Question about Ricoh Aficio Colour 3006 Color Copier
Ricoh CL 7000 down due to an SC-685
SC-685
Do you have the copier feature option installed?
It is most likely just a loose connection on the interface between the main printer unit and scanner section. Turn off main power (red button), and re-seat the connector.
Please let me know and rate solution :)
Posted on Apr 17, 2009
How to reset SC 302 code ?
sc302 is usually PCU or charge roller.
As you say you have recently replaced the Drum/PCU, is the drum turning correctly?
Check charge connectors and connectors on the back of the pcu. To reset that code, simply turn main power off and on again. If problem comes right back....the machine detects the cause still exists. May be an issue with the HVT.
Sep 01, 2014 | Ricoh RICMP201SPF AFICIO MP201SPF,...
Ricoh Afficio cl 7000 sc 552 code what is it?
Try the procedure below. Its a hardware error on the device
Press and hold online + escape, then power on.
Use up and down arrow keys to select SP2
Press Enter
Use up and down arror to locate SP5
Press Enter
Use up and down arrow keys to select 810
Press Enter
Confirm the selection
Power off and on.
The error code is now cleared.
Aug 18, 2008 | Ricoh Aficio CL7000 Laser Printer
Problem Ricoh CL 7200 error SC 542
fuser assy replace it and reset code or have tech come out and fix it
Jul 19, 2013 | Ricoh CL-7200 High Yield Toner Refill Kit...
Mp 7000
Please refer to the authorised service support as it might need technical support with spares.
click on : http://www.ricoh.co.uk/support/index.aspx
Nov 21, 2011 | Ricoh Aficio 450 Copier
Hi I need a service mode code for a ricoh cl 7100
Press and hold both arrow keys for 5 seconds, let go then press enter. This will enter service mode. You will need to search through the menu system for the particular option you want.
May 24, 2010 | Ricoh Aficio AP3800C Laser Printer
RIcoh CL 7000 having problem within the copier, it's locked and unable to use WHat should i do
Most likely if you have no error code displayed then one of the hard drives is bad.
Feb 07, 2010 | Ricoh Aficio 450 Copier
I KEEP GETTING AN ERROR ON MY RICOH CL 7000 THE ERROR READS SC 221-2
SC No. Item Definition Possible Cause Related
SCs Troubleshooting Procedure Type
SC 221 Synch.
detection signal
error 2
221-001: Y
221-002: M
221-003: C
221-004: K
Main scan length detection is
not properly completed ten
consecutive times.
The front (for C&M) or rear (for
K&Y) laser synchronizing
detector boards are used for
the main scan length
detection, which automatically
corrects the main-scan
magnification.
• Damaged or
disconnected cable
between front (C&M)
or rear (K&Y) laser
synchronizing
detector board and
the LD unit
• Incorrect installation
of front (C&M) or rear
(K&Y) synchronizing
detector board (the
beam does not target
the photo detector.)
• Defective front (C&M)
or rear (K&Y)
synchronizing
detector board
• Defective LD unit
After doing any of the following, print ten
jobs or more to see if the same SC code
is displayed:
1. Turn the main switch off and on.
2. Check or replace the cable
connecting front (for C&M) or rear (for
K&Y) synchronizing detector board
and the LD unit.
3. Check or reinstall the front (for C&M)
or rear (for K&Y) synchronizing
detector board.
4. Replace the front (for C&M) or rear
(for K&Y) synchronizing detector
board.
5. Replace the laser optics housing unit.
6. Replace the BCU.
If a synch. detector board cannot be
replaced, do the following as a
temporary measure:
• Disable main scan length detection
Sep 15, 2009 | Ricoh Aficio CL7000 Laser Printer
Dirty copies on Ricoh Aficio CL 7000 copier
Did you replace the fusing oil as well? toner will not fuse well and deteriorate your new fuser very quickly if you are out of oil
Feb 03, 2009 | Ricoh Aficio CL7000 Laser Printer
Installation driver for Ricoh Aficia CL7000 laser printer
go to www.ricoh.com, usa, downloads and then select your printer in the drop down windows, lastly choose your operating system. now just unzip the file and install
Sep 26, 2008 | Ricoh Aficio CL7000 Laser Printer
Ricoh CL 7000 error code SC 387
This Code relates to color gamma error in the Yellow development. Possible causes Low toner density in the Y toner,Toner supply Y mechanism problem( not supplying enough toner),Laser exposure problem, image transfer problem. My suggestion would be to ensure you have toner in the cartridge( but by this time it has depleted the developer), and you will need to replace the development unit and possibly the drum Unit. My best guess would be the development Unit.
Munybuny
Apr 24, 2008 | Ricoh Aficio Colour 3006 Color Copier
429 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
