Question about Car Audio & Video
It would not turn off at all
I have got a 1.5 farad car audio capacitor which does not turn off when i swich off my music it stays on all the time
  • 47 Answers
Your Powercap will turn off, you will find that it will take a while sometimes because there is always power going through your car. i.e if your interior light is on.. boot light anything that consumes power will effect this.
They do turn off tho once the car is left for a while :)
Hope this helps
Upfront Audio
Posted on Apr 24, 2009
I have a PCX-5F POWER ACOUSTIK 5-Farad Digital Capacitor and after i turn the car off it stays on and sometimes when the keys not even in the ignition the cap stay on. why is it doing that?
It is a capacitor. Please read up on how capacitors work and it will explain itself.
The capacitor is holding a charge, just like it was designed to do.
Oct 01, 2012 | Power Acoustik Pcx-5F 5-Farad Digital...
Are the capacitors suppose to stay lit and will it kill my battery?
It should be turned off with the key. If it continues to stay on it is installed incorrectly to a constant power source.
Mar 30, 2011 | Rockford Fosgate Rfc2d 2 Farad Hybrid...
It stays on all of the time and it is draining my battery
once a capacitor is charged, it should not be draining the battery, are you sure it is not something else in the system?
Mar 22, 2011 | Stinger 1 Farad Chrome Cap Capacitor W/...
What number of cable should use on rockford fosgate 1 farad capacitor thanks
If good brand name wire, jl rockford monster kicker, the 8 gauge wire will be fine. if buying it at walmart or somewhere, then use 4 gauage wire
Jul 19, 2010 | Rockford Fosgate 1 Farad Capacitor Cpc10...
It's beeping when turned on. Why?
I have read that if the polarity is reversed, or the connections are backwards, the Capacitor will beep. If this is not the case, it may need to be replaced.
The voltage meter stays on an there is a flashin blud led light every 3 to 5 second only flashin 2 to 3 times a cycle, having problems with running battery down also, brand new battery too? would having it...
the LCD meter will stay on until voltage in the car stabilizes, and you will notice that if u hit the power unlock button it will turn back on after its off..
do you have it hooked up correctly?
I Usually run power from battery to + of capacitor then another wire from positive of capacitor to amp, Then you can run ground from amp to capacitor negative then anotheer wire from cap - to a good ground
Mar 30, 2010 | Tsunami Lite Wave Capacitor 2.0-farad with...
JL Amplifier 500 1 shuts off after i put the music up a bit. at low volume levels it's ok. But when i put the volume up it will turn off. Have had the same setup and setting on the amplifier for 1yr. just...
Check the wires going to the amp for any corrosion on the terminals and ground.
. Kind of like when someone squeezes a garden hose2_bing.gif when your trying to use it. That would be the high volume, starving the amplifier. The capacitor stores power in it to power the amp at high volume. 2 farads would probably be bulletproof on a single amplifier system, but 1 farad should work well enough. Or seek help from an expert on exactly what size capacitor you should use. If you find yourself saying: My amp cuts out.
If this assisted in solving your problem, please take the time to rate it. Thank you.
Mar 03, 2010 | Jl Audio 500/1 Car Audio Amplifier
My amp goes out and turns red when i get to a certain volume
get a 1.5 farad they have them at walmart for like 40 bucks
Dec 23, 2008 | JBL BP600.1 Car Audio Amplifier
Battery
First off, are you trying to stop lights from dimming? Because a capacitor is only a band aid to solving that issue. If you are using a capacitor for its intended purpose (to smooth out the voltage input to the amp, thus providing a more consistent voltage level), the general rule is 1 farad per 1000 watts rms. I hate to tell you caps aren't worth it, but this amp is a good amp. There are built in capacitors already. If you really want to see an improvement in your system, you will want a quality cap along side a quality amp. Look for an Alumapro capacitor. They go all the way up to 50 farads. High in price, very high in quality. Perfect compliment to an amp such as yours.
May 09, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Amp shuts off when music turned up
try adding a capacitor to feed the amp. these are large in capacity (farads)and dims (about 6' x3' dia.)...what wire size are you using?
May 30, 2007 | Sony XM-2002GTR Car Audio Amplifier
Car Audio & Video Logo
53 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
