Trouble shooting Samsung HLN437W DLP
Question! My picture and sound both went out at the same time on my Samsung HLN437W yesterday, plus I had the 3 blinking lights. I took out the lamp carrier and checked it out and put it back in and picture and sound came back on, but later did the same thing again. It has 16,437 hrs on the orig. bulb and before I order a new one Monday, is it just the bulb or is there more going on then the bulb. I not sure if the sound also goes out when the bulb does?
  • 1 more comment
  • Anonymous Feb 20, 2009
    I try to power on my samsung dlp hln5065w. It cycles and tries to power up but won't turn on. It does this two or three times, and then shuts down with the three lights on the front of the set flashing. I've tried resets, a new bulb, neither of which worked
  • sammyVe Feb 24, 2009
    I have the same problem, I have had the Tv for 5 years samsung 61 dlp I have replaced the bulb 3 times and now the color wheel is humming. This is the biggest piece of **** I have ever purchased. I ordered and new color wheel and now the bulb is out again.
  • coolpairpl May 14, 2009
    I try to power on my samsung HLR617W, the lights on the front flash, Lamp flashes in green, Timer flashes in green and standby temp flashes in red. What problem does this indicate?
    Thanks
    Problem Solver:
  • 17 Answers
1. If the 3 LED indicators flicker from the time the set is
turned on, it means:
1) The CN106 connector on the DMD board is not inserted
properly.
2) The MDR cable that connects the DIGITAL board to the
DMD board is not connected properly.
3) If the lamp does not turn on even after turning it on three
times, by powering off/on 15 second intervals:
! The B+ 380V power is not supplied to the ballast
(The cable is not connected properly between the power
and the ballast.)
@ The cable connected to the CN110 terminal on the
DMD board and the CN2 terminal on the ballast is shortcircuited
or not connected.
# The lamp does not turn on because 5V has not been
supplied to blue pin #1 on the CN2 terminal of the
ballast.
$ 5V is supplied to the CN2 terminal on the ballast but the
lamp does not turn on because the ballast has a failure.
(If the lamp is replaced and 5V is supplied normally to
the CN2 terminal, suspect a ballast failure if the lamp still
does not turn on.)
% The ballast is normal but the lamp doest not turn on.
(When 5V is supplied to CN2 and 385V to CN1, but the
lamp does not turn on, try replacing the lamp. If it turns
on, that means it was a lamp failure.)
4) The color wheel engaged to the engine does not operate,
or the connector which indicates the operation of the
color wheel is not connected properly, and therefore
does not allow the lamp to turn on. The cause can be
determined when the set still does not turn on after
attempting to turn it on three times.
5) Another digital board or the DMD board has a failure.
Conclusively, if the three LED indicators flicker, first
check the above five items, then check the various
connector connections, and then suspect a failure of the
lamp or the ballast.
Posted on Jun 27, 2009
I have sangsun DLP with many point in all picture how canI resolv problem?
Posted on Feb 10, 2009
  • douglas400 Feb 10, 2009
SOURCE:
No sound, just clicking noise
Is your TV a SAMSUNG DLP TV Model HLN437W Rear Projection Digital HD?
If so I found a TROUBLESHOOTING GUIDE @
http://support-us.samsung.com/cyber/popup/pop_troubleshooting.jsp?ia_cd=02010300&model_name=HLN437W
A probably INTERACTIVE ONLINE SERVICE REQUEST FORM @
http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
PHONE #S FOR SAMSUNG:
mobile phones: 1-888-987-HELP(4357)
  • Mon - Fri : 7am - 9pm (CST)
  • Sat : 9am - 6pm (CST)
digital HDTVs: 1-800-SAMSUNG (1-800-726-7864)
  • Mon - Sun : 9am - Midnight (EST)
printers: 1-800-SAMSUNG(726-7864)
  • Mon - Sun : 24hrs
IT Products for Business: 1-866-SAM4BIZ(726-4249)
  • Mon - Fri : 9am - 9pm (EST)
All other products: 1-800-samsung (1-800-726-7864)
  • Mon - Sun : 9am - 9pm (EST)
To see PHOTOS of REPLACING a SAMSUNG DLP TV ballast go to:
http://forum.doityourself.com/electrical-c-d-c/248376-testing-ballast.html
Hope this is helpful.
Good Luck!
Jack iaria
Nov 25, 2008 | Samsung HLN437W 43" Rear Projection HDTV
Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Mar 26, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Sound but no picture
Need to replace the lamp, samsung p/n# Bp96-00224a or if you're a bit more budget wise and fairly handy you could get just the bulb and instll it into the lamp holder yourself and save some bucks. The trick to this is try not to handle the lamp with your bare hands installing it, use some rubber or nitrile gloves.
We buy just the lamps from DLP Lamp Source http://www.dlplampsource.com/?gclid=COG23pben5ACFScXagodE3YR7A
Bill
Dec 11, 2007 | Samsung HLN437W 43" Rear Projection HDTV
Televison & Video Logo
1,507 people viewed this question
Top Televison & Video Experts
Ekse
