Question about Kyocera Office Equipment & Supplies
Difference between ''Auot Color'' and ''Full Color Mode
We want to know what the difference is between the two color settings on our copier.
Thank you
Patricia
  • 469 Answers
Most Colour machines have three settings.
Auto Colour, Machine will determine if the original is Colour or Black and White from its scan. Then print in the format that best suits the original.
Full Colour, Machine will copy in full Colour regardless of Original type.
Black and White, Machine will copy or scan in B & W regardless of original type.
Hope this is of some help.
Ed
Posted on Apr 17, 2009
What is the solution for e 001 problem
If its a Canon
#001
> Cause 1
Different sized originals were scanned without setting the Different Size Originals mode.
Remedy
Set the Different Size Originals mode, and then try scanning again.
Cause 2
Different sized originals were scanned in the 2-Sided Original without setting the Different Size Originals mode.
Remedy
May 11, 2015 | Office Equipment & Supplies
Have an HP laserjet cp2025 - the printing comes out faded although the test page prints fine. What's happening?
sounds like you either have econo-mode set which would be in the printer driver or your screen colors do not match your printer colors. Your easiest test is to open mspaint and create a block of just one basic color like yellow. If it prints fine then the programs you are trying to use are not sending the right color instructions to the printer. Never expect a low end color such as this to match your screen out of the box, it will not happen. You either have to accept the color difference or spend the money to buy a color matching device which creates custom drivers for your printer and screen so they look the same.
Mar 21, 2011 | HP Office Equipment & Supplies
How to print black and white only on Konica-Minolta 2400W
Are using OEM cartridges? What about the transfer belt and transfer roller have they been replaced>
Dec 26, 2009 | Konica Color Stationary Workgroup Laser...
Color printer full will only print black in my
You would nee to check you printing setting it migh be set to print only in gray mode
Sep 23, 2009 | Office Equipment & Supplies
Uneven color lines
That is because it is printing the document as text. Not have=ing used a canon I presume it is the same as epson & HP. Instead of clicking the print icon click file print. A box should open allowing you to change the properties, seleect photo
Sep 18, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Poor print quality .... Canon Pixma MP140 ...
Paper quality does make a difference in the quality of print, but it's usually in the areas of blurriness and vibrance. If your prints are coming out faded, the quality for your prints might be set to 'economy', which doesn't use very much ink. If you have it set for 'quality' prints, I would try replacing the ink cartridges.
May 08, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Magenta backgrounding
If the magenta is low the waste bin may be full and that may be causing the problem. If this is the case you need to change the toner. You can try calibrating the printer. You may have to do this 3 times in a row for it to make a difference.
Press Select-check mark button
Use arrows to go to Print Quality
Use arrows to go to Calibrate Color
Use arrows to go to Calibrate Now
Press Select to Confirm Calibrate Now
Jul 31, 2008 | HP Color LaserJet 2600n Printer
Color printing from Windows XP Photoprinting Wizard
Just dirrerent intrepertations by the driver.
Often times "auto" settings are not the best to use.
You can default it to the best management solution for your computer/printer matchup.
Sounds like a weasly answer I know, but it is amazing how much different those will operate one system to another.
Another suggestion, color normally prints better with a PS, Post Script, driver then a PCL , driver. You may want to go ont the website for your printer and see if there is more then one driver, and switch drivers to see what happens.
Subtle differences in drivers can make a difference how printers print also.
Most of the times it's finding where your printer works best.
It is not necessarly a problem if one setting works better for you over another. Just nuances on different systems.
Please don't take this as a wise comment, but that is why all those adjustments are on drivers and printers, sometimes you just have to modify to get what you really want quality wise.
Hope this helps.
Feb 25, 2008 | HP Photosmart 2610 All-In-One InkJet...
New ink cartridge problem
pleaz change the same original cartridges
Apr 19, 2007 | HP OfficeJet V40xi InkJet Printer
458 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
