Can I fix this stuff without a service call?
I have two problems. First, I am looking to adjust the copies that are printed. They are aligned too far down on the page and cuts off the bottom of the page on copies. Also, The images I print, copy, and received faxed images print out with little black spots all over them. Is that the developer usually?
  • 524 Answers
Black spots can also be caused by drum...
developer normally will cause blur print due to developer uneven or dirty (dust)...
Posted on Apr 17, 2009
What would be causing our Toshiba e-studio 350 copy machine to mis-align margins when printing a document?
This involves 2 different sizes coming from 2 different cassette. 11x17 tray needs adjustment .
Sep 11, 2014 | Toshiba e-Studio 350 Copier
Colors don't line up correctly
This problem is referred to as color to color alignment. Most color laser systems have a rough adjustment by means of a screw somewhere and a fine adjustment that is done in diagnostic mode as part of a setup routine. Try the latter first by locating your manual and looking through the troubleshooting guide which should explain how to force the machine to do an automatic color alignment. Your manual should be available online from your manufacturer's web site if you can't locate it. If this doesn't work you will need to take it in for servicing unless you are handy with tools and can find a service guide for your model.
Nov 10, 2013 | Lanier Ld445c Ld435c Ld430c Ld425c Ld420c...
My Lexmark 4650 keeps telling me that my margins need adjusting, plus it is giving me blurred copies.
Check Page Preview before printing your file and see if the application you are using recognizes the entire page and does not cut-off the edges.
You can try to print Fit to Page or Borderless and see if that helps.
For your blurred copies, Please follow the steps below to fix your problem:
  1. From the printer operator panel, press the Setup button.
  2. Go to Maintenance.
  3. Select Align Cartridges. Your printer will then print a page to align your cartridges.
  4. After the test page is printed, try to print a document again to verify that the problem is fixed.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Oct 19, 2011 | Lexmark X4650 InkJet Printer
My printer window on the HP PSC 2175 continues to read: 'Press Enter to align cartridges' I have done this 5 or 6 times and the message will not go away. How do I fix this problem so it will print?
Perform the following steps to align the ink cartridges:
  1. Disconnect the power cord from the unit, wait five seconds, and then plug it back in. This will reinitialize the unit.
  2. Print another alignment test page. If the Press Enter to align message is not currently on the front panel display, complete the following steps to print an alignment page:
    1. Press Setup or Menu on the front panel (depending on the model).
    2. Press the right arrow button (>) until Maintenance or Tools is displayed, and then press Enter or OK (depending on the model).
    3. Press the right arrow button (>) until Align Print Cartridges is displayed, and then press Enter or OK (depending on the model).
  3. To determine if the automatic alignment is functioning correctly, look into the output tray as the alignment page is printing; a blue light should be visible periodically on the page as the cartridges move back and forth. If this light is not visible, the product will not be able to align the cartridges and will require service. Service the product.
  4. If the blue light is visible and the alignment pages are printing correctly, but the alignment pages still fails, there still may be a hardware problem with the unit.
    • If there are no other printing problems and you wish to continue, use the information in the Bypassing the ink cartridge alignment section below to bypass the alignment. The information from last successful alignment will be used.
    • If the message keeps reappearing or other print quality problems occur, service the product.
Models with a semi-automatic print cartridge alignment Some HP products have a semi-automatic alignment process. These models do not have an additional sensor and will print two pages for the alignment process instead of one. The alignment page must be placed on the scanner glass or into the automatic document feeder (HP Officejet V series) and scanned.
  1. Disconnect the power cord, wait five seconds, and then plug it in. This reinitializes the product and forces the scanner to calibrate again.
  2. Examine the scanner glass and white scan backing. Clean the scanner glass and scan backing if they are not clean. To clean the scanner glass and scan backing, use a soft cloth towel slightly dampened with clean water.
  3. With the product turned on, open the scanner cover and check the bulb assembly. If the scanner bulb is not lit, the product must be serviced.
  4. Verify that the alignment page is placed correctly on the scanner glass or in the ADF (if the product has one). Place the printed side down.
  5. 5. Make a copy of the alignment page. The unit will make a copy even if the alignment message is displayed. Compare the copy to the original. If vertical lines appear in the copy, check to see if the scanner assembly requires cleaning. If cleaning the scanner assembly does not correct the problem, service the product.
  6. 6. Use the information in the Bypassing the ink cartridge alignment section below to bypass the alignment. Operate the HP All-in-One to determine if there are other problems. The unit should be serviced if other error messages or problems occur or if alignment problems occur every time the ink cartridges are changed.
To bypass the ink cartridge alignment: Press and hold the Setup button, and then press Options (or Copy Options ).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 26, 2011 | HP PSC 2175 All-In-One InkJet Printer
How do I align my Cannon MX340 all in one since I change ink cartiridge now it prints on two sheets of paper instead of one. I looked in my booklet but I cant find a fix for this.
Your "set-up" is incorrectly configured. Try printing or copy without the computer. If it works fine, then you set-up is the problem - don't think it's the alignment.
Oct 24, 2010 | Canon PIXMA MX340 Wireless Office...
After deep cleaning the print heads, it will only print one page
This sounds like the print head alignment is not stabilized and may indicate you need a new print head ($$$). Try looking in the Service Manual.
A copy of the Canon i860 Service Manual is downloadable at:
http://rapidshare.com/files/179582794/Canon_i860__i865_SM_-_printer1.blogspot.com.rar
The password to open the compressed PDF file is: printer1.blogspot.com
Jan 24, 2009 | Canon i860 InkJet Photo Printer
Photosmart 6180 won't print black
Been ther and done all of the stuff Have pulled the ****** apart... wont go into detalis try copy black only sheet of text 12x20 times then run head clean I was getting white sheets output if no black run 25x3 times black only on copy then do head clean For me Voila! BLACK Inkypete
Jan 10, 2009 | HP Photosmart C6180 All-In-One InkJet...
Copier only copies 90% of sheet in 100% mode
you have to go to service mode to adjust it that's ,technician's job,better looking for a local service provider
Dec 09, 2008 | Minolta EP1083 CS/PRO Copier
Alignment problem
I want to start my office working with the HP F380 DeskJet....
Apr 30, 2008 | HP DeskJet F380 All-In-One Printer
135 people viewed this question
k24674
