Question about HP Laserjet Cp2025n Printer
New HP CP2025 printer prints "ghost" DVD circles between labels
New HP CP2025 printer prints "ghost" DVD circles between actual label prints. I'm using Memorex vinyl coated DVD labels. My HP 2600n had little problem with this. I'm using Memorex's Expressit software to print labels. Thanks, MaryD
    Problem Solver:
  • 9 Answers
Hi, i work for a company who is the dealar of hp products.
you have to do a clean service of your hp printer.
after that the printer should not have ghost print any more.
Posted on Apr 17, 2009
E260 will not print labels
This printer has capability to print on labels. Here are some tips when printing on labels:
· Use labels designed specifically for laser printers. Check with the manufacturer or vendor to verify that the labels can withstand temperatures up to 210°C (410°F) without sealing, excessive curling, wrinkling, or releasing hazardous emissions.
· Labels can be printed at a higher fusing temperature up to 220°C (428°F) if Label Weight is set to Heavy.
· Select this setting using the Embedded Web Server, or from the printer control panel Paper menu. Label adhesives, face sheet (printable stock), and topcoats can withstand up to 25-psi (172-kPa) pressure without delaminating, oozing around the edges, or releasing hazardous fumes.
· Do not use labels with slick backing material.
· Use full label sheets. Partial sheets may cause labels to peel off during printing, resulting in a jam. Partial sheets also contaminate the printer and the cartridge with adhesive, and could void the printer and cartridge warranties.
· Do not use labels with exposed adhesive.
· Do not print within 1 mm (0.04 in.) of the edge of the label, of the perforations, or between die-cuts of the label.
· Be sure adhesive backing does not reach to the sheet edge. Zone coating of the adhesive at least 1 mm (0.04 in.) away from edges is recommended. Adhesive material contaminates the printer and could void the warranty.
· If zone coating of the adhesive is not possible, remove a 2-mm (0.06-in.) strip on the leading and driver edge, and use a non-oozing adhesive.
· Portrait orientation works best, especially when printing bar codes.
· Use only paper label sheets. Vinyl, pharmacy, and dual-sided labels are not supported.
For further assistance, please contact Lexmark Technical Support.
Mar 04, 2011 | Lexmark E260dn Laser Printer
My 2600n is ghosting when printing black and labels are not printing correctly, the ink does not stick to the label, any ideas?
Sounds like a fuser problem.
Check the hp website, there was a firmware upgrade for fixing problems.
This may help, but you may also have a more involved problem...
Check print out on plain paper, and print the configuration page.
Dec 18, 2009 | HP Color LaserJet 2600n Printer
How do I print a label on a cd/dvd
your printer does not support CD label orinting. though you can still print CD labels but with some softwares. there are HP printers that prints CD labels. Check them out.
HP Lightscribe
Use LightScribe technology to label CDs and DVDs.
HP Photosmart D5460, D5463, D5468, and D7560 Printers - Printing Directly onto a Printable CD or DVD in HP Solution Center ...
On a computer running Windows, print directly onto a CD or DVD using the HP Solution Center software.
HP Photosmart Premium C309a, C309c, C309g, and C309n All-in-One Printers - Printing Directly onto a CD or DVD - c01622666
Review steps for printing directly to a CD or DVD.
HP Deskjet 900C series printers - CD Label.
These printers comes with a special software that enables them print on CD labels. Also try to get their softwares and see if you can interface them with your own printer and them print. Else you may have to get one of these printers that support CD labelling. Cheers!
May 19, 2009 | HP OfficeJet 4255 All-In-One InkJet...
HP Color LaserJet 2600n toner problems
In speaking with other tech support people it appears my image drum needs to be replaced. Also sounds like it will be more economical to buy a new printer.
Feb 19, 2009 | HP Color LaserJet 2600n Printer
Printing CD labels , can not get it to line up stright.
I have the exact problem with my HP Deskjet D2360...Done all adjustments, doesn't print in the outline of the label...help
Nov 09, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP C5580 print settings
Hey! I found this in a review site (can't remember)
"If you use Nero 7 Essentials to print CD/DVD labels, make sure you print just the page for the disc, and under print setup make sure you have CD/DVD 120mm under size and CD/DVD tray from source, then under Preferences set your calibration to -0.185" horizontal, -0.182" vertical, and you'll be golden."
I hope it helps!!
Nov 07, 2008 | Office Equipment & Supplies
Extra background color in my printing
You really should not run labels through this machine unless they are full sheets. If you are running used pages the glue will build up on the tranfer belt and cause the hazing.
Jul 28, 2008 | HP Color LaserJet 2600n Printer
Cd/dvd label printing
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786157&lc=en&cc=us&dlc=en&product=1153481
Nov 15, 2007 | HP Photosmart C5180 All-In-One InkJet...
HP Laserjet Cp2025n Printer Logo
740 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
