The problem is my Whirlpool 6.5 cu ft 5 cycle is blowing hot air but not hot enought to dry the clothes quickly like it use to. Also the timer on the top of the dryer stopped working and timing the dryer to turn off and the dryer will continue to run until I turn it off. It takes a full day to dry one load of laundry. Please let me know what I should do. Thanks.
First I would check to make sure your vent is not clogged or kinked. As far as the timer, the only fix would be to replace it. Unless of course you have the feature that detects the dryness and that would put you back at the venting problem. Good luck.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Whirlpool 6.5 Cu. Ft. 5-Cycle
Whirlpool 6.5 Cu. Ft. 5-Cycle Super Capacity Gas Dryer -...
clothes do not dry for a very long time. seems as though dryer is not as efficient as it used to be....
(More)(More)
clothes do not dry for a very long time. seems as though dryer is not as efficient as it used to be. the air flow is constricted or not as hot as it should be
Posted. Thank You!
Congrats on your 3 solution. You're helping others! Someone may even thank you with a Testimonial.
where can I find a wiring diagram for my Frigdaire FDG648GFS0 gas dryer? The dryer starts and turns,...
(More)(More)
where can I find a wiring diagram for my Frigdaire FDG648GFS0 gas dryer? The dryer starts and turns, I can hear the gas valve click; I think the ignitor is bad, need the troubleshooting book and wiring diagrams. Thanks,
Posted. Thank You!
My Whirlpool dryer is heating up, lint trap and ductwork leading out is clean. However, I can run...
(More)(More)
My Whirlpool dryer is heating up, lint trap and ductwork leading out is clean. However, I can run this dryer for 2 hours and not dry the smallest of loads. Excessive moisture is present when I open the dryer door. I live in a 3rd floor condo. Therefore it his a long way to travel. Didn't have a problem for 3 years. Now every 2 months we clean everything out. Now they say it is clean, but it is doing the same thing it would do if it were clogged with lint. Is it possible that the thermostat is going out? Maybe it isn't getting as hot as I think it is. I can put dry clothes in the dryer to fluff and there is plenty of heat. Please help with this matter.
Unhappy whith my Whirlpool:(
Posted. Thank You!
It just stopped starting. The start button does not kick the dryer on? Is there anything I can check...
(More)(More)
It just stopped starting. The start button does not kick the dryer on? Is there anything I can check into, if so ... how.
Posted. Thank You!
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
