Question about Browning Diana Grade Spreader, 12 Ga
Diana 35 air rifle repair
I need to know how to replace the main spring of my beloved Diana 35 air rifle (I already have the corresponding spare part).
Hi, sorry can't really help with you quastion, but I got a quastion my self, where can I buy the spring from for diana35? thanks
galaxyjohn300@yahoo.com
Posted on Oct 29, 2012
Rifle will not fire,side bar rod and cover broke long time ago,i threaded a 3/16 rod iwas able to crank it back loaded it but it will not fire.
  • Get the proper spares for it. You know it has a safety?
  • DIANA ORIGINAL : Model 48 & 52 - Airgun Spares www.airgunspares.com/store/category/64/791/DIANA-ORIGINAL/Model-48... Diana/Original Piston Seal. Fits Models: 34, 36, 38, 46, 46E, 48, Stutzen, 300R, TO5, P31, 66, 75 & Remington Express
  • Diana/Original - Airgun spares ' Chambers Gunmakers ... https://www.gunspares.co.uk/categories/24035/DianaOriginal ... Shotgun & Rifle spares. HOME ' CATEGORIES. Airgun spares; ... Diana/Original - Airgun spares. Please select the MODEL you require`
  • RWS Parts. Diana RWS Air Guns, RWS Air Rifles and ... www.pyramydair.com/m/RWS-Parts/44/73 RWS Parts. We carry Diana RWS Air ... You must be 18 years or older to buy any air gun or air rifle in our ... (T01) Model number 30223000. Umarex: RWS. Starting at ...
  • May 01, 2016 | Optics
    How do i mount my 650 laser sight to my bone collector rifle.
    Red Laser Sight 650nm Weaver rail mount - Gamo USA
    www.gamousa.com > Optics > Airgun Lasers and Lights
    650nm Red Laser Sight with Weaver style rail mount.
    Gamo airgun accessories, spare parts and products ' Gamo ...
    www.gamousa.com/category.aspx?catID=4
    Air Rifle Scope Mounts/Rails. Air Rifle Scope Mounts/Rails. Air Rifle Sights. Replaceable sights for air rifles. Air Rifle Spare Parts. Replaceable parts for air rifles.
    Dec 25, 2015 | Laser Optics
    Diana scope 3-9x 40 AO - I need a parts diagram and how to find spare parts to it. In a 'just in case mode' (Magnum airgun recoil) what spare parts should I have to this scope?
    Hi Marcos
    You will probably not find any spare parts for the scope, unless you will write or contact the manufacturer of the scope.
    I do not recommend that you repair the scope yourself, as it has to be reinstalled properly and also most are nitrogen filled to stop fogging of the lenses.
    Make sure you only use a scope that is designed for an air rifle, because the spring pushes and pulls the gun when it fires and it has to have the "air rifle" scope to handle the double recoil if not you will break the reticles of the regular gun scope.
    Bud
    Oct 18, 2013 | Garden
    Cocking assembly
    First establish a source for replacement parts, otherwise there is no point to mess with the air rifle.
    Also by your description, I am not sure if the main spring is fully cocked or not at this point ?
    If you are not sure about it continue cautiously.
    Second (if you are mechanically inclined) start to take the rifle apart.
    Remember that the danger is in the in the main powered spring.
    Taking screws out is fairly safe, pins on the other hand should be done cautiously, they usually hold back some sort of force.
    Pushing out any pins that hold assemblies together should be done with a smaller diameter pin than the one you attempting to push out. The pusher pin should go in loose, but if spring tension is present it will stick and keep things from exploding on you.
    If the push pin gets stuck you will know there is spring tension that needs to be released.
    Putting pressure on the right component or spot will free your pusher pin and allow you to release compression in a controlled and safe manor.
    At this point you can just identify the parts that look broken or excessively worn and replace them.
    Good Luck
    Aug 24, 2013 | Umarex Air Ruger Air Hawk Air Rifle .177...
    Replace main spring in RWS
    hello friends you broke my rifle spring my rifle crosman optimus ea .177 cal. and the dealer put a new one, but it has presicion not know if I should wait for 500 shots or more like new or will be another problem, thanks for your help
    Oct 08, 2012 | RWS Diana 34P air rifle - 0.177 Caliber
    How to repair a ruger air hawk .177
    well for starters, there is no firing pin, second, without major machinery, you can't fix a spring powered air rifle, any of them. It is impossible, major jigs and fixtures hold these things while the spring is removed and replaced. You might try crossman, they do a lot of repairs.
    Jul 30, 2012 | Umarex Air Ruger Air Hawk Air Rifle .177...
    Repair beeman rs2 broken spring
    My stupis Beeman RS2 dual-caliber Air rifle combo trigger broke for no reason and I cant find a replacement can someone help me?
    May 29, 2012 | Beeman RS2 Dual-Caliber Air Rifle Combo...
    How do i change my benjamin air rifle pump seal?
    pyramidair.com has a seal kit. it also comes with a diagram. Benjamin and Sheridan air rifles do not have springs to propel the pellet. also never use vasalin. specifically for a Benjamin or Sheridan you need to use pelgun oil (also found at pyramideair.com). use pelgun oil because it is a non detergent fossil compound) the main intention is to condition the seals every 250 rounds. never use silicon based lube for this gun specifically. silicone lube is for spring air rifles such as break barrels.
    Nov 23, 2010 | Dmm Benjamin Air Rifle
    Gun trouble!
    i wrote them a nasty letter once on a new pump air gun i returned twice and told them i would never buy from them again. they apologized and sent me a letter and hope that i would do bussiness with them in the future. that spring should not break that easy or in 3 places!. try writing them to replace it and if not tell them you will expose the quality of this gun on you tube.
    Apr 05, 2010 | Crosman ® Quest cal. Air Rifle with 4x32...
    Browning Diana Grade Spreader, 12 Ga Logo
    1,818 people viewed this question
    Top Browning Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
    Are you a Browning Garden Expert? Answer questions, earn points and help others
