Question about Quintum Tenor DX2048 (501012100) 2x10/100 Mbps Networking Switch
Setting up Call Progress Voice Announcement
How do I setup a 1 minute remaining voice announcement with the Quintum Tenor DX 2048
    Problem Solver:
  • 7 Answers
This is not possible, it is done by DTMF tones only.
Posted on Jan 06, 2008
SOURCE:
How to recover lost announcement from machine's memory
That is a shame. I also have my late wife's message on my answerphone and my sister in law and I would be sad to lose it. I heard her voice today. Phones usually have a small backup battery to keep things like announcements in the memory. It may be that your phone is old and this battery is not functioning any longer. The first thing I would do is remove it from the power, count to 10 and plug it back in.
Your manual is here
http://www.manualslib.com/manual/10386/AtAndt-1717.html#manual
AT 1717 User Manual
Jun 26, 2014 | AT&T 1717 Digital Answering Machine
Retrieveing a lost recorded announcement
contact your local sheriff's forensics unit and, they can advise you retrieval requires expertise and specialised equipment
May 07, 2014 | AT&T 1738 Digital Answering Machine
I have a LG 220 C phone and I am trying to figure out how to deactivate the announcement feature on the phone. My phone is not ringing; it is just announcing the incoming caller's phone number.
Go into the menu. Then hit '8' (calendar, alrms, etc I think?). Press '1' (voice commands). You will then get a drop list to check or uncheck regarding 'deactivate', 'announce', 'announce +ring'. Select deactivate-- now your phone will ring normal! Son had same prob on his phone-- apparently he'd hit 'announce' at some point....
Jan 27, 2011 | LG C 2200 Cellular Phone
I need to rerecord the greeting message for my phone system.
According to the instruction manual, which can be found at: http://telephones.att.com/docMgt/public/art/175/1872_manual.pdf,
TO RECORD AN ANNOUNCEMENT:
1. Press A.
2. Choose the announcement location by
pressing s until the appropriate
mailbox is displayed.
3. Press R. Begin speaking after the beep
4. When you are finished, press S.
You will hear your new announcement.
5. Repeat Steps 1-4 to record another
announcement
— OR —
Press S.
TO REVIEW YOUR ANNOUNCEMENT:
1. Press A.
2. Press s to choose the announcement
you want to review (A, B, C, AO,
MBOX 3, MBOX 4).
3. Press P to hear the selected
announcement.
Or, if you're away from the office,
CHANGING ANNOUNCEMENTS:
You can re-record any of the announcements
currently in use by any
line or mailbox.
1. Contact the answering system.
2. After two beeps press a number key
(1-4) to select a line or mailbox, then
press 4*. The system beeps and begins
recording.
3. Speak into the telephone in a normal tone
of voice.
4. Press # when you are finished. The
system beeps once and plays the new
announcement.
To review your announcement, press a
number key (1-4) to select a line or mailbox.
Press 41 after the two beeps to play
your announcement.
NOTE: If announcement is being used by
both lines, re-recording the announcement
will change the announcement heard on
both lines.
Hope this helps!
tkhusa420
Sep 25, 2009 | Lucent 1872 Corded Phone
How do you record outgoing message?
1 Prepare your announcement. Each
announcement can be up to 4 minutes long.
2 Press A.
3 Press and release S until you see
the letter of the announcement you want
to record (A, B, or O).
4 Press R. Begin speaking after you
hear the beep. Speak in a normal tone
of voice, about 9 inches from the
microphone.
5 Press S. The system plays your new
announcement. To hear the announcement
again, press P.
6 Repeat Steps 3 to 5 to record another
announcement, or press S.
To assign an announcement to play:
SELECT ANNOUNCEMENT CALLERS HEAR
1 Press and release F until the screen
displays ANNC.
2 Press and release S until the screen
displays the announcement you want
callers to hear (A, B, or O). If you
select AO, you must record an announcement,
as instructed in “Record an
Announcement.”
3 Press S to return to the message display
Jul 02, 2009 | Lands Phones
How do you set the time and date? Thanks
Hi!
First of all you need to set the Language which allows you to set the answer in either English or in Spanish voice menu mode. Once the language is set, all voice menu, including the ones used in Remote access mode, will be switched to the selected language.
1. Press and hold the STOP/SET button for two seconds, then release to access the set-up menu.
2. The answering machine announces, "For English, press NEXT, press SET to continue (in English). Para espanol, oprima PREVIO, oprima PROGRAMAR para continuar (in Spanish)".
3. Press NEXT, answerer enters English voice menu mode. If PREVIOUS is pressed, answerer enters Spanish voice menu mode. If SET is pressed, answerer remains in the current language mode. In any case, the answerer enters to the TIME/DAY menu.
NOTE: Language can only be set when the user is in physical access of the unit. When you are running in Remote Access mode, the language cannot be changed and will remain in the language you’ve previously set.10
Setting the Time/Day : This setting allows you to set the current time and day for the Time/Day stamp attached to each message.
