Question about Maytag 7.0 Cu. Ft. Electric Dryer
How to run the drive belt over the pulleys on Maytag dryer
Delt Diagram
  • 490 Answers
Posted on Apr 17, 2009
What sound does a dryer drum belt make when it is going bad?
screech screech
But it would be more the pulley bearing that would be the one to worry about. The belt will simply snap when worn out.
See this diagram and parts list
http://www.appliancepartspros.com/06-motor-drive-parts-for-maytag-lde8604acl.html
Aug 28, 2014 | Maytag Dryers
Trying to replace the dryer belt forgot how the old one came off b/c it broke. not sure how to get it back on to the pullys. maytag dryer model de7600.
This link is a listing of diagrams of belt configuration on various brand dryers the diagram for how the belt goes on the motor/idler pulley on the Maytag brand is going to be diagram E
http://www.repairclinic.com/Dryer-Belt-Diagrams#DiagramE
GENE
Aug 31, 2011 | Maytag Dryers
I need the diagram of the drive belt and how it goes around the drive shaft and pulley
Thank for the great rating and I hope by now you are running again...
hewatman101
Sep 15, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Model: maytag LDE9606ACE reinstall belt
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, look for the "Dryer Belt Diagrams" link under the "Special Features" section. Refer to Diagram E for a Maytag dryer. If you have questions, please let me know. I hope this helps you.
Sep 25, 2009 | Dryers
Maytag electric dryer belt repacement how to do it yourself
Below are some links provided by www.repairclinic.com, that may assist you. Depending on the model of your dryer, this may be a simple DIY job.
1. Belt /Pulley diagram.
http://www.affordableappliance.com/Tips/beltdiagrams.htm
2. Parts breakdown/disassembly procedures.
http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
3. Belt image page.
http://www.repairclinic.com/SSPartDetail.aspx?s=b4i529597&PartID=529597
Aug 25, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Performa PYE G2200 gas dryer, the dryer seems to turn on but the drum will not turn.
Based on the information provided, it sounds like a broken drum belt is at fault. Below is an illustration of the drum belt.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-PYG2200+-%3d%3di529597&PartID=529597
Here is a parts/disassembly diagram:
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
Here is a belt installation diagram:
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
All links courtesy of www.repairclinic.com
Aug 16, 2009 | Maytag Dryers
Dryer belt routing on Maytag dryer model MDET236AYW
With the drum removed, loop the belt around the drive motor an run both strands of the belt under the tension pulley. You have to be carefull on getting the drum back in place while working the belt back on a LITTLE AT A TIME. Once installed verify the belt is not caught on anything and you should be good to go.
Mark
May 21, 2009 | Maytag Dryers
How do I install the belt on a maytag med5840TW0
All you have to do is tilt the machine back and look under the machine and the pulleys should be exposed. next just roll the belt onto the pulleys
Feb 09, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Need routing diagram of dryer belt on maytag dryer D7600
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, locate the "Dryer Belt Diagrams" link under the "Special Features" section. Scroll down to Maytag. The dryer belt diagram for Maytag should be listed as diagram E. I hope this helps you.
Jan 28, 2009 | Maytag PYE2300AY Electric Dryer
The Maytag Dryer MED5570TQ0
Hi lesterjabbow;
A lot of these dryers have a long fiber belt that runs from a pulley on the motor thru a tension idler pulley and goes all around the drum. I suspect this belt is either broken or has come off the drive pulley on the motor. You can remove the back of the dryer easily with a 1/4 or 5/16 nut driver and immediately see if the drive belt is good. Any Maytag dealer will have a replacement part and it is easy to install
Hope this helps Good Luck Loringh PS Please leave a ranking if appropriate Thanks
Nov 22, 2008 | Maytag MED5770TQ Electric Commercial Dryer
Maytag 7.0 Cu. Ft. Electric Dryer Logo
131 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
