Question about Car Audio & Video
Radio reads SAFE won't let me enter a code
I have a 98 vw golf. My battery went dead a while ago and I got a jump... Ever since my radio says "safe." I was reading up on the problem and supposedly the radio should flash "safe" and then move on so you can enter the code. I see other people have had this problem but I haven't seen any solutions other than some idiots saying to just enter the code. The screen is STUCK and you aren't able to enter a code at all. I saw someone say that they let their car run for an hour and the radio eventually moved from safe to enter he code. Well, I let my car run for an hour and a half. It hasn't changed from saying safe. If anyone knows how to solve this Please let me know! I would really like some music!
  • Anonymous May 24, 2009
    i hve a vw velocity 1.4i and the radio is on safe mode. I try to enter the code but the radio does not respond. pliz if anyone can help.
  • 47 Answers
Normally you do have to leave your car running sometimes 10 mins sometimes couple hours,
I had same problem with my one and i must have been driving around for days like it and one day it just decided to work
You may find that if you disconnect the battery for couple mins then put it all back together it will work
If not matey then you probley have a faulty headunit
so this is what i suggest to do
Number 1
Disconnect Battery for say 5 mins then connect it all up and see what happens if not you most prob do have a faulty headunit. you can take it to your local car audio shop and they will either repair it or decode it for you
Hope this helps you
Upfront Audio
Please leave feeback and rate thanks :)
Posted on Apr 24, 2009
My vw golf tenacity battery went flat replace now my radio is blocked on safe mode and showes two
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your VW service centre and get them to enter this code for you.
Mar 29, 2013 | Volkswagen Car Audio & Video
My battrey on my vw golf 2001 went dead on monday and then the radio is now not playing and just have safe on the display when i switch it on but it will not play.....how can i de-code it to get it playing...
You will need to enter the code, the code should be in glovebox with the manualy also read on how to enter the code, if you enter code wrong three times it will lock you out. if you dont have the code then remove radio without removing power to it and record serial #, then go to dealer with reg and id and they will give you the code, ive done this alot for customers,
Aug 29, 2010 | 2001 Volkswagen Golf
Jumped started Audi 2001 TT, due to dead battery, now radio dead
You will need to enter the anti theft radio lock code. I would check the manual for the operation. On my VW it was on a sticker in the truck. Also check with an Audi dealer for exact location.
Mar 11, 2010 | 2001 Audi TT
Hi, problem with 2007 VW Citi Golf radio security code.
The radio is in Lock-Out mode. You only get two attempts to enter the code, then it enters Lock-Out mode.
Put the key in ignition and turn on the radio for an hour (maybe a bit more). The radio should reset itself after about an hour and then you can re enter the code.
Jul 08, 2009 | 2007 Volkswagen Golf
My 1997 vw golf radio is in safe mode since i changed the battery. No dealer will help me where do i find the # Im a teenager with out a radio Thats NOT good!!
If its a vw factory radio,all u need is the serial no.found on the radio casing,eg.VWZ4Z3G...... and any vw dealership should supply you with the code.If the radio remains on safe mode,leave the ignition and radio on for 1 hr until you see the no 1000.Enter the code.
Jul 04, 2009 | Volkswagen Golf V Vw Scale Diecast Model
97 VW Golf radio flashes safe
you have to leave radio and ignition on for 1hr till no.1000 appears,then enter code
Jun 19, 2009 | 1997 Volkswagen Golf
Radio reads safe
The radio reads "safe" because you lost power to the radio. Either the battery was replaced, the battery was dead, or one of the terminals was disconnected. You will need to take the serial number from the radio to your local VW dealer where he can call in to obtain the programming code for your radio. The dealers usually do not charge in order for you to obtain the code.
Jun 01, 2009 | 1997 Volkswagen Golf
Re setting the radio on my VW Golf
heres what u do , switch radio on , safe appears in radio display , followed by 1000 approximately 3 seconds later , input the security code found on the radio card using the station preset buttons on the radio , Button 1 corresponds to the first number in the security code , 2 is the second and so on . press the applicable button repeatedly until the desired number appears in the display , ( press button 1 three times if the first number is 3 ), when the entire code has been input and appears on the display , press the right side of the seek button for longer than 2 seconds until an audible signal is heard , ,,, if you do not get this procedure correct , in 2 attempts , the radio will lock up for 1 hour before you can try again .. if this happens , leave the radio on for minimum 1 hour without touching it , after that time you may try again ..
J5
Jan 15, 2009 | 2001 Volkswagen Golf
What is the radio code of VW Golf 1993? Please help me know. T.Y
your main vw dealer will give you the code or a good car radio shop will be able to recode it
Dec 30, 2008 | 1993 Volkswagen Golf
Vw golf .... alpha...... safe 2
"2 safe" means that your radio was in safe mode, and then the code was improperly entered 2 times. you either need to disconnect your battery and leave it for up to 4 hours (i've been told), or leave your key in the ignition for around an hour.
once it comes out of "2 safe" mode, then it will just say SAFE and give you the numbers 1-0-0-0. You just need to enter the 4 digit code (using your pre-set numbers 1-2-3-4 to change the numbers), then hold the seek > button and your radio should come on.
If you don't have the code, call VW. they'll find your code for free. they did for me. if not they'll charge like $50 or something.
Dec 24, 2008 | 1997 Volkswagen Golf
Car Audio & Video Logo
344 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
