sw 19" LCD Monitor
Tip
Trying to connect computer to LCD TV and get no signal?
Hi.
If you are trying to connect computer to LCD TV and get no signal, as a first thing do the following:
Double check cable and connection. If possible test different connections. Try using VGA, DVI or AV, depending on availability on computer and TV.
Ensure that Video drivers on computer are properly installed, and that the video adapter is working properly.
If you are using a laptop, ensure that you do not need to use a function button to enable the external display, this is pretty common on laptops.
If you are using a desktop, go to display properties, find the windows where you get the picture of two monitors, and ensure that both monitors are enabled.
On Vista try also using the 'Identify Monitor' button on Top. It is located on same properties panel as the two monitor, the main Display Property windows. From the same window you can also modify display resolution, as explained later.
If still no luck, then it may be a problem of synchronization between TV and computer, in that case try the following.
  1. Turn off TV.
  2. Disconnect TV power cord.
  3. Restart computer.
  4. With Computer already on, plug back and restart TV.
....If that does not work.
On computer, go to display properties.
First try changing computer resolution. The TV max resolution may not be available on computer. In that case try lowering down to the smallest 16:9 resolution available on computer graphic settings (usually LCD TVs are 16:9), and if that does not work, set resolution to 800x600, just to test (picture proportion will be distorted, or you get squared box on a 16:9 TV).
If that does not work, open Display Properties. In Display Properties access Advanced, and then Monitor settings (XP). On Vista choose Personalize in control panel, then Display Settings, and go straight to Monitor Settings, in there again go to Advanced.
Under the advanced monitor settings you will find a tab called monitor, in there you find the monitor frequency. Try setting this to 50Hz, if that does not work try 100 HZ, that is the output frequency of your TV. If you get unsupported frequency, revert value to normal.
on Jan 17, 2010 | Televison & Video
I have an Acer Aspire one and it won't let me change my resolution off of 800x600 I have windows 7 ultimate x64 (32-bit right?) i need help to get my 1024x600 res back.
Generally - you simply need to right-click anywhere on the desktop that does not have an icon present, and select "Screen resolution". Adjust the slider as needed to obtain the desired resolution. If the resolution desired is not available, choose another that is close.
Digging deeper, you might want to investigate the "Advanced settings" to make sure that you've got the correct drivers loaded in the settings for both the "Adapter" and "Monitor" tabs.
Lastly, "Windows Ultimate x64" is the 64 bit version of Windows. The 32-bit version is referred to as "Windows Ultimate x86" If there are both 32-bit and 64-bit drivers available for your Aspire, make sure you get the correct version 32-bit = x86 and 64-bit = x64. The "x86" tag came from the Intel processor line up where the "x" represented the generation (8, 16 and 32 bit CPUs) and the "86" were the last two digits to indicate the instruction set used by the CPU like this:
8086, 80286, 80386, 80486, etc.
The 64 bit CPUs are not x86 family processors, so they do not carry the x86 tag. Please rate this reply if it was helpful to you - good luck!
Jul 02, 2010 | Dell OptiPlex GX260 PC Desktop
I want to hook it up to my computer but i dont know
At the rear or side of the PC there should be either or both of a 15 Pin DIN Plug, HDMI socket. or a Yellow RCA or 4 -7 pin DIN. Now IF these are present then YES you can connect to a TV. Now some TV's have a connector a DB15 MALE, so that the cable from the PC to the TV, is DB15. this plugs in directly, with appropriate DB15 cable. This, however, will ONLY take the VIDEO to the TV, Audio is delivered via the "Audio Out" Jack on PC, and Plugged into the AV Sockets on the TV, with a dual cored coaxial cable, they are Red & White. Some PC's also have a Yellow RCA Connector, OR a 4 -7 Pin DIN Socket, that requires a Special Adapter Cable (That generally came with the unit, and are colored and marked as to output) to use, for Video/Audio Out to TV. This signal is Composite or SVHS Video & Stereo Out. This connects up TO the TV's Composite/SVHS input Jacks and the Red & White Audio IN, RCA Jacks, &/or DIN SVHS socket.
