Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Too much water in espresso, Steam spits water
When we make an espresso the espresso turns out weak and with a little too much water. The steam also spits water. It's as if the boiler does not come up to the proper temperature. We have descaled the machine but it does little or no improvement. Any suggestions on how to fix this would be appreciated. Thank you.
  • mlandwehr Apr 24, 2009
    I'd like to make stronger, hotter expresso, too. We have it set to a fine grind, good Italian beans, maximum coffee dispensed & minimal water. The digital version allows temperature adjustment. Is there a way to increase the temperature on this model?
  • 1,089 Answers
Hi
Yes it is possible to raise the temperature but it requires taking the top off. Most people are not into removing the top. email me if interested
Posted on Jun 01, 2009
Steam is not strong on my ec702 delonghi. I have cleaned the wands. The wand spits out a lot of water with a strong steam, bu the steam gets weaker as I am trying to froth.
The steam temperature control (Thermostat) is not functioning.
The small quantity you get at the start is the steam pressure build up with hot water. Water steam cannot keep up the pressure.
Replace the steam thermostat.
Dec 24, 2016 | DeLonghi Coffee Makers & Espresso Machines
No steam
TRY RUNNING SOME VINIGER THROUGH IT THAT SHOULD CLEAN IT AND RETURN THE STEAM
Mar 30, 2014 | DeLonghi BAR 32 Espresso Machine
Very hot weak bitter coffee
Ascaso dream temperaturegauge
It should be between 80°C/180°F degrees for the coffee and 100°C 212°F degrees for the steam.
You may have to replace the thermostats.Use thermal paste for correct fit.
Ascaso boiler thermostats 2
Feb 05, 2014 | Ascaso Dream Espresso Machine
No water flow, low motor sound, weak steam
looks like your shower disc is blocked remove screw under head you well most proberly find it is blocked when looking up to light clean disc with brush until you can see through holes reassemble you will find flow and steam are better hope this helps
Dec 13, 2012 | Gaggia Baby Espresso Machine
Makes a bang sound and spit sout steam
Try first to pour out some hot water first from steam wand and then try to make coffee.
Jun 30, 2010 | Krups Small Appliances Espresso Machine
Gaggia TS Espresso Machine although my machine seams to work OK, It does not seam to produce much steam any help would great
Their is a grait posibility that the steam want is blocked from dry milk that is why you have weaker steam out. So you can first try to boil only water for some minutes and then leave the steam want in for more than 30 minutes. Then try the steam again and posibly the dry milk will be spit out. You can even boil the water with some cooking soda in it which can help more.
One more think that can help to clean the steam wand is to use a thin flexible steel wire in the steam wand so it can clean it more.
This is the most posible solutions you can try.
Good Luck
Mar 22, 2010 | Gaggia TS Espresso Machine
Rancilio Silvia: The steam works only for about 10 seconds
Remove the top panel and check the 3 thermostat on the machine one of them is not functioning properly, find the wire to the steam switch and trace it to the thermostat.
Jan 26, 2010 | Rancilio Silvia Espresso Machine
No steam when valve opened, spits out water in the beginning of frothing
There is a small teflon piece on the inside of the steam tube, you will have to disassemble the frother to get to it. Remove this piece. Reassemble and the wand should work fine.
May 08, 2009 | Gaggia Syncrony Compact Coffee...
Can't get milk to foam
Place 1/3 part distilled white vinegar and 2/3 part water into the water reservoir. Turn the machine on and wait for the heat light to go off. Once the heat light goes off, turn the steam vs. water knob to the water drop icon, and turn the main function knob to steam/water. Make sure to have your frothing cup underneath the steam element ready to catch the water. The vinegar/water solution should clear out the calcium that clogs the steam element. Also, remove the cover to the steam element and dip it in a bowl with vinegar for about 5 minutes, and use something like a pipe cleaner to clean out that cover. Then apply vinegar and hot water to a rag and clean the calcium off the shaft of the steam element. Once you are all finished with this, run plain water through the espresso maker on the steam/water setting to clear out the bitter vinegar residue. Now, try again to make espresso and froth it.
Since milk contains calcium, the steam element has to be decalcified more often than a regular coffee maker. The EM-100 is a beautiful machine, but it is definitely high-maintenance - you will probably spend more time cleaning it than making cappuccino, etc.
-Tha Mp3 Doctor (is also a huge Cuisinart fan)
Feb 22, 2009 | Cuisinart EM-200 Espresso Machine
Weak steam on steam mode and strong steam on water mode
Run the descale again, it seems that the booster boiler has a small blockage and or no water.
Dec 26, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
244 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
