Question about Xact Communication XTR1 SIRIUS Radio Receiver
My sirius radio turns off right away
When i turn my sirius radio on it turns off right away
TRUN ON SIRIUS RADIO IN MY HOUSE .COM
Posted on Jan 11, 2008
Sportster 5 turns on and off randomly every few seconds hooked to a dock.
Sportster units get very hot ! If you use it in the boombox stop ! Take the radio unit out - remove the silver cover from the boombox ( don't overlook the 2 hidden screws under the speaker grills ) take a dremel tool with a cutting wheel - and cut all the shrouding away around the top of the reciever. This will allow the radio to run way cooler ! I also drilled several holes thru the swivel mount to allow better air-flow !
Jan 02, 2012 | Sirius Satellite Radio Sirius Sportster...
My sirius sporter 5 keep turning off and on while driving
Power or Signal drop-off can be fix at ebay item# 360454042820
http://www.ebay.com/itm/ 360454042820
Dec 12, 2011 | Sirius Sportster 5 Satellite Radio...
Cannot get my Sirius radio ID on my 2007 Passat
Turn on the radio and put it to channel zero there you will see an alphanumeric characters that is the radio id or visit this link http://www.siriusxm.com/help.
Apr 02, 2011 | Car Audio & Video
Same problems here also, had sp-1 for 4 yrs no probs at all! I even have a brand new antenna, needed to be replaced any way, thought that would fix problem (ACQUIRING SIGNAL) No luck ,why does everything...
Go to XM, I did. But first, call Sirius and ask them to 'refresh' your receiver. Leave unit on channel 1 for 30 minutes and see if problem go away. Make sure to turn off and on with pushbutton on unit - not remote, and do not just diesconnect power..
Dec 28, 2009 | Sirius Satellite Radio Sirius Sportster...
Speakers on right side of car not working when satellite radio is
Try rewiring the system matey, you proberly need to daisy chain them together
Feb 16, 2009 | Sirius Satellite Radio Receiver
Did you ever get your starmate to work?
same here...
happened today...these all seem to have expiration dates
it came to life twice but now , it's possible fubar
shame to throw away,as i have the home kit .. non compatible , or buy another?
Jul 16, 2008 | Sirius Satellite Radio Sirius Starmate ST1...
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
Sportster 4 not working...
I had the same issue. This is what Sirius calls a "Frozen Unit". There is no bypass, unfortunately, and it must be returned.
I had mine for 3 days and it froze on the Sirius Logo screen when booting up. If you bought the unit from Sirius, you must contact their E-Commerce department. If bought from a retailer, take it back to the store.
Sorry, mate.
Oct 13, 2007 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Satellite radio
Do you Have the right adapter Plugged in??
Jun 22, 2007 | Sirius Satellite Radio Sirius Starmate ST1...
Xact Communication XTR1 SIRIUS Radio Receiver Logo
582 people viewed this question
Top Xact Communication Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Xact Communication Audio Player and Recorder Expert? Answer questions, earn points and help others
