Toggle does not work
I have set up projector to laptop. It will not display what is on the monitor and the toggle key does not work
  • 2 more comments
  • maureen282 Apr 17, 2009
    I am using a Dell laptop, and I have tried FN+F8, which does not work to bring up the diplay on the projector.
  • May 11, 2010
    Have you tried another monitor on the laptop to make sure the output is working? Maybe it's a laptop problem. Do you know for sure the projector is working properly?
  • charles raynor May 11, 2010
    have you set your laptop to use either/both laptop screen or vga out?
    you should find that setting in control panel
  • May 11, 2010
    Are you talking about the toggle key on the projector or the laptop? Have you used the function key on the laptop keyboard to make sure the external monitor connector is turned on?
  • 39 Answers
Go into the display settings in the control panel on your computer. chances are your monitor is not set in the display settings. or if you are able to see the screen but not see what is on the computer then it is mostlikely set to "extend windows to this monitor" uncheck that box and you should now see whatever is on your screen. also you may see it listed as 2 monitors. you can drag and move the #2 monitor to the #1 monitors spot and it changes the order of the dispaly for what is the primary and what is the secondary.
Posted on Apr 24, 2009
How do i switch to external monitor
Virtually all IBM and Lenovo ThinkPad and ThinkCenter laptops allow you to hook up an additional monitor or projector to the computer. When you add an external monitor or projector to your notebook, you can choose to view the display on the computer, on the external device, or on both the laptop and the external monitor or projector at the same time. Toggling between viewing devices is as simple as pressing a couple of keys on the keyboard.
Shut down the laptop. Plug the VGA monitor cable from the external monitor or projector into the blue VGA port on the back of the computer. Turn on the external monitor or projector first, and then the Lenovo laptop. Allow the notebook to boot into Windows normally. Press the "Fn" and "F7" keys at the same time to switch the display from the laptop to the external monitor or projector. Press the "Fn" and "F7" keys again to enable the display on both the laptop and the external display device. Press the "Fn" and "F7" keys again to display screen contents only on the laptop LCD. choose support you need http://www-307.ibm.com/pc/support/site.wss/MIGR-54305.html http://www-307.ibm.com/pc/support/site.wss/MIGR-4YQHUC.html enable tv out on thinkpad http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-58625
Feb 13, 2013 | IBM Lenovo 3000 N200 PC Desktop
When connected laptop display goes off but projector screen shows display
normally you can toggle the f8 key on computer. you can also go into display setting and it will show the two monitors and you can change it there.
Feb 14, 2012 | Office Equipment & Supplies
My hp compaq model 510 is not working with projector.projector is not working on this laptop plz provide a proper solution.
You are not providing enough information to help you.
Have you set the display to use an external monitor or dual monitor? That is how laptops work with projectors. You normally can set the system for dual display and either mirror the displays or use the second display (projector) for power point or other presentation.
If this does not fix the problem, post more information on why it is not working for you.
Jun 23, 2011 | HP 510 Notebook
Hi. My Dell Latitude E6410 does not recognize a Epson Projector, model EMP-7800. How can I solve the problem?
Hi
you must tell the laptop to display out on the projector,
how to do that?! you must toggle the display path
Generally, there is button ( with Fn keys ) have dusplay screen sample on it, use it with Fn to toggle the display
Display have 3 modes:
  1. laptop screen
  2. outside LCD projector or monitor,
  3. or bith 1 + 2
you can press the keys 3 times ( at maximum ) to have the display on both laptop screen and projector
Good Luck
May 13, 2011 | Dell Latitude E6410 Laptop
CTX EzPro 550 data projector and laptop operating on Windows XP
Usually the key combination is 'Fn' (function Key) + F4 (or which ever F key that displays the symbol of monitor on it). This key combination is used to toggle the display between monitors.
Please come back and vote for me if this turns to be helpful for you. Thnx
Mar 20, 2010 | Electronics - Others
I am running Windows XP on my laptop. I plan to give a presentation using Powerpoint, and I'd like to plug a projector into the laptop. I cannot figure out how to play Powerpoint's presentation on the...
Couple ways. If you hook up the projector before turning on the laptop it should work. The preferred way, however, is to 'toggle' to the external moniter on your keyboard. Look for a icon on the Function keys (usually F4 or F5) on the top of your keyboard that looks like an external display. It may have a color, like green. It the lower left there maybe a key of the same color. You need to hold the lower left key while pressing the F key at the top. It will likely toggle between the external monitor only, both monitors, and internal only. Good luck.
Jan 07, 2010 | Computers & Internet
My Epson EMP-S4 LCD projector does not display images from my Averatec C3500 laptop. It displays "No signal".. Do i have to press any keys before it would display? I suppose it would automatically project...
When you connect a data projector or external monitor to the external video port on the laptop, power up the data projector or external monitor first then the laptop. The video info will automatically divert to the data projector/external monitor automatically.
If you have already had powered up the laptop first, most laptops will allow you to toggle between the LCD screen and the external video port by pressing the Fn key plus one of the Function keys, this key will have a screen/laptop symbol.
Sep 08, 2009 | Averatec C3500 Tablet PC
No Signal when plugging into laptop
On your laptop you have the ability to toggle the external display on/off/both. On several laptops I see, it is a combo of teh Function Key+F4 (or F5). The key for your laptop (you did not provide type) should be marked with an image of a projection screed or a monitor in a color matching function key; often blue.
With everything connected, press these keys to toggle from Laptop Display Only to Projector Only to Both.
If the problem is not your laptop, then verify the input source that the projector is looking for via it's menus or a button on the remote. Toggle the source if required.
Aug 05, 2009 | Sanyo PLC XU35 Multimedia Projector
No way to get simultaneoulsy my videos on the laptop monitor and on tne projector PLC XU 73 card : ATI Radeon X700
Most laptops have a Function (Fn) key in an alternate color (blue maybe) from the usual key text color (white usually).
By pressing this key, along with another key that has text of the same (blue) color, perhaps labelled with "LCD/CRT" or a pic of a monitor, or of 2 squares - one single square and one double "square in square", you can toggle between the modes of:
1. Laptop display only,
2. external display only, or
3. Both displays.
Be sure to check your laptop model manual for specific details to make sure this is possible.
Jun 09, 2009 | Sanyo PLC-XU73 Multimedia Projector
Projector does not display laptop screen
Many laptop computers do not automatically turn on their external
video port when a projector is connected. On many laptops, the activation function key is labeled with an icon or the text CRT/LCD.
Try the Function Key with the Icon of a monitor to enable the external video port.
If that does work, look at the settings on the projector using the buttons on the top.
Check the "Default Source"
Default Source toggles among Computer 1 analog, Computer 1 digital, Computer 2, and Video. This determines which source the projector checks first for active video during power-up. Highlight Default Source and click the left or right mouse button to toggle
among the options.
Jan 17, 2009 | InFocus LP70+ Multimedia Projector
Computers & Internet Logo
112 people viewed this question
David Payne
David Payne
