Question about Philips DVP5990 DVD Player
Dont work after upgrade
I have a new DVP5990 when I try to instal upgrade (34) I lose elektricity and the dvd player turned of. So now I can turn this player on it look like the player is dead.
Can anybody help me to wake up my new dvd player
    President:
  • 814 Answers
This is a problem with the command and control software. You will need to contact Phillips customer support at this telephone number. 1-888-744-5477. Tell them that you have tried to upgrade the software and now the unit fails to respond to any function and turns itself off. I hope this information helps you with your problem.
Posted on Jun 02, 2009
Colour distortion
Try a new video cable assembly..
Sounds like the other colors arent getting thru from the DVD player
Apr 20, 2010 | Philips DVP5990 DVD Player
Tip
How to up grade the software in the Phillips dvd players DVP5990 & DVP5992
Installing the latest software
Philips provides software upgrades to
make sure that this unit is compatible
with the newest formats. To check the
updates, compare the current software
version of this unit with the latest
software version available at the Philips
website.
A Press ç to open the disc tray.
B Press numeric keypad ‘55’ on the
remote control.
C Write down the file name.
D Go to www.philips.com/support to check
the latest software version available for
this unit.
E If the latest software version is higher
than the software version of this unit,
download it and store onto a CD-R.
F Load the CD-R to this unit for upgrade
operation.
Note:
Never unplug or turn off this unit
during the upgrade.
G Once complete, this unit will restart automatically
on Jun 02, 2009 | Philips DVP5990 DVD Player
Cannot see the screen Philips DVP5990 DVD player. Setting problem
You may have probably turned on Closed Caption on your TV. Unhook the DVD player to find out if it disappears. If it disappears then Closed Caption is on on your TV. Turn off Closed Caption. If cannot find how, give me the brand and model of your TV.
Oct 30, 2009 | Philips DVP5990 DVD Player
I installed a parental control code on my phillips dvp5990 dvd player and forgot the code.how do you reset it?
This information was found on the Phillips USA website http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=DVD_HOME_THEATER_CA&sct=DVD_PLAYERS_SU&session=200906 in the customer support section for you model dvd player. In the owners manual on page (47). I hope this information helps you with your problem. Select this to set the password for Parental control and Disc
Lock. The default password is ‘136900’.
To change the password:
1) Press OK twice to access the change password menu.
Old Password
New Password
Confirm PWD
OK
2) Use the numeric keypad 0-9 on the remote control to
enter your existing six-digit password at { Old Password }.
Note: When doing this for the first time or if you forget your
existing password, enter ‘136900’.
3) Enter the new six-digit password at { New Password }.
4) Enter the new six-digit password again at { Confirm PWD }.
5) Press OK to confirm and exit
May 07, 2009 | Philips DVP5990 DVD Player
Distorted color on hdmi output
If you haven't already stumbled across the fix: I just had the exact same problem after about eights months of casual use. Unplugging the DVD player for about 15 minutes and then plugging it back in "solved" the problem. Until next time it happens, anyway.
Apr 17, 2009 | Philips DVP5990 DVD Player
Background color is orange instead of blue, color is messed up
Usually this problem is a simple one to find out.Are you wires working correctly.If they are not,open up the box and,if you are a professional so I dont get sued for some accident,try to splice the wires back.If your not a pro take it to the retailer and have it fixed.If it is not the wires,I would check your color settings option in the DVD options menu.Check your red blue green balance and make sure they are correct.
Mar 24, 2009 | Philips DVP5990 DVD Player
PHILIPS DVP5990 -region free problem
In order to have access to the Preference screen, you need to have the CD tray closed with NO DVD/CD in it. If you have a CD or DVD loaded in the tray, the Preference menu is disabled.
Unlock procedure..
press Setup
select the Preference Tab
Press 1,3,8,9,3,1
Press up/down key to select "0"
and hit menu to exit.
Enjoy..
Jan 02, 2009 | Philips DVP5990 DVD Player
How to make DVP5990/37 Region Free
First I recommend that you upgrade the factory firmware to the latest version. The current version is .31 and available here. Click "I accept" to accept the license agreement and start the download. Open the zip file and burn the file named DVP5990_37.bin to a CD. Put the CD in the DVD player and it will begin the upgrade and open the DVD tray. Remove the CD but leave the DVD tray in the open position. After just under 10 minutes (6-8) the DVD player will report that the update was successful and close the DVD tray. Press the setup button, go to preferences scroll down the choices (past the bottom of the screen) and select reset to default values. The player will reboot.
Next press Setup
select the Preference menu
Press 1,3,8,9,3,1 on the remote control.
Use the up/down arrows to select region "0" which means all regions.
If you ever get a disc that won't play correctly due to a region error, just use the code above to select the correct region for the disc and you will still be able to play it.
Nov 02, 2008 | Philips DVP5990 DVD Player
Philips DVP5990 DVD Player Logo
170 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
