Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
No picture I have a 46 inch sony that has no picture. I can hear the sound. The t.v is about 11 years old. The antire circuit board was replaced under warrenty about 6 years ago. what could be the problem, and what might the cost be to fix it. we really like the t.v thanks
    Genius:
  • 1,139 Answers
This looks like a problem with the Hv Voltage section of the TV set. What you need to do is to measure the voltage from the HV transformer to the Anodes of the CRTs with a high voltage probe, or have this done by a qualified TV technician.
Or check the voltage test points on the HV / Horizontal board. This will determine if the section is working or not (most likely not). Make sure you have a schematic, and multimeter and a high voltage probe.
I would suggest that if you do not have a background in electronics that you have a qualified electronics technician who knows TV take a look at your set and perform these test.
I hope this helps,
Thank you,
Shuttle83
Posted on Oct 26, 2007
Samsung 46 Inches LCD TV Model#LN46C630 Black Screen with Sound
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 23, 2016 | Samsung LN46C630 TV
I have a 46 inch Sony Bravia. It is several years old. Maybe 5? A few years ago the screen was replaced under the extended warranty we bought from Target. The problem started out as shadows on the screen....
Is it a perfect square like there is a box on the screen ? if so it could be an easy fix if not then time for a new TV!! Did it just slowy get worse or was it just like that one day?
Nov 17, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Have a sony 46 inch rear projection model #kp 46wt510! Purchased it new in 2004! Have nothing but great things to say about picture untill today! I have a color seperation with red, whatever line or...
This is problem of convergence output chips failure and it is fixable.
Replacement of convergence output chips on D board will solve tv problem, local tv repairman will do this job because convergence output chips replacement requires soldering work on circuit board.
Thanks.
Jan 01, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
New 46 inch flat panel TV. After the TV has been on for a couple of hours the picture goes out but the sound continues. Anyone have this issue before?
Yes,the causes is the tv Tuner signal board have a short in it some kinds.That the board,where the incomming tv broadcasting signal cable plug.New tv under a year old,call for warrenty or newer than that take back where u buy it and exchange for another tv.
Dec 28, 2010 | Televison & Video
I just bought a sony kdl40ex400, 40" lcd tv and when i first turned it on the picture quality was poor and there are 2 vertical blue bars running down the screen at all times how do i fix this
The tv Tuner signal board is bad,must be replaced.This tv is new,bought it,under a year old?So this tv is still under warrenty.Call Sony for a warrenty repair.
Oct 16, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
I have a 46' lcd sanyo... we have sound but no picture...and the off and on button keeps flashing...hadnt had any problems until now...how can i fix this..we havent had the tv 7 mths yet??
The tv less than a year old?Call the hot line in the owner manual for warrenty repair.The tv Tuner board have pronlems,that the board,where the coalaxial broscasting signal cable plug into it.
Jul 16, 2010 | Sanyo DP46849 46 in. HDTV
Our RCA 32 inch TV L32HD35D has sound but the picture has a pulsating white screen---no picture. We have only had the TV since approximately May 2009. Is there a way to fix the problem? Thank you Susan J....
No,Ur tv under a year old?Still under warrenty?Call RCA for warrenty repair.This problems is a major problems for the tv.The Tuner board it dead,must be replaced it cost u at lest $200 for a refurbish Tuner board.And u have to do the labors ur self.
Apr 25, 2010 | RCA L32HD35D 31.5 in. LCD HDTV
I have 46 inch toshiba LCD Tv & i've had it on since 12pm its only like 1 year old & at like 1240am i turned to look at it & the screen was black but i could hear sound only & none of the...
Ur LCD inverter board is dead.Replaced this board u will get ur picture back.It a long board.Tries Shopjimmy.com,Ebay.com to buy this board part.
Feb 12, 2010 | Televison & Video
Tv sony 46 inch colored blurry..and picture is bowed
This problem is due to failure of two convergence out ICs in TV that will be replaced to get correct picture.
If you can solder parts in circuit board and have necessary tools to do so, let me know exact model of TV to provide you more technical info or call local TV tech to replace convergence out chips.
Thanks.
Oct 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
46" screen with an <8 x 11 picture!
you should contact samsung and inquire as to poss.warranty defects of this item
Aug 23, 2008 | Samsung HLN467W 46" Rear Projection HDTV
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
