TV Set goes on to red standby and shuts off over and over again
I have SONY KV34HS420 , the set is out of warranty , the standby red light goes on and it shuts down the set ....Any help or ideas ? I have tried all the basic steps such as unplugging the TV and allowing time for a "default reset" , I have looked at timers on the TV set as well as the cable box with no conflicting issues there. I called the tech from the retail outlet where I purchased the set and he used the remote control of the TV set to get a diagnostic window . After looking at the screen I was told that it would probably cost in the range of $ 400 to fix it. Before I am forced to spend money on a new TV set , I would appreciate any feedback from "experienced" people .If anyone can tell me how to bring up that diagnostic box up again , I might be able to determine the parts needed and maybe I can find a more cost effective resolution to my problem , and in the process I might learn enough to be able to help people with similar problems in the future...Thanking all of you that might be of help to me , let me wish you all a great day !!!!!!
    Top Expert:
  • Televison & ... Master
  • 74,990 Answers
If you wish to get some details; visit the site linked here. Pull up older posts. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Posted on Mar 06, 2017
  • 192 Answers
SOURCE: WD-52525 Shuts off, shows red lamp light even after replacing lamp
Turn on the set and let it shut down. push in the Menu and Device (or input, I don't have a schematic in front of me) buttons on the front of the set at the same time and hold until the green light starts flashing. Then release. There will be two different sets of flashes, such as, 3 and 6. The code 12 means the set is opperating fine. The other codes will tell you what part of the set needs repaired. Also, remove the bulb and check the ballast connection to the bulb. I find the connection for the bulb bent over when a customer replaces the lamp sometimes. Let me know what you find and we can go from there.
Posted on Feb 18, 2007
SOURCE: Red lines on Sony KP51HW40 Rear projection TV
This should be a very simple fix. The lines on your screen are call retrace lines. Basically you need to open the TV and the job is about 15 minutes to solve the issue with arched lines, either blue, greed, or red. There is a great how-to guide here:
Posted on Jul 02, 2007
  • 1153 Answers
SOURCE: mitsubishi wd-62327 red light
1. Self-diagnosis error 4-4, check for open F9A06 part # 283P128050 on the Power PCB. 2. Self-diagnosis error 4-4, check for proper seating of the DVI cable between the FMT PCB and the DMD (Light Engine). It may be necessary to disconnect and reconnect this cable to insure proper connection. 3. Self-diagnosis error 4-4, if F9A06 is good and the connection on the DVI cable between the FMT PCB and DMD are secure, suspect the Light Engine part # 939P977020 4. Self-diagnosis error 4-4, check F9A07 part # 283P128050 on the Power PCB, if open suspect the Light Engine part # 939P977020 5. Self-diagnosis error 4-1, suspect the Power PCB part # 930B929001
Posted on Sep 10, 2007
  • 4402 Answers
SOURCE: Sony KDS55A2000 Red Blinking Light Issue
first off
For the KDS55A2000, 9 blinks, pause, 9 blinks means "Device error" and the probable cause locations listed are as follows:
1. Temperature sensors
2. Bus decoder ICs (IC2000, 3150, 3200, 8804)
These are starting points for qualified service technicians. There is a service bulletin for this issue, but it is intended for use by qualified service technicians.
I found that it refers to a problem in the "zero crossing detector" circuit on the "G" board. I resourced the part from an electronics warehouse and found out that the "G" board has a known weakness and high failure rate The part cost me $73+$47 fedex shipping
The "G" board may be the only "plug n' play" board in the whole set
Posted on Feb 12, 2008
  • 51 Answers
we have repaired 100s of these tv..most have a flicker issuse and it is getting hard to find replacement tubes. the cost sounds right...I suggest to invest in a new tv.
Posted on Sep 09, 2008
Klv 32s200a
There are two things you can try. Press "Sleep" until you see "off" appears. If this doesn't fix the problem, go to the "Eco" settings and set "Power Saving" to "Off", set "Idle TV Standby" to off, and "Auto Shut Off" to "off". I hope this works for you.
Sep 20, 2013 | Televison & Video
My Sony wega tv won't turn on goes into standby red light blinks 10 times then shuts off?
Look at the owner manual as the 10 blinks is a error code or Google the model number to locate that information--Sony error codes are general and often misleading.
I would if looking at the set inspect the lamp first.
Aug 28, 2012 | Sony Grand WEGA KDF-42WE655 42" Rear...
My sony kp-51ws510 color rear video projector tv when i turn it on it stays on for abt five seconds and then turns off and also the timer and standby light is flashing red
this model did have problems with bad picture tubes---screen goes bright red,green,blue and set shuts down.
set also does this to protect itself---when fails look to see if specific sequence of blinks
Apr 17, 2012 | Televison & Video
Sony Bravia 3D LCD Tv ..I replaced the lamp and it was on for about 10minutes and goes to standby with 3 red light flashing. It has been doing that ever since. Sometimes I turn it on and it will on. once...
Make sure the lamp door is seated properly and back on tight. The door activates a microswitch in the TV and if it fails to do so the end result is the set shuts down with the flashing lights : )
Jul 25, 2011 | Sony Televison & Video
Hi there i have a Bravia # KDL-46VL150 Television
Problem is with the backlight and will get worse over time. Return it if you can. Otherwise, have it repaired by Sony as this unit comes with a 2-year warranty.
Jun 12, 2010 | Televison & Video
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
I have a sony wega
Generally speaking whent he set shuts itself down, the standby light will blink a code. This will be a count followed by a short pause and then the count again etc.
When teh set shuts down, count the blinks and post it here. That will indicate the circuit that has the problem.
Dec 05, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Televison & Video Logo
Top Televison & Video Experts
