Question about Elliott's Car Radio Ford-COSF-18808-E Car Speaker
Intermittant speaker failure
Hi, I have an '03 350Z with a factory Bose stereo. The speakers on the right hand side of the car, both front and rear (tested with fade) intermitantly come on and off, without any noticeable crackle. Initially I thought it would be a loose wire, however with front and rear having the same problem, I think it's unlikely..? It doesn't seem to be effected by travel/bumps, nor speed/revs. Any suggestions would be great, as it's driving me crazy! cheers, Matt
Thanks heaps for the interst pyro! Have discovered that I can isolate it even further to the cd player within the HU, as the speakers work at capacity with the radio on..? P.s. like the "what's up". reminds me of an old friend of mine from San Diego. Must be an American thing methinks??? Cheers, Matt (Australia).
Posted on Sep 21, 2007
  • 150 Answers
What's up Matt, I would suggest it's either the head unit has a small electronic component in it that;s going bad, or when the factory wired that car they placed a wire incorrectly and it has chaffed it's insulation off over a period of time. Good Luck L8R
Posted on Sep 17, 2007
SOURCE:
Where can i find a radio diagram for a 24 pin 05 cobalt with pioneer speaker system
Car Radio Battery Constant 12v+ Wire: Red/White .
Car Radio Ground Wire: Black/White
Car Stereo Antenna Trigger: Yellow
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: Factory amplifier is located behind the driver side of the dash (near the firewall).
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Dark Green
Right Front Speaker Positive Wire (+): Light Green/White
Right Front Speaker Negative Wire (-): Light Green
Left Rear Speaker Positive Wire (+): Brown/White
Left Rear Speaker Negative Wire (-): Brown
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Tan
Nov 03, 2016 | Pioneer Car Audio & Video
How do I integrate an aftermarket deck into the Bose system in my 2001 DeVille, factory radio plug in has been cut, and is long gone
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Negative Wire (-): Light Blue
The best way to do this would be to get a plug from the junk yard..colors should match up and them get the correct integration harnes.
Aug 22, 2016 | Cars & Trucks
Nissan Maxima 1997 Stereo not turning on at all!!
Here is a list of radio wiring harness wire color codes and what they do. I have given both with and W/O Bose.
Nissan Maxima Car Stereo Radio Wiring Diagram Radio Constant 12V+ Wire: Pink/Blue
Radio Ignition Switched 12V+ Wire: Blue/Black
Radio Ground Wire: Vehicle Chassis
Radio Illumination Wire: Red/Blue
Radio Dimmer Wire: Red/Orange
Radio Antenna Trigger Wire: Black/Red
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/White
Left Front Speaker Wire (-): Blue/Yellow
Right Front Speaker Wire (+): Brown
Right Front Speaker Wire (-): Brown/White
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Red
Left Rear Speaker Wire (-): Green
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Pink
1997 Nissan Maxima with Bose Stereo Wiring Diagram W/Bose
Car Radio Battery Constant 12v+ Wire: Pink/Blue
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amp Trigger Wire: Green/White
Car Stereo Amplifier Location: Each speaker has its own amplifier located at each speaker.
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Violet
Left Rear Speaker Positive Wire (+): Red
Left Rear Speaker Negative Wire (-): Green
Right Rear Speaker Positive Wire (+): Pink
Right Rear Speaker Negative Wire (-): Blue
Mar 27, 2017 | 1997 Nissan Maxima
Wiring diagram for bose 28060
Infiniti QX56 Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Yellow
Car Radio Accessory Switched 12v+ Wire: Purple
Car Stereo Antenna Trigger Wire: Green/White
Car Stereo Amplifier Location: To the right of the steering column behind the BCM.
Left Front Speaker Positive Wire (+): Blue/White
Left Front Speaker Negative Wire (-): Blue/Red
Right Front Speaker Positive Wire (+): White/Black
Right Front Speaker Negative Wire (-): Blue/Black
Left Rear Speaker Positive Wire (+): Gray
Left Rear Speaker Negative Wire (-): Black/Yellow
Right Rear Speaker Positive Wire (+): Orange/Blue
Right Rear Speaker Negative Wire (-): Red/Blue
Jul 08, 2012 | Cars & Trucks
2005 nissan pathfinder xe 8 speaker wiring COLOR
Check this for...
