Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Lamp location i was told the lamp is in the small door in the rear on the t.v, just to the right and up a little from the fan secured with 2 screws...its where the cord to plug the t.v. in comes out. I opened that door and see no lamp. is this right? and whats the lamp supposed to look like ? how do you take it out. my main problem is finding the lamp first. thankyou
  • helpme86 Oct 27, 2008
    i have a jvc d-ila and i cant find the lamp to replace it...anyone know where it is?
No, that was wrong advice. On this model, there is a large door on the right side (as you face the screen) of the TV at the bottom. Remove several screws to take the cover off. Inside, looking along the back of the TV (not toward the screen), you'll see what looks like a wire bail (handle) on a square inset piece about 3 inches square. Remove the screws and pull on the wire bail and the lamp housing will come out with the lamp contained inside. Make sure you unplug the TV before doing any of this. If you are replacing the entire housing with a new lamp you can just plug in the new housing and replace the screws and cover. If you are placing a new bulb in the existing housing you take off 4 small screws and remove the metal cage from the housing, remove and replace the bulb the same way the original is in there, put it back together, and you're done.
Posted on Sep 25, 2007
  • svdon Sep 25, 2007
    Sorry, should have said... on the right end (as you face the screen)...
WHERE IS FUSE LOCATED ON BIG SCREEN TV, REPLACED LAMP , STILL NO PITCURE BUT I HAVE A SOUND, STAYS ON A LITTLE WHILE AND KICKS BACK OFF
You must follow instructions very carefully when replacing the lamp. Chances are the door did not get shut tightly allowing an open circuit to the door switch and the fan. If the fan is not running you must go back and make sure the lamp installation is right. also, if you did not purchase an exact replacement lamp it may be defective. If the fan is running then the chance is for a bad lamp. Hope this helps.
Feb 10, 2015 | Mitsubishi WD Televison & Video
My Panasonic multimedia projection tv -PT-61LCX65 needs a new lamp....where is the bulb located within the tv? How do I remove?
Hello, the lamp is located at the rear of the set. Unplug the tv before you start. There is a door secured by a screw, remove it to expose the lamp housing. There is a screw that secures the lamp, remove it, then you can gently grasp the handle and slowly pull it towards the rear of the set. To replace the lamp, gently slide the new lamp back in and secure it with the screw you pulled out. replace the lamp door cover, and replace the screw. plug the tv back in and turn it on, you should be fixed. Here's a link to a video on how to do it....https://www.youtube.com/watch?v=xvF36pepCOI.....tks
Jul 04, 2014 | Panasonic PT-61LCX65 61" Rear Projection...
Samsung HL-S5087W (" CHECK FAN # 1") is displayed
hello Harley,
Lamp # 1 is lamp fan, Lamp # 2 is DMD board fan.
Lamp # 1 is located behind the lamp.
Pull assy angine out you will fine fan # 2 , clean it or replace it if not rotate properly.
Fans displayed on screen because fans are dirty or air flow not smoothly.
Good luck.
Mar 30, 2011 | Samsung HL-S5087W DLP TV
The lamp LED blinks 4 times and repeats, I replaced the lamp but the lamp led is still blinking 4 times and repeats and I have no picture
4 times blinking light indicates problem with exhaust fan in KDS-R50XBR1 and possible causes are as follows:
-Fan 1-4 power is not supplied. (ASU board)
-Fan connector is not attached securely.
-Fan caught wires or harnesses.
Please check exhaust fan in tv, it is located at lower right of tv looking at rear of tv.
Thanks.
Feb 04, 2011 | Sony KDS-R50XBR1 50" HDTV
2 rear fans are working, after ballast spark the 2 rear facing fans then stop and the power light blinks red 4 times, is this a failing ballast?
Hi
Please check correctly how many times the power LED is flashing. There is no option for flashing four times.
Flashing 3 times- Lamp door or lamp is no securely attached
I have attached a diagram how to check it please follow the steps and you can get rid of this problem65de2ca.jpg
Thanx
Jul 31, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Kdt-42we655 red/standby power switch flashes 3 times at a repeat, after tv is turned on just replaced bulb after last on burned out causeing small amount of damage due to clugged fans
Your lamp door is not secure. You may need to replaced the door if it warped. PN: X-2048-503-3. Also, you need to address the clogged lamp fan, it should be replaced. PN: 1-787-460-11.
Mar 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
My SONY WEGA 52in Blinks red 4 times...
Youe suggestion of fan is the right Tack. I would also suggest looking fo air filter and cleaning or replacement. The fan is located near the lamp assy. you should be able to hear it when set is on. Good luck.
Jul 03, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Optical block
I think, Lamp compartment locates at rear side near cooling fan. Open the cover and pull out the lamp. Please Don't pull HOT lamp.
May 27, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Zenith E44W46LCD Lamp Access Door Location
I found the location to get at the lamp. If you are loking at the front of the TV there is a small panel at the bottom of the right end. Two screws, remove panel, two screws inside and a small handle that lifts so you can slide the unit out. 4 screws on top of the cage that the lamp sits in, carefully slide up the silver bracket holding the bulb, be careful the edges are sharp. Remove the bulb from bracket and remove the 2 cables attached to the bulb. Now just do the same but in reverse. Make sure you wear plastic gloves that should be provided because if your fingers touch the lense you could be out the price of the lamp.
Aug 31, 2007 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
63 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
