Blank screen on my laptop but power button is on.
I have a acer2420 travelmate and when i switchjed it on this evening.the screen was blank but the power button lit up.can you please give me a solution as to what happened and what to do?
  • aruna_2388 Apr 17, 2009
    thankyou justin..
    i tried to connect it to an external monitor but it isnt working the desktop monitor to which i tried to connect was also blank.
  • 36 Answers
Depending on what kind of laptop you have, your button may look different. Look at the Function keys (all those keys up at the top that have F's in front of them) and see if there is another colored symbol on any of them. You should find a colored symbol that looks like a rectangular monitor.
Press another key toward the bottom of your keyboard that probably says "Fn" or some other kind of "Function" key - not Alt, Ctrl, or Shift. Hold that Fn key down while you press the first key you found that looks like a monitor. That will change your laptop video output mode between several different modes like: laptop LCD panel only; LCD panel and external monitor; and external monitor only.
The purpose of this is if you wanted to plug another monitor into the back of your laptop, or a projector for a meeting or presentation, etc.
Posted on Apr 17, 2009
  • Justin
    Justin Apr 17, 2009
    Another thing you could check is make sure the button or trigger that gets pressed down when you close the lid isn't stuck down.
Acer 4320 Screen turn blank when it load Windows.
press fn button and with up-arrow increase brightness ,,, in windows open display settings by right clicking on the desktop (intel or nvidia properties ) acer 4320 could have nvidia or intel ... increase the brightness and the contrast or load the default settings ,,, use external monitor if need ...
Mar 07, 2012 | Acer TravelMate 4320 Notebook
My acer travelmate 4100 will not power up when I switch on. The green power button is lit but the screen is blank and and there is none of the normal "booting up" noises it's just silence :-( I have tried...
hi michelle, first check to see if you can even get to your BIOS. if that is not posible then you might have either a power supply or motherboard issue. for either one of those you will need to send for repair.
Aug 11, 2010 | Acer TravelMate 4100 Notebook
Blank screen although power light on and fan running.
Please force shut down the unit if it still is on. Then, press the power button and see if it starts up.
If that doesn't work, then please disconnect everything from the unit (Battery and A/C) and Reseat the RAM and recheck.
May 22, 2010 | Acer TravelMate 2300 Notebook
ACER TRAVEL MATE 2480 WILL POWER ON BUT SCREEN REMAINS BLANK.
look close to the screen and see if there is a faint picture. if there is then read below for the issues and solutions that can cause this problem.
Issue 1: Lid button sticking
this is a common issue with this model that the lid button sticks closed. fiddle with it to see if it opens and the light comes on.
issue 2: Inverter for the monitor is bad
this is not to uncommon an issue when this problems shows itself. Laptops monitors light up with a fluorescent bulb. This is powered by an inverter. These can go bad and if they do the light will not turn on. you need to take this to a service station. i don't recommend trying to replace without knowledge of this. They are high powered and you can hurt yourself or damage the screen
issue 3: fluorescent bulb went bad
this is usually the least common but could have happened. usually happens when peopel spray their screen with cleaner and it drips down inside the bottom. This can be fixed by a service center but coudl get costly. best bet is buy a new screen.
Feb 11, 2010 | Acer TravelMate 2480 Notebook
7720 Travelmate turned off and startet again only once
Try without battery.
If it set the problem, let me know
Check power supply if green led lights up
if not try other power supply if yes
Tell me if you ear or see anything on the screen.
Sep 08, 2009 | Acer TravelMate 5520 Notebook
Blank screen
Seems like the connection might not be setup correctly inside the laptop. Check for bent pins for where the lcd screen connects to the motherboard, and also make sure any "ground" screws are in like they were if there are any.
Mar 20, 2009 | Acer Ferrari 4000 Notebook
Blank display screen after system restore, i restored my acer 1660 travelmate and i now have a blank screen and the key board will not work.
while it is powered up, push and hold the fn key, then hit the f5 key. if that does not help,push and HOLD the power button down for 60 seconds this should reset the unit.also how did you find out keyboard is not functional? i know alot about the 5100 series,have 2 that broke after warranty was up. and had 2 repair them myself.i hope this helps you, ask i you need more help.good luck.
Mar 03, 2009 | Acer Aspire 5100 Notebook
Acer 23001LC
A temporary Swap with a Working Ram Module should help further pin point the failed component..
Mar 02, 2008 | Acer TravelMate 2300 Notebook
Help to repair ACER Travelmate 290LCi
this is normally motherboard or powe side problem check your motherboard
Oct 19, 2007 | Acer TravelMate 290LCi Notebook
Computers & Internet Logo
David Payne
David Payne
