Question about Western Digital Caviar SE WD800JD SATA Hard Drive
Wd800jd sata hard drive not recognized in bios on boot up
I have bought my first SATA hard drive and installing it in my computer. I have a SOYO SY-KT600 Dragon Plus mobo. On boot up it does not show the drive has been recognized as well as windows does not recognize the drive. I don't see any place in the bios to change something to make it recognize it. I have the drive connected to the SATA port on the drive with a SATA cable and power is through a "legacy" ATA power plug. It also appears that there is supposed to be a jumper on pins 1 and 2 that is missing on my drive. Looking for help with this issue.
  • 1 more comment
  • Scott Kruger Sep 17, 2007
    I have the SY-KT600 Dragon Plus mobo and first generation serial ATA WD800JD hard drive The board has two SATA ports. Would it be that the bios needs an update to recognize the WD800JD hard drive even though it has SATA ports?
  • Scott Kruger Sep 18, 2007
    I have now flashed the bios and tried putting a jumper on pins one and two on the drive. No luck. Since flashing the bios windows says the raid controller cant be started. I tried uninstalling the raid controller in the device manager and reinstalled it with no luck. I have checked the settings in the bios against those recommended by SOYO and still no change.
  • Anonymous Mar 29, 2014
    shuttle ak38n v1.1 motherboard with ATA 133 channels will not recognize sata hard drive
    Brigadier General:
  • 6,966 Answers
Hi, A couple of ideas: 1. There are 3 versions of this motherboard: Dragon Plus, V1.0 & V2.0, perhaps your BIOS needs an update to be able to recognize the new HD. This of course would require flashing; 2. There are two variations of a WD SATA hard drive: Serial ATA amd Serial ATA II; 3. Re Jumper settings: the eight-pin jumper block is only used to enable power management on the drive. There are no master/slave settings since there is only one drive per cable; 4. If you are fresh installing Windows on it, you need to press F6 when asked by the Windows Installer and follow on-screen instructions. Hope this be of some help/idea. Post back how things turn up or should you need further information.
Posted on Sep 17, 2007
  • 2 more comments
  • Louie  Role
    Louie Role Sep 17, 2007
    Hi again,
    Should be a straight forward autodetect and Windows install.
    Re BIOS, just might work updating/flashing. However before doing so, do you have any SATA options in your CMOS/BIOS? If none, how about RAID? Perhaps you can give that a try.
    As initially posted, when installing Windows, there is an option to press F6 when installing on a drive that is not IDE.
    Cheers.
  • Louie  Role
    Louie Role Sep 18, 2007
    Copy that you have flashed the BIOS and no more access to RAID. Flashback to the old BIOS. Likewise verify that you have the correct model/version.
    I know that this sounds redundant but there is no other alternative but to patiently work this out (or get a newer board which does not sound so appealing).
    Good luck and kind regards.
  • Louie  Role
    P.S.
    After a successful BIOS flash, you have to set the CMOS/BIOS to Default settings initially.
  • Louie  Role
    Louie Role Sep 23, 2007
    Below is a copy of my post re SATA and Win Xp installation.
    ...Typically, Windows XP installer does not provide full support for SATA HDs (drives) nor for all kinds of SATA Controllers (on the motherboard or add-on card).
    However, Windows XP installer provided a way out by prompting the user to press F6 and load the necessary drivers in the FDD. The diskette containing the drivers may either come from: manufacturer of motherboard; manufacturer of controller; or manufacturer of HD.
    If none was provided nor available, then perhaps you can DIY (do-it-yourself). More often than not, it is inside the MB installer/driver CD in D:\Drivers\SATA or something like that and copy to a floppy diskette. Alternately, you can download from the manufacturer's website, decompress and copy to FD.
    When the Windows XP installation CD puts out the message "Press F6 if you need to install a third party SCSI or RAID driver", press "F6" as instructed. Thereafter, press "S" to specify additional device on the next pop up screen. Insert the driver floppy disk in and press enter to continue. If the floppy disk is made
    successfully, the installation program will ask for selecting driver. Please then select "Motherboard chipset (VIA, Intel etc Serial ATA RAID Controller(Windows XP)".) After the SATA driver loaded, Windows XP will now recognize the
    SATA HDD, proceed and continue to install Windows XP.
    If you do not have a FDD, one of your option is to DIY a slipstream WinXP installer CD. This is better explained in this article http://www.maximumpc.com/article/How-To-...>...
WD 1TB sata II has jumper pins that reduce from 3 Gb/s to 1.5 Gb/s.