First you need to know if your PC can output to a TV. Then you need to get the adapter & cables that connect the PC to the TV. Then you need the correct TV drivers installed for your video card. When they are all installed, you need to "Enable" that Monitors, the TV's, Desktop. You need to set either a "Cloned" display or "Spanned, Extended Desktop". Go to "Display Settings" Now ensure the TV/Monitor connected has the correct input/output display settings. Adjust the screens resolution via the resoloution "Slider", it is best to start with, 800x600 32 bit color. or even lower. and once working OK, THEN increase to max resolution, your TV can handle, find out from manual. Once it is all connected up. It should all just work great. Now, from then on, &, to get it to work every-time, the process is. Turn everything OFF. Connect the leads between PC & TV, Turn the TV, ON. Then, startup the PC up. It should "Detect" that it has TWO "Monitors" ie: One Monitor & One TV/Monitor, & you should see your desktop appear after a bit. Now you have screen 1 & screens 2. Now, if you are using "Cloned" mode, then whatever is displayed on the Master monitor, will be displayed on the TV. If you used Spanned, mode, in this mode, however, you will have to."Drag" the Video window, over to the TV, and it is though, you have one "Big Desktop". Now IF using Nvidia or ATI then BOTH of those have thier OWN, Control Panel, this, all then can make it all a lot easier to do it. So I would suggest that this method be used. But if you get stuck, or just want to do it by hand, then the the "By Hand" method is the only way.There is a great program called MultiMon, this allows great control over dual displays, and is well worth installing.
Usually you set the resolution to say 800x600 32bit color, also ensure your video format is right USA, NTSC, Europe, PAL. Hertz is up to 100Hz. Usually thought the TV will handle all that.
Mar 01, 2010 | Sony KV-36FS100 36" TV
Try to connect Samsung lcd hdtv using pc cable. I click source, PC and enter but no picture.
You must set it all up first. It seldom "Just works" At the rear or side of the PC there should be either or both of a 15 Pin DIN Plug, HDMI socket. or a Yellow RCA or 4 -7 pin DIN. Now IF these are present then YES you can connect to a TV. Now some TV's have a connector a DB15 MALE, so that the cable from the PC to the TV, is DB15. this plugs in directly, with appropriate DB15 cable. This, however, will ONLY take the VIDEO to the TV, Audio is delivered via the "Audio Out" Jack on PC, and Plugged into the AV Sockets on the TV, with a dual cored coaxial cable, they are Red & White. Some PC's also have a Yellow RCA Connector, OR a 4 -7 Pin DIN Socket, that requires a Special Adapter Cable (That generally came with the unit, and are colored and marked as to output) to use, for Video/Audio Out to TV. This signal is Composite or SVHS Video & Stereo Out. This connects up TO the TV's Composite/SVHS input Jacks and the Red & White Audio IN, RCA Jacks, &/or DIN SVHS socket.
Feb 10, 2010 | Televison & Video
How to connect tv to computer
Feb 10, 2010 | Prima CV2011 TV
I have a philips tv model 47pfl5704d. what cable
IF, your PC indeed supports TV out, then the Cable usually is SVGA or RCA, connectors. The PC must be configured to activate BOTH screens, ie: enable desktop, to be spanned or mirrored, , the Resolution on TV should only generally be set to 800x600. The correct Drivers must be installed. Must connect to TV before ya start PC too.
Jan 26, 2010 | HP Pavilion 505n (DC470A#ABA) PC Desktop
Wont let me connect it says display setting to 16-bit,800x600 resolution or higher
That refers to the PC's display settings. Use the Control Panel to set the display settings as suggested; 800x600 pixils, with 16 bits of color or higher.
Jan 25, 2010 | ION Audio VCR 2 PC USB VHS Video to...
Resolution isn't matching.
On the desktop righ click & go to properties. you will see a tab called settings, on this make the slider to 800x600 & on the drop down menu make it 16 bit.
Jan 05, 2009 | Microsoft LifeCam VX-1000 Webcam
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Computers & Internet Logo
David Payne
David Payne
