Black marks across top of copy spaced like rollers. Canon Imagerunner 3320i
  • mbernstein Apr 20, 2009
    Thanks for your help!
  • 135 Answers
The first thing is too remove the optics from the picture, what you want to do is go into additional functions and try to find where to print a report of anykind, if marks appear you have a drum or fuser issue, if marks are not present then you need to clean your copy glass and dont forget the little glass to the left side of machine
Posted on Apr 19, 2009
  • brian martin Apr 20, 2009
    your welcome please dont forget to rate the answers you recieve it helps out the expert, thank you
My Canon ImageRUNNER 3225 does not print correctly aligned when sent through the feeder? When feeding paper, I have tried Landscape and the resulting copy is cut off from the top and bottom and the left...
Is it ok when you just put the document on the glass? If so, the Document feeder needs a whole set of rollers.
Otherwise the document scanner may be bad. This needs to be changed out by a technician.
Whit
Item, Inc
Sep 15, 2010 | Canon imageRUNNER 3225 Black and White...
Cannon imagerunner 3320i has excess toner coming out of toner cartidge area. I can clean it and its fine for two copies, but after that... all copies start turning black.
You need a black image unit , I can give you a price on one and walk you thru replacement. My e-mail is geminibusiness@att.net
May 13, 2010 | Canon Image Runner 3320I Copier
A 1" wide band of black ink continues to to mark copies when printing. Even after roller is cleaned, issue persists
Try printing in single color mode found in the drop down menu - top left corner of the screen. If the line is not present in cyan or magenta etc, then you are probably looking at the black drum unit being faulty. If it happens in every mode, it could be your ITB cleaning assembly that needs replacement. Check the drum life counter in service mode - if the black is very high - over 100% this is another indication (not proof) that the black drum is faulty and needs replacement.
Jan 28, 2010 | Canon imageRUNNER C3220 Color Copier
I have a canon imagerunner 330s copy machine. I'm
Hello sir;As your descript, it seems need to replace drum blade, if they come with whole cartridge then replace whole cartridge.
May 12, 2009 | Canon ImageRUNNER 330s Copier
Grey Band/lines across page
your problem could be one of many things first try stoping the copy half way in the machine. to do this open the front door and cheat the door switch with some folded up paper or use a flat screw driver to bypass the switch. make a copy and watch the paper when in goes into the drum and starts to come out like 3 inches pull the screw driver or paper out of the switch. carefully pull the paper out from the machine and see if the image is ok. if the marks are there the problem is with the drum. if the image is clear and there is no marks then open the left door on the copier and inspect the rollers in the heat unit. to do this open the left door the front door has to be open to do this. there is a little green lever on the right side pull this down and look at the 2 roller if you see marks on the top roller or dirt on the lower roller this is your problem. also check the miliage reading on the drum if there is a sticker and check the meter on the machine the drum is rated for 55,000 copies.
Jan 03, 2008 | Canon imageRUNNER 400S Copier
Copy Problem
this could be two things first, the transfer belt is slipping. It can be cleaned on the inside of the belt and the rubber drive roller. second, the laser units need to be timed, its not hard to do but a service tech will need to do both. it should be running great. the 3200 is a great box
Dec 06, 2007 | Canon imageRUNNER C3200 Color Printer
400S Black lines at top of copy
Sounds like the drum is worn out. Usually do 60-70K before replacement. Shading more noticeable at top of copy. Could also before worn upper fuser roller.
Nov 09, 2007 | Canon imageRUNNER 400S Copier
jasbo
jasbo
