Question about Sony VAIO TT Series VGN-TT180N/B NoteBook Intel Core 2 Duo SU9400 11.1' Wide XGA 4GB Memory
How do you change the Hard Drive for a Sony Vaio vgn-tt180? And where is the oem hard drive located? Thanks, Mo
  • Sony Master
  • 5,660 Answers
Not a recommended thing Mo.
Granted I don't know your computer prowess, but it's an involved task, even for a tech.
First you make a backup of what's on your harddrive now. Burn to disk/s, all of your personal stuff, (If you haven't already done so)
(Everything in your My Documents folder. My Pictures, My Music, My Videos, and documents you have created. You won't be able to transfer downloaded programs, or programs you have installed. Read on for how to do that)
You use an external enclosure, (2.5"), and put the new laptop harddrive in it. Then using a 'mirror' imaging program, like Norton Ghost, Acronis true Image, or DriveImage XML, you make a copy of your operating system, and all programs that are on the harddrive in the Vaio VGN-TT180.
External enclosures are cheap. You want one that is 2.5", and is Sata.
Examples,
Now for the tough part, and the reason I don't recommend it.
With most laptops one removes a couple of screws, and slides the harddrive out of the side of the laptop case. Or remove a panel, and access it. Or, some have it where removal of the keypad grants you access.
Not the Sony Vaio, and especially not the Sony Vaio TT Series.
You have to turn the laptop over on it's top. Remove a series of 7 screws, or so. Six around the outside edge of the case, one in the middle/Front, next to the memory compartment cover. Then the laptop is turned back over, and a small flat tip jewelers screwdriver, is inserted into the slots above the keypad, and the keypad is released, and tilted back. The flat ribbon keypad cable, is then unclipped from the laptop.
There's a small White ribbon cable located towards the speaker grille, that has to be disconnected.
This is what connects the front panel buttons to the motherboard.
Now there's a screw right above the trackpad that has to be removed. (And CAREFULLY! It can easily be dropped inside! To get it back out, you MAY be lucky enough to pick the laptop up, turn it over, and gently shake it out. If you're not lucky, you get to disassemble the whole laptop!)
Next, a flat tip jewelers screwdriver is inserted in the parting line, where the upper half of the case, meets the lower half of the case. Start at the back towards the LCD screen, and ease the top panel up, working your way towards the front. Start on one side. As the top panel comes up a little on this side, go to the other side, and work it up. Bring the top panel up, as even as you can. It's thin, and can twist easily, binding it. The top panel is held on by a series of clips.
Once, you get both sides separated to the point you are at the front, the top panel lifts right off.
Now you can see the harddrive.
To the left side of it are two screws in the corners. These are removed. (DON'T drop them)
To the right, there is a screw in the Front corner. This is removed. The harddrive has a fabric strip attached to it, on the back of the case. You gently pull back, and as the harddrive comes out, you ease the back of it up, and pull straight out. Use extreme caution in this, as the little pins of the harddrive interface, could be bent!
Now you remove tow screws oneach side of the harddrive. This removes the metal frame that goes around it. The new harddrive is installed in this metal frame.
Now just reverse your steps.
Not a job for the timid! lol!
Posted on Apr 18, 2009
  • joecoolvette
    joecoolvette Apr 18, 2009
    Forgot to add examples of 2.5" Sata external enclosures,
    http://www.tigerdirect.com/applications/...|c:2781|&Sort=0&Recs=10
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
Need hard drive for Sony Vaio VGN-FS742/W
If it's an IDE? Newegg has a 320GB. SATA can go much bigger, but Sony linked your model to a IDE hard drive.
http://www.docs.sony.com/release/994630300_Rev_D_NO_PHONE.pdf
Oct 13, 2012 | Sony VAIO VGN-FS742/W Notebook
Replace hard drive on sony VGN-SZ760N laptop
It's not so easy here's a video tutorial...
http://videosift.com/video/Why-I-will-never-buy-a-Sony-laptop-try-to-replace-the-HD?loadcomm=1
If you just need to recover the data use an online data recovery service like http://FreeDataRecovery.us
Sep 07, 2012 | Sony VAIO VGN-SZ750N/C VGN-SZ760N...
How do I replace the hard drive on my sony Vaio VGN-NR120E?
To replace a hard drive, you'll need to backup any data you want to keep, uninstall the old hard drive, install the new hard drive, and then restore the backed up data.
The specific steps necessary to replace a hard drive differ depending on the type of hard drive you're replacing.
Jun 20, 2011 | Sony VAIO VGN-NR120E/S Notebook
Sony vaio vgn series laptop - when xp os loading blue screen appears and display the msg hard disk drive not detected.
system not found in my experience generally leads to a damaged or loose hard drive, try to open the cover at the bottom side of the machine, and reseat the hard drive, if it still says system not found, get a 2.5 inch drive case, put your laptop drive in the case and connect it to another machine, if you can access the drive great! save all your files and once complete return the drive to your machine and try to reinstall the OS from a dvd then reinstall your files.. and if still having the same problem replace hard drive thanks.
Oct 26, 2010 | Sony VAIO VGN-NS135E/S Notebook PC
I am trying to upgrade the hard drive on my sony vaio upgrade harddrive sony VGN-AR630E. I want to install windows xp on it, but it won't see the hard drive. What can I do?
its either the hard disk is bad or the operating system is faulty.try checking local computer fixers in your area.would like to know where youu leave maybe i can help.       thanks
Jul 02, 2009 | Sony VAIO VGN-AR630E Notebook
Get error message "operating system not found"
Run diagnostics on the harddrive. if possible reseat the Hard drive, i.e take it out and put it back again. and then try installing the OS. remember you have to boot from the laptop to install OS. Hope you are doing it correctly
Apr 09, 2009 | Sony VAIO VGN-FJ270/B Notebook
Sony vaio vgn cr200e drive
Western Digital Scorpio WD5000BEVT Mobile Hard Drive - 500GB, 2.5", looks nice. I haven't seen any larger yet.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4322423&CatId=1277
Jan 16, 2009 | Sony VAIO VGN-CR220E/P Notebook
Sony VAIO TT Series VGN-TT180N/B NoteBook Intel Core 2 Duo SU9400 11.1' Wide XGA 4GB Memory Logo
341 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
