Question about AOC LM729 17" LCD Monitor
CRT in CNC machine
Screen is completey dark
  • hammy1972 Jun 25, 2008
    it will turn on for 20 secs then the screen goes dark
Screen goes black
Posted on Jun 25, 2008
  • 883 Answers
Could be a multitude of problems. first, check that the cathode heater is glowing. then check that the getters are still silver (indicates vacuum leak) then test for anode voltage (high voltage probe required). if all of the previous tests pass, you should at least have a dot on screen. if not, then signal is not getting to tube (cathode). test cathode connector (disconnect with power off) with o-scope.
Posted on Sep 17, 2007
  • 2 more comments
  • Marty marty Sep 27, 2007
    any progress on this solution?
  • Marty marty Oct 06, 2007
    hello any progress on this solution? still need help?
What is cnc Macine
CNC stands for Computer numerical control. CNC Machining is a process used in the manufacturing sector that uses computers to control machine tools. These tools can be controlled in the manner of, lathes, mills, routers and grinders.
Jun 19, 2018 | Computers & Internet
Monochrome monitor pcb pinout
can you give some detailed problem of your machine so i can give much better solution.
Nov 10, 2012 | Computers & Internet
Our Lg Plasma 50PC1DRA popped then a very dim picture
If you have the same problem with another input such as a DVD player, this TV might need attention by a qualified service technician.
Aug 05, 2012 | LG 50PC1DRA 50 in. Plasma Television
What is diffrent between lathe machin & cnc machin
A Lathe machine turns a piece to be worked on usually along its longest axis. An operator or machinist manually moves a cutter or other tool against the rotating piece to remove and/or polish the material to a more refined state. Instead of manually, a Lathe can be controlled by computer with the speed of rotation and positioning of the cutter or other tool being done according to a program or set of numeric data in which case the Lathe would then be a CNC machine. A CNC machine can refer to any computer controlled machine which uses a set of numeric data to determine its operation which can be cutting, drilling, milling, etc.
For a more comprehensive description go to Wekipedia for Lathe at http://en.wikipedia.org/wiki/Lathe
and for CNC at http://en.wikipedia.org/wiki/Numerical_control
Jan 31, 2011 | Computers & Internet
How to reset emg alrm on fanuc 10m I just got the machine When i powered it up , screen comes up, fans comes on, but nothing else. I,ve checked power source and air pressure. I've read manual but can...
dear sir
iam from india .my name anand.now am using cnc vmc
machine .control ;fanuc 10m .EMG alarm coming .how
solveing that problem.pls reply me .
thank you.
Dec 05, 2010 | RTO KipwareM® - Conversational CNC...
I have full sound but no picture. the screen is completey dead
JVC av32750 tv works for a while and then picture goes out but sound remains on
Oct 06, 2010 | JVC AV-36D800 36" TV
I want to see how Software programming for cutting of a new watch model on the CNC machine is used
Try YouTube. I've seen some CNC machining there. Also visit Swiss manufacturer original sites.
Jan 12, 2010 | Casio Watches
My HP flat screen (crt) screen is getting dark
If the brightness control is set to maximum and the picture is still too dark, two things might be happening. The CRT picture tube may have deteriorated over time, and/or the high voltage circuitry inside the monitor is failing to deliver enough HV to the tube.
In both cases theoretically it can be fixed (the CRT tube replaced with a new one, and the HV part cleaned of dust residue and repaired), but most probably it would cost not much less than purchasing a modern LCD monitor...
Nov 22, 2009 | HP Computers & Internet
Canon printer MP110
ok clink the above link directly
Nov 16, 2008 | Canon PIXMA MP130 All-In-One InkJet...
AOC LM729 17" LCD Monitor Logo
90 people viewed this question
Top AOC Computers & Internet Experts
Raj Patel
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
