Question about Compaq Armada M700 Notebook
Battery fully charged, or is it.
I had a look around and most people are having problems with thier laptops just not booting up at all, well, not me, thats on the 1ghz m700 which i soon gave up on. my problem at the moment is on my 700mhz m700 which is refusing to give me anything from the battery. according to my pc i have a fully charged battery and according to a piece of software i use called mobmeter my battery has no wear. yet my pc wont give me a light of any sort without having the mains connected, and then if i unplug the mains during use it instantly blacks out. any ideas? thanks adam
  • blunty86 Sep 17, 2007
    excellent thanks for the answer. i feared as much just didnt want it to be right. my charger is a compaq charger. not entirely sure if it came with the laptop or not but deffinatly compaq. battery looks fine, the only reason i thought it might not be the battery is because everything seemed to check out.
    Do you have a guide on how to build your own battery? it just so happens im a sound technician so pretty dab handed with a soldering iron.
    Thanks again
    Adam
  • 150 Answers
Good Day Blunty, It's one of two things, the more likely of the two is that that battery is totaly shot, laptop battery's are usually only good for 1.5 years then loose there ability to retain a charge. It sounds like that one's just done. Unfortunatly that those batterys cost more than there worth, 100 bucks or more. The second possibility is the power cord, is that the original power cord for that? Or was on that was bought aftermaket, some aftermarket chargers will only power your laptop and not charge. Also remove the battery and check for corrison. You can build your own battery fot a a laptop if got a few hours time, and are good with a soldering gun. You get the litium ion cells you need for about 40 bucks. Good Luck L8R
Posted on Sep 17, 2007
  • Anonymous Sep 17, 2007
    Follow the below link for a step by step on how to build your own battery
    http://www.metacafe.com/watch/479447/lap...
SOURCE:
When a compaq armada m700 laptop is showing non-system disk or disk error replace and strike any key when ready
this usually happens when the computer is trying to boot from a disk that isn't a valid boot disk.
if you have a floppy drive plugged into the multibay and a floppy in the drive, try removing the floppy.
if there is no floppy involved, try to boot from your system recovery disks, as it's likely that the boot record on the hard drive will need repaired. your system recovery disks should walk you through the process.
Nov 03, 2011 | Compaq Armada M700 Notebook
Error reading hard drive laptop Armada M700
It's sadly possible your hard drive is bad or corrupted. Can you boot from a CD? Or a floppy disk? You could run diagnostics on it from a CD. If you don't have one available check the HP website for support.
Sep 24, 2008 | Compaq Armada M700 Notebook
Error messages
You may want to make sure it is the right type, this laptop take the older ide hard drive.
Sep 03, 2008 | Compaq Armada M700 Notebook
Blue screen
you have a virus on the laptop. you will need 2 take it 2 a professional to get the virus removed.
Jul 29, 2008 | Compaq Armada M700 Notebook
M700 won't work on battery anymore
This could still be a bad battery, even though the indicators and the machine are telling you that it's charging. Laptop batteries are a bit more complicated than regular batteries, they have built in fail safes in order to keep from damaging the machine if the battery malfunctions. If a fail safe has engaged due to a malfunction this could cause the problem. Start by trying a new battery. If a new battery doesn't cure it, then the problem may lie with the power management system on the motherboard.
Jul 20, 2008 | Compaq Armada M700 Notebook
Compaq armada m700 wont boot up
most of this kind of problem are located in a corrupt file or a bad sector on the hard drive that checkdisk won't repair you got two option to try. one make a backup of you files and reinstall the Operating sistem or try to fix the surface of the hard drive with an utility call "HDD regenerator" in the 70% of the cases I had it fix the problem specially in older notebooks whitout the need of reintall the OS. you will try and may be this fix your problem. (tihis utility comes in a disk called "Hiren"s" boot cd.)
Jul 18, 2008 | Compaq Armada M700 Notebook
Compaq armada m700
might have to do a windows repiar with xp cd or formatt it all install fresh copy
Jan 26, 2008 | Compaq Armada M700 Notebook
Compaq Armada M700 Shut Off During Windows XP Pro boot
remove the battery and directly connect to power and see.
Oct 09, 2007 | Compaq Armada M700 Notebook
CPU Upgrade Help Compaq M700
You might want to check this out I think it answers the questions you are asking? http://h18000.www1.hp.com/products/quickspecs/10382_na/10382_na.HTML
Sep 30, 2007 | Compaq Armada M700 Notebook
My Compac Armada M700 does not power up.
Had the same problem with My Compaq M700 No Boot Or Post. Battery Light Flashes 8 Times, Have to Wait 24 to 48 hrs sometimes longer to get Laptop to Start. Tryed the DC Converter Board Change No Difference same Problem. Noticed When Laptop Did Start Clock Time Was always a Little Off 2-4 Hours sometimes more. So Figure CMOS Problem With Time Issues. Read About Battery Memory Transitor Voltage spike Detection Issues Corrected With Newer Bios Flash at HP Supports. So I Flashed Bios With Latest 686h. During the First Boot After Reflash Battery LED Did flash No Start, After pushing the power button again it Started. And has Every since.So Far Laptop Now Boots Everytime and CMOS Checksum Seems To Keep Time Correct In Windows. The Bios Flash Corrects a Voltage Spike Detecting Transistor In The Charging Circuit. During First Start after flash Bios will run system test on the charging system and Correct CMOS. Worked for Me Hope this Helps a Few.
Oct 30, 2006 | Compaq Armada M700 Notebook
Compaq Armada M700 Notebook Logo
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