This fixed my problem with older M/board.
Seagate 1TB sata still isn't recognised and disables RAID.
Posted on Jun 24, 2010
  • 101 Answers
Try the jumper on pins 5&6 for WD drives to 'slow' the data rate.
Posted on Nov 18, 2008
Is it possible to use ID harddisk and SATA harddisk at the same time?
You can indeed mix IDE & SATA drives on a computer. If installing the OS (Operating System) to the IDE HD, you will only need to instruct the BIOS to boot the IDE HD drive first.
If you decide to install an OS on & boot the SATA drive first; you will need to instruct the BIOS to boot the SATA drive first and may need to provide a driver for the SATA controller - if the OS install does not recognize the SATA drive. The driver should have been included on a disk or diskette with the controller (or on the motherboard driver disk if a built-in type controller). You should see a prompt asking "If you need to install a driver.... press F6" (or similar). Press the F6 key and supply the driver disk - and follow the prompts.
Nov 24, 2011 | ASUS K8V-MX Motherboard
I have a WD800JD hard drive which was on my old computer in which I want to recover data to my new computer. I have installed it in the computer with the one ribbon (only one available). The master has...
Hello Joe,
Please visit the link provided below :
http://wdc.custhelp.com/app/answers/detail/a_id/981/p/288,95/c/123/session/L3RpbWUvMTMxMzU4ODkxOS9zaWQvN1JOSzdNQms%3D
Aug 17, 2011 | Western Digital Caviar SE WD800JD SATA...
I bought a Hitachi z5k320 hard drive trying to install it, and windows, but my computer won't recognize hard drive. how can i get it to recognize the new drive. can't do anything until that happens.
As long as you are sure the hard drive is connected properly with SATA cables to the motherboard and has power from the power supply unit, and that the drive is working, you can enter the BIOS on computer startup and modify the "boot device" look in "primary boot device" for a name matching that of your hard drive (probably "HITACHI .....) If it is there select it as the primary device and hopefully it will boot and ask you to install windows. If it is not there the drive may not be connected or it may need to be replaced. Hope this helps!
Mar 15, 2011 | Hitachi 160GB Travelstar Z5K320 SATA 3Gbs...
How to slave a wd800jd caviar se sata hard disk
Just install it. No jumpers are needed on a SATA drive.
Jan 01, 2011 | Western Digital Caviar SE WD800JD SATA...
I bought a Dell Optiplex 745 with no hard drive. I bought a second hand WD800JD SATA hard drive with no CD's and installed it. The computer does not recognize it so I cannot load an OS. Can you help?
make sure that the leads are in there correct slots
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Dec 04, 2010 | Western Digital Caviar SE WD800JD SATA...
Western Digital Caviar SE WD800JD SATA Hard Drive Boot: Couldn't find NTLDR could this be bad drive installed xp a couple times now works ok but when i shut it off Couldn't find NTLDR comes up
Yes it looks like a Hard drive problem.
This error means that NTLDR is missing somehow from your computer,hard disk problem usually or virus.
You can go to that page and follow the instructions exactly as he says and will not have to install windows over and over again
http://www.tinyempire.com/notes/ntldrismissing.htm
Jan 02, 2010 | Western Digital Caviar SE WD800JD SATA...
Doesn't recognize SATA hard drives. BIOS option
Need to install latest bios update go to there website also if you are trying to boot up with usb installed take it out. BIOS ID:15
  1. Fixed the issue where SATA HDD boot up will fail if USB storage device is installed.
  2. Fixed the issue where SATA HDD boot up will fail if "USB keyboard/mouse" setting as "BIOS" section.
  3. Enhance the compatibility of SATA device on WIN98SE/ME.
  4. BIOS compile date: 06/07/2004
Nov 28, 2009 | Abit KV7-V Motherboard
Hard drive crash on dell 2400. Bought new Seagate 500gb hard drive. Installed with sata port to motherboard connected. On BIOS setup enabled sata port to auto, only two selections off/auto. On atempting to...
you will have to install a driver before it picks your sata drive up. when your cd starts to install youll see an option F6 to install sata drivers from a floppy
http://xphelpandsupport.mvps.org/how_do_i_install_windows_xp_on_a.htm
let me know if that guide helps
Aug 11, 2008 | Computers & Internet
Western Digital Caviar SE WD800JD SATA Hard Drive Logo
4,099 people viewed this question
Top Western Digital Computers & Internet Experts
Alun Cox
Marvin
Marvin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
