Question about Canon Rebel XT / EOS 350D Digital Camera
Bulb when i follow the instuctions in the manual (turn to m mode The # after 30 is bulb the # 40 comes up not the word"bulb"
Bulb is a setting on the camera which allows you to keep the shutter open as long as you want, all you need to do is keep you finger depressed on the the trigger button.
Posted on Oct 03, 2007
6ya staff
SOURCE:
I am trying to program my key fob on a 2005 Pontiac Montana sV6. All the instructions state to turn the key to ACC which they claim is turning the key toward you.
my sv6 wouldnt go in learning mode by using the litlle programer they sell with then fob i did it with the snap on scanner and work fine
Nov 21, 2017 | Pontiac Cars & Trucks
[email protected] the security+ light feature on LiftMaster #1265......it is no longer working. Light can be turned on, and comes on when door operated, but will not come on when beam is broken....
Try these instructions in case they are different from what you have.
To have your lights come on automatically when you walk into an open garage, you must START with the lights ON. If you don't want that feature and you want to turn it off, you must START with the lights OFF.
To turn the feature on, turn the lights on manually with the wall switch, then press and hold the LIGHT button for about 10 seconds until the motor unit light bulbs flash. Now, if the light bulbs are on, manually turn them out and then walk out through the open door. The light bulbs should come on.
To disable this feature, start with the light bulbs OFF and everything else is the same.
Jul 13, 2011 | Sears Craftsman LiftMaster Chamberlain...
The unit is programmed to come on at 5:00 p.m. and go off at 11:30 p.m. It was wooking but now the lights won't come on.
Three things can cause lights not to come on:
1) Timer has gone bad.
Try resetting and reprogramming timer. Make sure you have correct mode.
I test timers. 4-6% arrive defective and most quit within a year or two.
Some go bad within a month.
If display does not show, then check battery.
Most timers have internal rechargeable battery that is not replaceable.
When rechargeable battery goes dead, timer is bad.
2) Light bulb burned out or lamp turned OFF.
3) Receptacle has no power. Plug lamp in directly and see if bulb comes on.
To see manual:
Check following link
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
Dec 21, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
The ladies disney citzen eco-drive requires a charge
Follow this link:
http://www.citizenwatch.com/CUK/English/settings.asp
Interactive settings are helpful as well.
Rate me, please.
Apr 06, 2009 | Citizen Eco-Drive JR3080-51L Wrist Watch
No picture
Our LCD television did that and we had to replace the picture bulb in front. It was about a $200 item. Good luck. Does the green light flash intermittently? If so, it's the main bulb that brings you a picture. When you get the bulb, get instuctions on how to get to it. Be careful pulling panels to get to it as they will break if you're not careful.
Dec 16, 2008 | Astar LTV-27BG 27 in. LCD Television
Shutter Speeds
Hi, You can get into "Bulb" mode only when you increase the exposure more than 20 or 30 secs.
Try increasing the exposure by turn the wheel (towards left extreme) in manual mode. You should the Bulb mode now.
hope it works ... cheers
Aug 24, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Canon Rebel XT / EOS 350D Digital Camera Logo
106 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
