Question about Garden
Gas mixture in Leaf Blower?
I have a Lesco LBB-4200 and I am unsure as to what type of fuel it takes. Is it a mixture or straight gas?
  • 35 Answers
The 4200 gas backpack leaf blower requires 50:1, 2 cycle oil mixed in the gasoline
Posted on Apr 17, 2009
Required fuel oil mix
Two-stroke oil with a 50:1 (Gas:Oil) mix ratio is required for the Husqvarna 125B leaf blower. Using the wrong oil or improper mixture ratio can drastically affect the performance of the leaf blower.
Nov 02, 2012 | Husqvarna Hand Held Blower 125 B Grass...
Gas and oil mixed in 4 cycle backpack leaf blower
If it is a 4 cycle blower, you do not mix oil with the fuel....It takes straight Gas. there is an oil cap to put engine oil in crankcase, this only usually takes 2,3,4 oz. of oil. Sounds like your Spark Plug probably fouled out from having oil mixed in your gas. I would recomend changing your Spark Plug and put some Fresh GAS only in the blower, dump the old stuff out !!! You should be on your way Blowing in No Time !
Nov 27, 2011 | Troy-Bilt 32cc 4Cycle Backpack Blower
Where do you put the oil in a fradan honda 8HP leaf blower?
you will need to check the owners manul to see where and what type of oil it takes or if it takes mixed oil and gas and then there should be a gas/oil mixture ratio you will need.
May 06, 2011 | Honda Garden
Will not stay running act like it runnig out gas? and in back the motor real wet too. it a 450cxl poulan
The wetness, does it smell like the gas mixture. If so, one of the gas lines most likely has a crack keeping the gas from flowing to the carb which makes it quit running. When you prime the blower, this is when it will run for only a few seconds? This is because the primer bulb is taking gas and shooting it straight to the carb.
May 03, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Mb 3200 gas leaf blower will start when choke
The carburetor could need rebuilding or you have some bad gas. I would mix up some 2 cycle oil and fresh gas from the station. I would try the new fuel mixture first.
Good Day.
Nov 02, 2009 | McCulloch 26cc Gas Blower Mcb3208
Poulan wild thing leaf blower won`t start. Has
SOUNDS LIKE YOU SHULD GET YOU A NEW ONE ITS CHEPER TO GET A NEW ONE
Sep 30, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
I nww=eed to know the fuel mixture for my homelite gas blower
If you ran plain gas in a 2-cycle engine and it seized... you need to buy a new one. 2-cycle engines depend on oil in the gas for lubrication. If you run straight gas, there is no lubrication, the engines overheats and seizes. The end, unfortunately.
May 25, 2009 | Mtd #TB4SC 25CC 4-Cycle Gas Blower
My homelite yardbroom 2 won't start. Maybe wrong gas/oil mix
Hi
If you remove the fuel you believe to be the mixture out of the fuel tank and refuel with the correct mixture then remove the air filter. Put a few drops of the correct mixture in to the intake it should start. it may take a few times of repetting putting the fuel in to the intake, but eventually it will clean out the bad fuel and run good.Remember to replace the air filter!
Apr 24, 2009 | Homelite 'Yard Broom' Leaf Blower
Fuel mixture for 32 CC McCulloch leaf blower
Gas to Oil ratio is 40 to 1. (40:1)
Oct 12, 2008 | Garden
Garden Logo
549 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
