Question about Riccar R1570 Mechanical Sewing Machine
Where to buy riccar sewing machine spare parts in the philippines or philippines dealer
WonderTech
  • 268 Answers
SOURCE: i have an older machine - Riccar 3600 -- and the
Here are some things to try.
If it's Your upper thread breaking:
* Rethread your machine
An incorrectly threaded machine can cause thread to break.
* Decrease the tension on your machine
The tension may be too tight for your thread.
* Reposition the spool of thread on the spindle
You know that little nick in the edge of a spool that’s used to hold the loose end of the thread? Your thread may be catching on this nick as you sew. Place your spool so that this nick rests against the bottom of the spindle.
* Reinsert your needle
Make sure it goes all the way into the holder and that it’s positioned correctly, usually with the flat side away from the bobbin, but consult your machine’s manual to be sure.
* Change your needle
Your needle may be bent or dull. The eye of your needle may have a nick in it that’s cutting the thread as you sew. Or your needle may be too small for the thread you’re using, in which case, change to a larger needle. And make sure your needle is appropriate for the weight and type of your fabric.
* Change your thread
Your thread may be weak. Or your thread may be fuzzy and irregular, causing it to catch in the eye of your needle as you sew. Cheap thread tends to be weak and fuzzy, so make sure to
use a quality, brand name thread. And if you’ve been sewing with an older cotton thread, which can dry out and become brittle with age, try a newer thread.
* Check your presser foot for damage to the needle hole
A burr in your presser foot’s needle hole may be cutting your thread. Gently smooth any rough spot you find with an emery cloth.
* There may be a burr in one of your thread guides, in which case, you may need to have your
machine professionally serviced to have the part replaced.
If it's Your lower thread breaking:
* Reinsert your bobbin
Your bobbin may not be seated properly in its case.
* Rethread your bobbin
Your bobbin may be threaded incorrectly or the thread may be tangled.
* Remove some of the thread from your bobbin
If your bobbin is very full (if it’s hard to insert into the case, it’s too full), this may be keeping your bobbin from turning smoothly.
* Rewind your bobbin thread
If your bobbin thread is wound unevenly, this may be keeping your bobbin from turning
smoothly.
* Try a new bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
* Clean the lint from your bobbin case
Lint in your bobbin case could be keeping your bobbin from working properly.
* Check the needle hole in your throat plate for rough spots
A burr in the needle hole of your throat plate, usually caused by the needle hitting the throat plate, could be cutting your thread. Gently smooth any rough spot you find with an emery cloth.
I hope one of these solutions work for you.
Posted on Sep 15, 2009
  • 718 Answers
SOURCE: Broken Cam
You can try;
http://www.a1sewingmachine.com/parts.html
Email your parts request to them.
Or you can contact your local dealer.
You can get an owner's manual from;
http://www.riccar.com/help/manuals
Posted on Mar 28, 2009
  • 47 Answers
SOURCE: wanted a user manual for a RICCAR reliant 505
Www.ifixmachine.com has lots of manuals and parts for a cheaper price
Posted on Jul 23, 2009
  • 255 Answers
SOURCE: riccar sewing machine keeps breaking thread
Oh yes. GRRRRRR is the word!!! I hope I can help.
In many cases, breaking thread is caused by the upper tension being too tight, so that's something to check.
Another thing is to change your needle. If it's at all bent it can break the thread.
Third thing is to make sure you're using new, high quality thread. Older thread breaks more easily, especially if it's been in the sun.
Finally, clean and oil the machine. A bit of lint in the bobbin area can do all kinds of havoc.
Hope this helps!!
Posted on Jan 19, 2010
  • 1788 Answers
SOURCE: Looking for Riccar sewing machine manual
you can get the manual by goggling Riccar 1570 manual for free. It will download, no problem
Posted on Jul 26, 2010
Is there a dressmaker sewing machine with the model no. 777?
In the 1960's, Riccar made a heavy duty 777 sewing machine. Riccar made machines into the 1970's. The headquarters appears to have been in Chicago before it moved offshore. Value of the machine? Maybe $100 if it worked. Parts might be found or salvaged from machines used for parts. However, here is a Riccar shop in South Carolina:
Riccar Sewing Machines Charleston SC
Riccar Home Sewing Machine Parts www drdanessmh com
The Riccar Sewing Machine Story
RICCAR 777 SEWING MACHINE CAMS CASEEXC
I would be doubtful regarding offers of a manual for sale for this online unless at minimum it was attached to a brick and mortar store in business (and even then might query the local Better Business Bureau).
Sep 14, 2017 | Sewing Machines
Riccar RL924DR
I looked at Riccar's site and didn't see that model number. Please feel free to check
http://www.riccar.com/help/manuals/
Otherwise contact Riccar and see if they can send you one.
Aug 14, 2012 | Sewing Machines
Where can i buy parts of singer sewing machine in the philippines
try this website, www.sewingpartsonline.com, this is a USA site though, don't buy electrical items such as foot controls or cables if your country has 240 Voltage.
Or go to Singer direct, the world Singer website shows this link for Phillipines,
http://www.singerphilippines.com/
It shows the company below as the Singer distributor, they should be able to help you.
MONTEVERDE MARKETING
1870 ABAD SANTOS ST, STA CRUZ, MANILA
AUTHORIZED PHILIPPINES DEALER
TEL 362.0712 / FAX 365.5867 / EMAIL singerphilippines @ yahoo.com
Aug 24, 2011 | Sewing Machines
Looking for hook gear for riccar eatons viking ezb 108798 and repair manual. my bobbin hook wiil not move
The gear is #53741 and is available at most sewing dealers. The part is also available wholesale at sewing machine services in Canada. Also fits riccar, eatons and babylock machines, so a babylock dealer could help. You will have to beg a repair book or photocopy same to ger mounting and setting instructions. We charge about 60 to install and time the part ONLY.
Derek
Jan 16, 2011 | Riccar Sewing Machines
Need parts/manual for old Riccar sewing machine
Here's a manual for the 551, it should be similar enough for your machine.
http://www.riccar.com/ftp/whitepapers/551-Owners-Manual.pdf
If not look on www.riccar.com/help/manuals for a similar model.
Find out what shank your machine is and you should be able to buy parts for it. I find ebay great for old sewing machine parts.
Hope this helps!
Jul 18, 2010 | Riccar R552
I have a riccar 600 that has a cracked upper gear. Can you supply this. What is the cost?
You will have a devil of a job getting any spare parts for Riccar
Feb 24, 2010 | Sewing Machines
Broken Cam
You can try;
Mar 28, 2009 | Riccar Sewing Machines
Riccar galaxy 300 sewing machine
I have a working motor from a Riccar Galaxy sewing machine you can have for free.
Apr 03, 2008 | Sewing Machines
Sewing Machines Logo
99 people viewed this question
Top Riccar Sewing Machines Experts
Tally Girl
Tally Girl
Joseph Mueller
Joseph Mueller
Are you a Riccar Sewing Machine Expert? Answer questions, earn points and help others
