Ricoh aficio sp c210 sf is printing with a black line on the right side of each page when used as a printer or copier.
  • 135 Answers
You are having a drum or fuser issue, to find problem you will need to attempt to make copy and as paper passes the drum you need to open door and remove paper,if line can be rubbed away then it is drum if it cant then the fuser is problem
Posted on Apr 19, 2009
Printer leaving horiz black lines every inch down the page. Happens w/ printing normally and w/ blank pages which leads me to believe that something inside is dirty but I have cleaned everything I can
Are you using a new toner cartridge? If not they may be the issue, refilled ones can cause this condition. I know this first hand from my wife's office printer.
Oct 13, 2016 | Ricoh AFICIO SP 3300D 30PPM LASERPR W/O...
Risoh aficio sp 3510 sf
my printer richo sf 3510 sir. my problem replace required soon print cartridge show on the display
Feb 19, 2013 | Ricoh Office Equipment & Supplies
How can I check the color counter page for Ricoh Aficio SP C210SF?
The instructions for getting the page count for the C210SF should be the same as for the C231SF:
- Press User Tools.
- Scroll down until you see Reports Print.
- Press OK.
- Scroll down to either Configuration Page (2 pages long, prints in black and white) or Maintenance Page (1 page long, prints in color).
- Press OK.
Both the configuration page and the maintenance page will show the page counts. For page count instructions on other models of copiers or printers, check out ConfigPages.Blogspot.com.
Aug 11, 2011 | Ricoh Aficio™ SP-C210SF Printer
Ricoh aficio sp-1100 sf toner chip reset problem
WE HAVE RICOH PRINTER SP 1100SF & REPLACED CARTRIDGE WITH NEW RECYCLED BLACK TONNER CARTRIDGE FROM POWER POINT, BUT UNABLE TO PRINT AS CHIP GIVEN IS NOT ACCEPTED BY PRINTER. TRIED 3 DIFFERENT CHIPS STILL PROBLEM PERSISTS. WHAT MAY BE THE RESEASON AND SOLUTION
Nov 30, 2010 | Ricoh Aficio SP-C210SF Printer
Blue dotted line of right side of paper
Sounds like the cyan photoconductor unit needs to be replaced. Usually what ever the color dot is that photoconductor has a pinhole in it and the only to get rid of it is to replace it.
Apr 06, 2010 | Ricoh Aficio SP C411DN Laser Printer
Ricoh Aficio SP C210 error message
Try loading letter size paper in tray1 .. Open the front door and the assembly attached to the front door is the transfer roller ASM. mybe you knocked it out of position ..There are green plastic clips that allow someone to the transfer roller unit so its easy to mess up good luck
Apr 20, 2009 | Ricoh Aficio SP C210 Laser Printer
Color bad on ricoh aficio sp c210 sf
Hi There,
print out a page from windows paint program of cyan, magenta, and yellow. see which colors are incorrect. that will help you get closer to the problem area.
the drum also may not be screwed in all the way. remove it, and try putting it back in again.
Dec 12, 2008 | Ricoh Aficio Colour 3006 Color Copier
sounds to me you are using the "wrong driver" double check the driver and the OS you are using.
I would also turn the printer off and clear all print jobs from the print que and restart. After loading the new driver do a test page from the driver.
Aug 15, 2008 | Ricoh Aficio SP-C210SF Printer
Ricoh Aficio CL 2000N printing problems
If the colors are good and solid with no fades, only black streaks, then black is the culprit. I suggest replacing the black cartridge.
Feb 20, 2008 | Ricoh Aficio CL2000N Laser Printer
jasbo
jasbo
