Question about Logitech Noise Canceling Headphones - headphones
The right hand side ear phone swivel has broke I want to repair it, can i get a spare part for this? ( logitech noise reducing headphones)
    Problem Solver:
  • 6 Answers
If you cannot find a replacement, I've fixed many of my broken headphones, where they pivot, using acrylic nail powder. You can purchase it at your local beauty supply, like Sally's. You need to buy the powder and the liquid. It will bond it back together and make it stronger than it was new.. You will be amazed what you can fix with acrylic nail powder.
Good Luck.
Jeff
Posted on Aug 21, 2009
Jvc gumy ear bud headphones purple
When you pull the wire up does it increase the right ear bud volume/ sound? If it does, then it means the right side ear bud has a short within the head phones circuit which is aka the wire that leads to the musical device in which the ear buds branch off from.
If the right side ear bud does not produce an increased volume for sound by picking the wire up or pulling it in towards you or to the left side of your body or musical device then it means that the right speaker is blown.
I know that all head phones come spiced together aka they are stuck together and have to be pulled apart in order to get both head phones seperated from each other so that they can be worn in the ears. If you pulled the wire apart to much or too quickly then that is what ruined the right head phone.
I suggest that regardless if the ear phones begin to work by pulling the wire up,side ways, or into towards your body that you return them back to the store since after awhile the problem will eventually continue to happen causing the right ear bud to completely blow. Once you return the ear phones be cautious with the new set when you seperate the ear buds from each other since they are very touchy and have to be handled with delicateness when seperation is taking place.
Please let me know how it works out for you. I have had many ear buds and I tell ya something; they are very easy to blow one side when seperating. I had to learn after a few pairs that I was ruining the speakers by the way I was seperating my wires. I kept thinking for the first 3 pairs that the store was selling blown ear buds until I began having same problems with another few stores so I said to myself "well the solution is to figure out what I am doing wrong in order to blow one side of my ear buds every time". After few seconds it was not that obvious that all I had to do for assembly was to pull the wires apart in order to get both ear buds to go into my ears.
Jan 22, 2014 | JVC Gumy Ear Bud Headphone - Peppermint...
I cant find headphones that fit in my phone?
Try to contact the vendor for genuine headphones, is your cell phone have bluetooth connection? if any just use bluetooth that have universal connector. so you could use any headphones you want.. hopefully it works..
Jun 18, 2012 | LG VOYAGER VX10000 Cellular Phone
14 month old Ultimate Ears 700s and the jack has turned faulty. I can wiggle it around to get both phones to work, but, once I remove my hand from the jack, the right phone goes out. Is this fixable? ...
It is for sure that the wires have come out of the jack connection. This normally happens as the wires are always moved around as your plug and change.
The easy way out for you is to approach any electronics service center who can easily splice off the wires and put in a NEW jack which must be soldered.
This job can be done if you are able to handle a soldering iron and get to solder the jack with the connection on either terminals- just any tech will guide you to do this very easily.
Mar 08, 2011 | Ultimate Ears 700 Noise Isolating...
Left ear no music
Before you worry about repair, verify that the balance control in the iPod isn't causing the problem. The easy way to do this is to try some other audio device (home stereo, etc).
Mar 19, 2009 | Coby CV-190 Consumer Headphones
Bose QC3 makes a high pitch noise when i press it against my ear
The design of these headphones includes a microphone on the outside and on the inside of each earcup. The outside microphone detects outside noise. The inside microphone monitors what you are hearing and when it detects that the outside noise is present inside, the active noise-canceling circuits remove that noise. This happens fast enough that you perceive a siginficant reduction in the outside noise getting to your ears.
The airspace inside the earcup is a tuned chamber defined by the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs. When you press the earcup close to your ear, you are changing the size and shape of the air chamber inside of the earcup thus directing more of the speaker sound toward the microphone than the design can compensate for causing audio feedback to occur. You are hearing that feedback. Removing your hand from the earcup should restore the shape of the air chamber allowing the circuits to return to normal operation.
If the feedback occurs too easily when you are NOT pressing on the earcup, then the foam may have weakened/deteriorated and it may be time to replace the ear cushion.
On my QC-3 headphones, I can cause the feedback squeal in both earcups, with the left earcup being more sensitive to the shape change than the right.
Feb 16, 2009 | Apple Bose QuietComfort 2 Acoustic Noise...
Logitech consumer headphones
the bottom line is, these headphone ****!!! I will never buy another logitech product again
May 12, 2008 | Logitech (9804090914) Consumer Headphones
Logitech Noise Canceling Headphones - headphones Logo
314 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