2005 Nissan Pathfinder with Bose Audio Wiring Diagram
Car Radio Accessory Switched 12v+ Wire: Green/Black
Car Stereo Dimmer Wire: Gray
Car Stereo Amplifier Location: Under the Driver Seat
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): Black
Right Front Speaker Positive Wire (+): Yellow
Right Front Speaker Negative Wire (-): Brown
Left Rear Speaker Negative Wire (-): Black/Red
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Black/White
2005 Nissan Pathfinder Car Radio Wiring Diagram
Left Front Speaker Positive Wire (+): Brown
Right Front Speaker Negative Wire (-): Red
Left Rear Speaker Positive Wire (+): Green
Right Rear Speaker Positive Wire (+): Gray
Right Rear Speaker Negative Wire (-): Orange
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Dec 20, 2011 | 2005 Nissan Pathfinder
Plugged in a Kenwood stereo in a 2000 tahoe. Have all power but no sound. Radio is not defective. When plugging the same stereo into a 99 express van, it works just fine. My question... What is the wiring...
Hi, your factory wire colors are below. Please let me know if you have more questions.
2000 Chevrolet Tahoe Car Radio Wiring Schematic
Car Stereo Antenna Trigger Wire: N/A
Car Audio Front Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Car Audio Rear Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Doors
Feb 10, 2011 | 2000 Chevrolet Tahoe
I got a ford aspire and a pioneer radio how do i hook it up
It is best to buy a connector pigtail for Ford, but you can wire directly using the below color code for the factory wiring. use the color code from the pioneer to match to the factory wires. If you have more questions, please reply.
1994 Ford Aspire Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/Yellow
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Amp Trigger Wire: Light N/A
Car Audio Front Speakers Size: 5 1/4?
Left Front Speaker Positive Wire (+): Brown/Black
Left Front Speaker Negative Wire (-): Green/Red
Right Front Speaker Positive Wire (+): Green/Orange
Right Front Speaker Negative Wire (-): Blue/Orange
Car Audio Rear Speakers Size: 5 1/4?
Car Audio Rear Speakers Location: Side Shelves
Left Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Brown/Red
Sep 29, 2010 | 1994 Ford Aspire
Factory stereo wiring
Right here!
1986 Ford Ranger Car Radio Wiring Chart
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Illumination Wire: Blue/Red
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 5′ x 7′
Car Audio Rear Speakers Location: Rear Corners
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Mar 04, 2010 | 1986 Ford Ranger 2WD
Color codes wiring for delco bose radio replacement n a1992 installing a aftermarket brand thx.
1992 Cadillac Eldorado Car Radio Wiring Schematic
Car Audio Front Speakers Size: 5 1/4′
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Oct 07, 2009 | 1992 Cadillac Eldorado
Need to know factory wiring colors to hook up aftermarket stereo
1990 Mazda 626 Car Stereo Wiring Diagram
Car Radio Accessory Switched 12v+ Wire: Blue/White
Car Radio Ground Wire: N/A
Left Front Speaker Negative Wire (-): Blue/White
Right Front Speaker Positive Wire (+): Blue/Red
Right Front Speaker Negative Wire (-): Blue/Yellow
Car Audio Rear Speakers Size: 6 1/2′
Left Rear Speaker Positive Wire (+): Blue/Red
Left Rear Speaker Negative Wire (-): Blue/Green
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Green
Aug 03, 2008 | 1990 Mazda 626
Car Audio & Video Logo
150 people viewed this question
Top Elliott's Car Radio Car Audio & Video Experts
xxxxxx xxx
Vitally Alcher
Anthony Carman
Are you an Elliott's Car Radio Car Audio and Video Expert? Answer questions, earn points and help others
