Question about Asrock 845GV (P4I45GV) Motherboard
Cpu fan is AKASA AK-955 CPU SKT775 cpu fan compatible with my p4i65g motherboard
  • 326 Answers
No, the fan is for a socket 775 cpu, you have a socket 478 cpu so the bracket will be different
Posted on Apr 17, 2009
P4i65g driver mb p4i6sg
CPU fan could be bad or the fan in the power supply is bad. A bad CPU fan can damage the CPU if not repaired promptly. Good luck.
Aug 28, 2013 | Asrock P4i65GV Motherboard
No video from motherboard even with new video card
Dear sir,
if this board has AGP slot, try to use AGP card inspite of PCI display card .. second thing when u power up the board . short its crystal oscillator for 2 second during switching on ..by screw drivers..if if it will not provide display .
then open fan & reinstall CPU .. if cpu is OK ( only can be tested on other board ) ..then something is wrong with Northbridge ../ or power supply mosfet of board if fan is not running ..
Regards
raj
Jan 26, 2011 | Asrock P4i65G Motherboard
My CPU fan started to become unreliable and would not always start. This gave me an error tone when this happened. I therefore replaced the whole assemble with a akasa AK-955 unit from maplin. This worked...
i hate to say this but you may have had a bad fan sent to you or it is not connected into the actual cpu fan port. or the fan is giving false rpm readings to the bios even though the cpu is staying cool.....last thing.... make sure you used thermal paste to install the heatsink/fan ect... otherwise you may run a high risk of burning the cpu.
Dec 03, 2010 | Intel Gigabyte GA-8I915P Duo Pro 915P...
Asrock P4i65G motherboard/CPU
Hi Rlforeard, yes the BX80546PG3000E is compatible with the motherboard P4I65G.
http://www.alvio.com/product_view.aspx?product_ID=61048&source_ID=froogle
Here is the list from Asrock. CPU's supported for the Asrock P4I65G board. You will find you can go higher.
http://www.asrock.com/mb/cpu.asp?Model=P4I65G&s=478
Good Luck!
Mike
Jun 02, 2008 | Asrock Computers & Internet
If the CPU is dead the problems can be
  1. no power
  2. no fans etc or
  3. power, no beeps (errors)
If the Ram is not compatible it would be constant beeping.
With the board in, and power supply 20pin + 4pin Pent 4 power attached,(#2 and #7 of motherboard layout) remove power cord from power supply.
CLRCMOS0 allows you to clear the data in CMOS. The data in CMOS includes
system setup information such as system password, date, time, and system
setup parameters. To clear and reset the system parameters to default setup,
please turn off the computer and unplug the power cord from the power
supply. After waiting for 15 seconds, use a jumper cap to short 2 pins on
CLRCMOS0 for 5 seconds. Remove the jumper. Remove heatsink and fan from CPU. disconnect cpu and reseat it. Re-install heatsink and fan. Plug in the power cord. Try to boot up. If it still does not boot and (no power, no fans etc.) problem would then be cpu is fried.
Jun 02, 2008 | Computers & Internet
Asrock p4i65g motherboard
Your current motherboard is an mATX form factor. I recommend staying with that form factor for your new motherboard if staying with your current case. When upgrading to the new board you choose don't forget that you may need to upgrade the power supply unit also. You should upgrade to either a socket AM2+ board with dual core amd cpu or socket 775 board with Intel Duo Core2 cpu.
May 02, 2008 | Intel Motherboard
Powering up problem
there is heating problem
remove cpu fan and put on cpu heat sink compound and
refitting cpu fan
Feb 28, 2008 | Computers & Internet
Asrock 845GV (P4I45GV) Motherboard Logo
73 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
