Question about Hotpoint RGB745 Gas Kitchen Range
The oven is not coming on - Hotpoint RGB745 Gas Kitchen Range
  • chang2roscoe Apr 17, 2009
    The stove works but the oven does not come on.
Most likely a bad ignightor, I would start there
Posted on Apr 24, 2009
Electric Oven will not heat or come on
Sounds like you have burned out the element?
Aug 12, 2015 | Ovens
WE HAVE AN ELECTROLUX DD060GA DOUBLE OVEN THE TOP OVEN IS WORKING BUT THE BOTTOM OVEN DOESN`T EVEN COME ON WHEN YOU TURN THE KNOB THERES NO GAS AND NO SPARK AND THE LIGHT WONT COME ON EITHER, CAN YOU...
Good Morning Friend,
I understand that your Electrolux double oven, model# DD060GA, is having trouble with the bottom oven coming on. I also see that your top oven works just fine. This appears to be a UK Electrolux double oven. I suggest contacting the manufacturer directly. They will be able to better assist you in getting your bottom oven functioning correctly.
-Best Regards-
WP
May 21, 2014 | Electrolux EOG7330WN Gas Double Oven
Caloric wall oven set timer and now oven will not come on
reset timer to zero .turn on the oven .numbers should flash press once .on 12 light should now come on for the oven.
Dec 20, 2013 | Cars & Trucks
Lower oven will not come on. Top oven and cook top works
Does the oven indicator light come on when you turn the oven on. If it does the oven element or the wiring at the oven element terminals will be faulty. If it does not come on it will most likely be a problem with the oven control thermostat.
Feb 24, 2011 | Ovens
I have a Tecnik TKC 8522 double oven - I can't get the bottom oven to heat up. When you turn it on the fan comes on, but the red light doesn't come on and the oven doesn't heat up.
If the red light does not come on, then this suggests that the oven thermostat or control switch is fault.
Even if the element was faulty, the red light shuld still come on.
Sep 25, 2010 | Tecnik TKC8522 Electric Double Oven
Gas in oven wont come on,burners and broiler ok, oven light comes on but oven won't come on,electrical connections ok, checked
this is a 2 burner oven with 2 ignitors . the bake ignitor is too weak to light the burner . replace it and the bake should work properly .. mm
Jul 13, 2010 | GE JGRP17 Gas Single Oven
Oven not coming on correctly or up to temp setting
The most common problem is a bad oven glowbar ignitor.
The part number is 5303935066.
Remove the oven racks and the oven base pan to access the ignitor for replacement.
Mar 18, 2010 | Frigidaire Ovens
Smoke come up from bottom of 3-month new smeg oven SA702X when try to heat up
Hi.
Smoke coming from the oven is not normal. Ensure that the smoke is not vapour coming from the food inside the oven.
If there is vapour coming from the hinge area, then ensure that door and hinges are installed properly.
If you get smoke from the oven, try cleaning the oven cavity, follow the instructions on manual to clean the oven.
If after cleaning the oven, there is still smoke coming from the bottom side, then call Smeg and have the oven replaced. There is one or two years warranty on the appliance.
Smeg support and service phone number is listed in the oven manual.
Regards.
Mar 09, 2010 | Smeg Ovens
Oven wont work
when i turn onether oven then a bipping alarm and oven will not come on. light come on but not heated up.
Aug 30, 2008 | Ovens
Hotpoint RGB745 Gas Kitchen Range Logo
113 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
