Question about Konica Minolta Magicolor 2530 DL Laser Printer
Instructions for Fuser Unit Change - Konica 2530DL
I need to find some instructions to change the fuser unit on our KM 2530DL. The fuser was wrecked by avery laser labels that failed to pass through the fuser as gauranteed they would.
Any help would be much appreciated.
  • dunk1103 May 07, 2009
    I am still looking for help with this fuser. I wasn't able to get in contact with dhudson15 but if you can help me out I'd be a very happy chap. Or if dhudson15 could try again that would be great.
  • 118 Answers
Send me you email at dhudson at Gmail dot com, and I will reply with the manual attached. It is a very involved process, that, having done it, would not ever want to do again.
Posted on Apr 20, 2009
  • Dan Hudson May 07, 2009
    My fault, dhudson15 at gmail is my address... I am still willing to help and share my experience for the time I changed one...
Remove fuser
These model you replace the fusing unit you don't get small parts for the fuser for these small machines.
Sep 04, 2014 | Konica Minolta magicolor 2530DL
Paper jam at fuser
Buy a new fusing unit can't get small parts for the fusing un it for these models
My konica gives me an error code of cof 32
Need the change a developer.After 40000 copies the developer,OPC drum,Drum cleaning blade and the imaging unit fuser(SOME MODELS) need to change.Please the copier model for another instructions.
Jul 17, 2014 | Konica Minolta Office Equipment & Supplies
C300 Fuser unit reset
To reset fuser unit you need change the 60mA/250V fuse,located in the fuser unit contact house (a little green diode).
Dec 24, 2013 | Konica Minolta Bizhub C300 All-In-One...
0500H Fatal Error
Witam,
0500H Heating roller warm-up failure:
The thermistor /1 does not detect the specified temperature and the warm-up cycle is not completed even after the lapse of a given period of time after the cycle has been started.
Relevant electrical parts
Fuser unit
Printer control board (PRCB)
DC power supply (DCPU)
Solutions:
1 Check the fuser unit for correct installation (whether it is secured in position).
2 Check the connector between fuser unit - PRCB PJ9 for proper connection and correct as necessary.
3 Check the connector between fuser unit - DCPU CN2 for proper connection and correct as necessary.
4 Change fuser unit.
5 Change PRCB.
6 Change DCPU.
Mar 12, 2013 | Konica Minolta Magicolor 3730 Dn Color...
Kyocera KM-2050 Problem error C6400
Fuser unit Error code, you can try to reset, but if the code still there, you need to change the fuser unit.
This is the way to reset your fuser code;
On the panel press 1087 1087
this will take you to the service mode,(look into the screen)
now on the panel again press 163 and hit the start key.
Look in the screen, you will see execute, select execute by the arrow and hit the start key, the machine will turn off then on. or it will ask you to turn the main power off than on. this might fix your problem, if not! change the fuser.
Nov 19, 2011 | Kyocera Mita KM-5035 Printer
My kyocera km-2550 multifunctional copier has started showing a error message "call for service c6000" and a phone number in asterisks. kindly advice on what to do or if there any online help.
This is fuser unit error code, you can try to reset it might work, but if the erorr code came back then you need to change the fuser unit.
In order to reset this code: follow those steps
on the panel press 1087 1087
The screen will change to service mode
now look at the screen and you will see Excute.
Select Excute and press the Start key.
The Machine will rebot or it will asks you to turn it off and on.
After the machine load again, it should be good, if the Error came back!! Then change the Fuser Unit.
Oct 13, 2011 | Kyocera Mita KM-2550 All-In-One Laser...
The toner isn't adhereing to the paper, If i change the settings to card it sticks
The fuser unit is faulty or the power supply to the fuser unit is faulty. The fuser unit is not heating up to fuse the toner powder to the paper.
Try re-seating the fuser unit.
Mar 16, 2011 | Konica Minolta Office Equipment & Supplies
Papr jam in fuser unit C900
You can download (free) the Service Manual for the C900/C1900 here;
http://tinyurl.com/2dxyzrr It contains comprehensive dis-assembly, re-assembly and service instructions including parts lists and wiring diagrammes. The download is in six zipped parts. After downloading all of them unzip part 1 and it will rebuild the complete file as a pdf document.
This printer uses the same print engine as the Minolta QMS/Konica Minolta Magicolor 2300/2350 printers. KM versions of the manual are also available from the above site. Much of the content is virtually identical but the instructions are not quite as comprehensive or as detailed as the Epson version. KM MC2300/2350 users may want to download both versions.
Geo.
May 02, 2010 | Epson AcuLaser C900 Printer
Error F32
the error is COF32. You have to check the developing unit, to change the developer is needed and to run atdc auto adjust.
Apr 16, 2009 | Konica Minolta bizhub 180 All-In-One...
Konica Minolta Magicolor 2530 DL Laser Printer Logo
884 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
