Question about Vodavi 30-Button XTS Telephone
No dial tone with display message
We have the following display on our phone
LKD -30D V0.6H
Scout-DX V1.1 OK SYNC
We have tried to reset the main box and disconnecting the power. Any recommendation for what the problem might or how to fix it? Thanks
3 Suggested Answers
SOURCE: lkd-24d error for starplus sts
The technician had to remove the memory module as the board tried to reset itself but the memory module was corrupted and would not allow the board to reset itself. The phone were reprogrammed and are working.
Posted on May 13, 2008
slywil091
  • 112 Answers
SOURCE: power surge and now the phone is dead on screen it
take it to the shop for repair,
Posted on Jul 03, 2009
Our power went out this morning and now all phones are not working. message on display screen reads LKD-24D VO.6J SCOUT-DX V1.1 NO SYNC
sounds like you have phone service thru the internet. if so, unplug your router for 10 seconds and then plug back in. give it about 5 minutes to reset. This might do the trick?
Dec 07, 2017 | Lands Phones
LG-Nortel LDP-7024D Handset connecting to GDK100
try to check the telephone wire connections. or try to use the other phone box to test.
Sep 09, 2008 | Nortel Lands Phones
LKD-24D V0.6J SCOUT-DX V1.1 NO SYNC
If power cycling does not work, the next step would be to reinitlize the phone system. Caution, this will erase all programming and revert back to factory default. I have found over the years that the STSe Database can get corruppted and cause this display read out. If power cycling does not fix it this usu does. If it does not then there is a motherboard issue. Good Luck.
May 27, 2014 | Vodavi Starplus STSe Universal KSU 3501-01
Lg aria phone showing "LDP-7016D V1.4 SCOUT-DX V1.1 OK SYNC" same as below
Lg aria phone showing "LDP-7016D V1.4 SCOUT-DX V1.1 ...
www.faqqq.com/.../lg-aria-phone-showing-ldp-7016d-v1-4-scout-dx-v1...
Question Product: Phones Question Details: Lg aria phone showing "LDP-7016D V1.4SCOUT-DX V1.1 OK SYNC" same as below View Answers Search ...
LG Aria 130 & LDP-7016D Handset Issue - LG / Goldstar Systems ...
www.tek-tips.com/viewthread.cfm?qid=1694833
Oct 3, 2012 - I recently purchased 3 additional LDP-7016D handset for our phonesystem, but have ... System is a LG-Nortel Aria 130 running 7 handsets 1 x LDP-7024D Handset (V1.4) 6 x LDP-7016D Handsets (5 x V1.4 and 1 x V1.5)
Sep 16, 2013 | Lands Phones
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
Where can I find a free instruction manual for using an LG Aria 30D LKD phone?
The manual is available as a PowerPoint document here: www.ttgroup.biz/userguides/LG/Aria%20Handset%20UserGuide.ppt . If this direct link doesn't work, you can find the link via a Google search for the LG Aria 30D LKD manual. It came up as the third link for me.
I hope this helps.
Mar 17, 2011 | Cell Phones
How do you change time and dat on lg lkd-30d phone
Depends on what system you are using. The time is taken from the system, different systems have different programming codes.
Dec 03, 2008 | Lands Phones
Lkd-24d error for starplus sts
May 12, 2008 | Vodavi StarPlus 2706 Corded phone
Vodavi 30-Button XTS Telephone Logo
133 people viewed this question
Top Vodavi Lands Phones Experts
Oloyede Monsuru
ray gallant
vince
Are you a Vodavi Lands Phone Expert? Answer questions, earn points and help others
