Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
Wptg9350c profile harmony washer- hot water slowly fills washer
Everything works fine till after the wash. Hot water fills tub slowly after wash is done, can hear the hissing sound of the water and when I turn off the hot water supply it stops. If I dont turn off hot water the basket gets filled when I come back to it later. I have had this problem a few times in the past and thought I had read it has something to do with putting too much detegent in at one time, so its diluting the machine. (?) Also I noticed that it sounds like there is water under the baket when I move it around, but not in the basket. Is this normal? Thank you for any help you can offer. Kevin
  • GE Master
  • 19,396 Answers
That is not normal. Usually this happens because of a faulty inlet valve or because of a faulty control/timer board. The inlet valve is tested first and eventually replaced.
If the valve is ok , then proceed in testing the timer board.
Posted on Apr 18, 2009
What does it mean when my lg tromm WM2487HRM front load washer slowly fills the tub with water when the washer is off?
most likely water fill valve is defective and leaking. hot water or cold water? replace which ever is leaking
May 21, 2016 | LG Washing Machines
Cold water trickles in tub. Hot water fine.
remove the cold water hose from the machine that is your service line feeding into it.
a screen in the inlet were the hose attaches to is probably clogged up
May 28, 2010 | Washing Machines
Brand new roper washing machine model # RTW4440VQ2 the cold water is very slow filling hot is fine
This model of washer has something called an Automatic Temperature Control. This means the washer puts water into the tub at specific tempreatures instead of just 100% cold, or 100% hot. Be sure and check that the hot and cold fill hoses are connected to the proper places on the back of the washer. It's possible that the ATC (mentioned above) is causing the washer to fill slowly on the cold setting.
May 20, 2010 | Washing Machines
Water comes out verryy slowly when using cold wash GE large capcity washer
check the fill hose washer located in the washer cold water fill hose,they get clogged with lime and such,and when you replace the washer run hot water thru the hose to clean it out thoroughly,
Apr 24, 2010 | GE Profile WPRE6100G Top Load Washer
I can't get the cold water to fill the tub/rinse. the hot works.
Your problem is either a clogged COLD fill valve or a bad water fill valve. Turn the water off. Remove the COLD hose from the WASHER. Check the filter screen inside the valve for sediment. If you find sediment,remove the screen and clean it. Replace the screen and turn the water back on. If you do not find sediment on the screen,replace the water valve.
Sep 21, 2009 | Frigidaire FWS1339A Top Load Washer
Hot water stream when tub fills & how full tub gets super wash
there should be a knob connected to your water lines that come from the wall, turn the hot to the left.
Jun 22, 2009 | Estate Washing Machines
Error message only prior to the rinse cycle,not filling correctl
The cold water solenoid valve seems to have failed on you. They're easy to replace and can be purchased at any appliance parts company
Jun 15, 2009 | GE Dryers
LTE6234DO Whirlpool Thin Twin-No hot water
The inlet valve that the hoses attach too the solenoid for the hot side may be stuck closed or clogged with sediment. May need new inlet valve.
Mar 18, 2009 | Whirlpool LTE6234D Top Load Stacked...
Ge profile whsb8000bocc
Washer is most likely trying to fill with cold rinse water and the inlet screen is blocked or the cold water solenoid is bad. If you set washer to wash cold only it will not fill or fill very slowly. When you set it to warm or hot you are getting almost all hot. Clean inlet screen or replace inlet water valve.
May 12, 2008 | GE Profile WPSR3120WWW
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket Logo
81 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
