Question about Philips Televison & Video
Wont stay on turns on for a second then i hear a
Wont stay on turns on for a second then i hear a clik and it shuts off after a few tries it will go on and stay on but after that i gotta go through the same thing and it gets worse as it goes takes more tries to come on
50 inch plasma tv phillips
  • angelo455 Apr 17, 2009
    its the power supply or needs a new tube
  • angelo455 Apr 24, 2009
    well i fix it and it only cost me $2.50 changed 2 capacitors on mother board if any 1 needs help email me for picture instructions @ ang455@hotmail.com
  • 371 Answers
I have had the same problem with every Phillips with which I have had any experience. Service required, possible DOA.
Posted on Apr 17, 2009
  • Maurice B Thomas
    Maurice B Thomas Apr 17, 2009
    True. But wait until you get the quote for that!
  • Maurice B Thomas
    Maurice B Thomas Apr 24, 2009
    Actually, you would be better off selling your fix to Phillips!!
When i turn my tv on the screen just stays black. You can hear the volume. I just replaced my bulb about a month ago. I took the bulb out again to see if it was blown and it wasnt. Does anyone know wh
send me a email slinteriors@yahoo.com and I will send you the info to retreve the error code to find out why the set is shutting down. Be sure to include the moodle number and symptoms with your email
Feb 10, 2013 | Mitsubishi WD-65C9 65" DLP HDTV
Truck wont shut off for a few seconds after turning key off
try using high test gas if that dosnt fix it you need to retime the engine. you are risking total engine failure do not wait another day.
Jan 05, 2013 | 2007 Dodge Dakota Cab SLT
My 1993 nissan sentra 1.6 wont run and check engine light wont turn on,bulb is ok
Could be any of several things. If the crank sensor is marginal and not sending pulses, the fuel pump is shut off. This is for safety. The pump is energized for a few seconds as key is turned in preparation for starting then engine must rotate normally to keep the pump on. If it stops, in a few seconds the fuel is cut off.
Aug 17, 2012 | 1993 Nissan Sentra 4 Door
Turns on hear a click shuts off
Bad thermostat is the most lilky cause,
Jun 20, 2010 | Haier Water Dispenser w Fridge...
Started up my acura tl 2000 and started to hear knocking and shut off
Check oil level and oil pump. Oil pump light should turn off after a few seconds after start up. If light stays on for more then 3 second shut off and do not drive or run motor.
Jan 12, 2010 | 2000 Acura TL
Our grill doesnt seem to be getting enough gas to stay lit. when you turn the burners on your hear the gas coming through for 2 seconds..then nothing, and it wont stay lit
How are you turning the grill on and off? It sounds like a vapor-lock. Try this: first unhook the regulator and crack the valve on the tank open...if you hear and smell gas coming out, good, close the valve and re-connect the regulator then open the gas valve then turn the burner on and light it...then shut it off by closing the tank valve first and let the burners go out then turn off your burner valves...try that and let me know what happens.
Sep 06, 2009 | Grilling
Mitsubishi 50inch TV Turns off right after I turn it on
tv is in shut down.could be several things.call a repairman.
May 10, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi vs50111
find service manual online, look for fault code test. if it shows a fault for power convergers, get new fuses and convergers. replace them.
Apr 01, 2009 | Televison & Video
It wont stay on
Hi Kimberley,
Looking at your brief description of the problem a possible fault may lie with power supply and or battery.
Have you access to another Armada power supply? if not does the light go green when Pc is turned off and fully charged.
I would be looking in these area's for the problem.
Good Luck,
Paul 'W'
Onyer~EDson(:0) {#><U.K.
Jan 15, 2009 | Compaq Armada E500 Notebook
Televison & Video Logo
469 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
