Question about Epson Stylus C86 InkJet Printer
Epson c90 paper feed problem
When i print on my epson c90, the printer feeds a paper but does not print and the computer reports that paper is not fed correctly. when i press the maintenance button the printer ejects the paper and feeds another paper then the computer reports a paper jam. needs help please...
  • Anonymous Mar 14, 2014
    regular paper feeds but photo paper will not - not a jam although printer says jam
  • Epson Master
  • 511 Answers
Is the message general error? The problem is tchip. When turn on chip is recognized by printer, but when start to print, printer "read" some information from the chip. Here is the error. Some pin at the chip for redaing the existence of chip, other pin for reading the information. Check connector between chip and carriage.
Posted on May 30, 2009
Preprinted 4 part paper crunching up when being printed in epson lq680 printer
Mustafa:
The printer is not meant to use multi-copy carbon invoices. The cause of your problem is the double-feed prevention pad below the paper pickup roller. When the first form is fed, the double feed prevention pad will stop multiple paper feeds. With multi-page carbons, the paper feed roller is trying to feed the form, and is pulling the top page of the form into the feed rollers while the double-feed prevention pad is stopping the bottom form from feeding and the top and bottom pages are sliding because of the carbon paper between the sheets. The only solution that I know of is to buy a printer with a tractor feed and pre-printed fan-fold forms with tractor feed strips on the sides of the forms.
Oct 13, 2012 | Epson LQ 680 Matrix Printer
Printer won't print documents. Green light on
Hmmm, try feeding a sheet of paper into the manual feed slot... you might have inadvertantly sent a Manual feed job, and the printer is waiting for a sheet to be fed by you.
Feb 10, 2010 | Dell 1710n Laser Printer
The printer only prints half a page then moves to next page and a
Before printing, the printer checks the paper size. If the paper edge guide is positioned incorrectly, the paper may be fed at an angle. If this happens, the bottom of the paper is therefore at an angle and not perpendicular with the paper feed rollers. This can result in the paper sensor not recognising the real page width as it can only detect a certain amount of the bottom of the paper sheet which is nearest to it.
If only part of the width of the paper is detected, the printer considers that the paper width is less than it actually is. To avoid printing on internal parts of the printer such as paper feed rollers, the printer automatically cuts the image to fit the detected paper width As this phenomenon depends on the paper feeding condition, it can be random.
Reload the paper and make sure it is loaded correctly. All the way to the right and the paper guide correctly adjusted.
Feb 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus Photo R350 giving a paper jam error message
An Epson service man (he was VERY kind to suggest this) told me to use a weak detergent solution on the rollers, NOT alcohol as that will dry out the material the rollers are made of. Although the problem has recurred a couple of times, it's worth repeating when necessary. I actually activate the 'print' command so it tries to feed in paper, while I FIRMLY hold a piece of fine cotton cloth stretched over a thin plastic ruler, which I hold down where the paper feed grabs its paper. The printer has a couple of tries to feed paper, reports an error message (because there was no paper) and I activate it again, thus exposing the WHOLE of the feed wheel to the cleansing cloth! WORTH A TRY!
Jan 30, 2010 | Epson STYLUS R350 Photo Printer
Epson stylus color 880 printer has a paper jam. It printed color in area with no paper, so to get ink out, I fed in a paper towel. Now the towel is stuck and torn remnants cannot be reached from above. ...
OK this takes a bit of technique and bravery. You need a stiff piece of card such as the backing from an A4 notepad or similar. Turn the printer off and insert the card into the paper feed. You will need to align it with the pick-up roller and push it through quite hard to overcome the spring pressure. It will push out the bits of towel so open the cover and fish them out. Feed the card all the way through and out of the cover. Always try to remove paper jams in the direction of paper feed.
Hope this helps, please take a moment to rate this solution. Thanks.
Apr 02, 2009 | Epson Stylus 880 InkJet Color Printer
Paper will not feed through - epson DX4000 printer/scanner
Did you check the thickness? My printer won't feed paper that's to think or thick properly it sould say in the manual what thickness of paper you should use.
Mar 24, 2009 | Epson Stylus Multifunction Inkjet Printer/...
My printer, makes a grinding noise, when the paper is feeding through when printinig?
Look to make sure that there isn't a small bit of paper caught in the wheels that push the paper through. Over time, even a small bit in the corner can destroy your printer.
Mar 22, 2008 | Epson Stylus Photo R300 InkJet Printer
Paper will not feed
These are basically throw away printers. But you might try checking the paper path. There are small plastic "arms" that guide the paper as its picked up and goes throught he printer. Sometimes one of these may get stuck in a position that makes the printer think there is paper in the path somewhere.
Mar 19, 2007 | Apple Epson Stylus Color 777i InkJet...
Epson Stylus C86 InkJet Printer Logo
983 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