Hour : 1. When you have completed setting the Language, the unit will enter the TIME/DAY menu. The answering system announces, "Time (the current time and day setting) To set hour, press next...press set to continue."
2. To change the hour, press and release the NEXT or PREVIOUS button and the answering system announces an hour, such as "12am, 1am, 2am," or "12am, 11pm, 10pm."
3. After choosing the hour, press and release the STOP/SET button to store the hour. The answering system enters the Minute menu.
Minutes : 1. The answering system announces, "(the current minutes setting). To set minutes, press next...press set to continue."
2. To change the minutes, press and release the NEXT or PREVIOUS button, and the answering system announces a minute such as "1, 2, 3" or "59, 58, 57."
3. After choosing the minute, press and release the STOP/SET button to store the minute. The answering system enters the Day menu.
Range of Settings
Time
Hour 12 a.m. - 11 p.m.
Minute 0 - 59
Day Sunday - Monday
Rings 2,3,4,5 toll saverto Answer
Message time 1,2,3,4, minutes
Security 0 - 9, 0 - 9, 0 - 9Code
Default Settings
Time 12 a.m. Sunday
Rings to Answer 4
Message time 2
Security Code 12311
Day
1. The answering system announces, "(the current day setting) To set day, press next...press set to continue."
2. To change the day, press and release the NEXT or PREVIOUS button, and the answering system announces a day, such as "Sunday, Monday" or "Sunday, Saturday."
3. After choosing a day, press and release the STOP/SET button to store the day. The answering system enters the Rings to Answer menu.
Thanks for using FixYa and do rate the solution as Fixya, if found helpful.
Thanks
Rylee
Apr 06, 2009 | GE Telephone
AT&T 1717 How to turn on Announcement Monitor.
You can choose whether to hear the
announcement when your system answers
a call, or have it silent (off) on your end
(your caller will still hear an
announcement).
1 Press and hold "Setup". After the Ring
Select setting is announced, continue
to press and release "Setup" until the
system announces “Monitor is on (or
off)”.
2 Press and release "ANNC/SKIP"or "Memo/Repeat"
until the system announces your
selection.
3 Press and release "Play/Stop" or "Setup"
to exit.
Jan 01, 2009 | AT&T 1717 Digital Answering Machine
I nees to setup Quintum A800 for termination can anyone help me
Command line for termination A800 (Quantum)
Config unit 1# online 1
Config sys# mindn 10
Config sys# maxdn 20
Config pstntg 1# pass 0
Config pstntg 1# cassig 6
Config pstntg 1# super 3
Config pstntg 1# lamp 1 country code (91)
Config pstntg 1# Answerdel 120
Config pstntg 1# lamp 1 9101 01
Config pstntg 1# dis 1 a (ALL - ports)
Config pstntg 1# ena 1 a (ALL – ports)
Config gkadmin allow 1# ip xxx.xxx.xxx.xxx (GW ip + switch-ip)
Config dsp# voice 81 (for g723) voice 68 for (G729)
Config# submit
Local information
Name of this zone Hello
Country selection Canada
Local country code country code (91)
International prefix country code (91)
Hop-off PBX Numbers
91 public
9101 01 public
This configuration for termenation
Nov 20, 2008 | Quintum Tenor A800 (501-0026-00)
I minute remainding voice message
This can only be done via DTMF signaling, not by a wav file.
Sep 17, 2007 | Quintum Tenor DX2048 (501012100) 2x10/100...
Help! Re-recording message
Following are instructions for the GE25881 phone which is similar to your 25880. Hopefully this will work for you. -Vish Answering System Set Up This section shows you how to set up your answering system to receive incoming calls. Before you begin the setup, you must turn on the answering system. ? Press the conference/ans on/off button to turn the answering system on and off. NOTE: The display shows ANSWERER OFF when the answering system is off. The default status is on. Voice Instructions If you need additional assistance, press and hold the memo button on the base and follow the voice instructions. 12 Answering System Operation Recording the Outgoing Announcement For best results when recording, you should be about nine inches from the microphone, and eliminate as much background noise as possible. 1. Make sure the answering system is ON. 2 . Press and hold the announce button on the base while you record the announcement. 3. Begin speaking after you hear the beep. 4. Release the button after you finish your announcement. If you choose not to record an outgoing announcement, the default announcement plays. To return to the default announcement after you have recorded your personal announcement, press the delete button on the base while playing the announcement, or press the announce button and release it when you hear the beep.
Jul 23, 2007 | GE 25880 Twin Phone
Quintum Tenor DX2048 (501012100) 2x10/100 Mbps Networking Switch Logo
185 people viewed this question
Top Quintum Computers & Internet Experts
Ekse
Alun Cox
Are you a Quintum Computer and Internet Expert? Answer questions, earn points and help others
