It's possible that your Freesat Panasonic Blu Ray recorder DMR-BS750 may not be compatible with the specific HD format used by BBC1. Here are some troubleshooting steps you can try:
Check that your Freesat Panasonic Blu Ray recorder is updated with the latest firmware. An outdated firmware can cause issues with recording.
Check if the recording schedule is set up correctly for BBC1 HD. Make sure that the start and end times are accurate and that the program is not set to record in series.
Try resetting your Freesat Panasonic Blu Ray recorder to its factory settings. This will clear any possible software errors and may help to resolve the issue.
If none of these steps work, you may need to contact Panasonic customer support for further assistance. They may be able to provide additional troubleshooting steps or recommend a firmware update or other solution.
It's also worth noting that some broadcasters may use proprietary or non-standard HD formats that are not compatible with all devices. If this is the case with BBC1 HD, it's possible that your Freesat Panasonic Blu Ray recorder may not be able to record this channel.
The could have been hit by a small power surge and it you disconnect all power to and unplug it from the wall for 30MIN., it will reset back to normal.
I have a Panasonic DMR EH50 DVD recorder and have just discovered this evening that everything on it is displayed in Black & White (tuner, recordings, menu, dvds etc). Yesterday everything was working in full colour. I have checked all my leads and have no solution to this problem and also need help.
Not sure exactly what you mean by "unlock". I suggest you try some of the "commands" listed onhttp://www.dxcc.com/dmr-e85h.htm Perhaps one of these commands will solve your problem.
will not record HD programes
