Question about Kenmore 20172 Top Load Washer
Kenmore Elite Calpso washer
There is a DL code showing on the washer.
  • Anonymous Mar 26, 2008
    There is a ld display on the washer. Water will not drain.
    Turned it off. Press spin and seems to be working.
  • Mary Jo Schlecht
    Mary Jo Schlecht Nov 24, 2009
    I have the same washer. My pump works but leaks badly. I guess the seal is shot. They only seem to want to sell a replacement pump AND motor for about $100-150. The Whirlpool repalcement pump and motor seems to be part # 285990. I've called Sears and a few other appliance parts dealers - same answer. Just the pump part looks pretty simple and should be under $30.
I am having the same problem with my calypso model 110 top loading washer. i found that the drive to the pump was spinning on it and stripped out the teflon gear. i believe the motor to the pump is working but, the pump isn't spinning i don't think. thats why the water isn't coming out, and the cycle won't move on. i can't seem to find the 8527775 pump by itself. the geneic ones i found have a different fitting to the motor.
Posted on Mar 26, 2009
Your pump had gone bad part number 8527775
Posted on Oct 01, 2007
  • rhyn Oct 01, 2007
    your calypso pump had gone bad,If I were you here's the Part number for that Item #8527775
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ... > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machine are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
I have a Kenmore Elite washer. I keep getting a F 14 code and a DL F code. What do I Do?
I understand that 'F14' for Kenmore (Whirlpool) machines decodes as 'EEPROM failure' (control unit) and 'DL' is Door Lock- a problem with either the door solenoid/lock or the 'door closed' sensor.
Sorry but I fear both F14 and DL require a service engineer's attention ;-0(
Good luck,
John C
Mar 21, 2011 | Kenmore Elite 45986 Front Load Washer
Hello, I have a Kenmore Elite Oasis washer model
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!!!!
Jun 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Hello.. I don't have a lot of time.. to work on this.. but wondering what the dl error codes is on a kenmore elite oasis washer model 110.27086603 serial #CT4070587
First, see the Sears parts site for your washer:!retrieve.pd?modelNumber=110.27086603&pathTaken=partSearch
The DL code points to a Door Lock problem.
See the Whirlpool Service Manual for their Cabrio washer (basically the same as the Sears Oasis).$FILE/8178583.pdf
It has troubleshooting and testing procedures.
Apr 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite HE4 has fault code of dl and F?
F-DL code is for your washer and if the main control has not been replaced then that is what I would replace most of the time F-DL is also seen with a F-11 code later in the cycle, i am sure you hear the washer try to lock the door a few times and pop up F-DL. the main control part # is based off of the model#
Sep 25, 2009 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore Elite Washer model 48051. I am
i think the dl code is clogged water pump,tip it back and you can remove the water pump cover and check it-mike
Jul 17, 2009 | Kenmore Washing Machines
My screen in showing code "dl" and then "f", please help?
The "dl" code is "doorlock" indicating a problem with the door locking mechanism or switch
Apr 19, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore 20172 Top Load Washer Logo
562 people viewed this question
Sal De
 Brian Main
Brian Main
