Question about GE Profile Harmony DPGT750EC Electric Dryer
Shutting off every 20 minutes
We've had our dryer for not even 2 years. Suddenly is is shutting off automatically when drying, every 20 minutes. Then it takes 5 minutes before it will allow me to restart it. Then it will dry for 20 minutes and shut off again.
  • ericalacycon Apr 17, 2009
    Thanks. What do I need to do to fix it?
  • Jerry May 11, 2010
    Did you ever fix the problem with your dryer?
  • 77 Answers
Your thremal fuse is getting hot. OR There are overloads attached to the element housing and one of them is getting hot and automatically resetting itself once it is cooled.
Posted on Apr 17, 2009
My Maytag Bravos dryer is shutting off after running 10-20 minutes. Will not restart for an hour. Feels very warm
Have you considered calling a repairman .. sounds like you have a thermal overload malfunction .
Mar 16, 2016 | Maytag Dryers
Dryer keeps shutting off while drying. Even if holding the push to start knob it will shut down. Is this a sensor problem or a 8 year old dryer problem
Hello;
My name is peter. I am a retired field service appliance technician.
You did not provide a model number which is on a metal tag on the face of the dryer after you open the door, so I can only be general.
A dryer should last your 15-20 years or more. You are probably plugged up with lint and have poor air flow witch will shut you down, or you may have a bad high temperature thermal switch.
Jun 04, 2015 | Dryers
My electric dryer shuts off after about 20 minutes of drying
ok sounds like you are using dryer sheets,,,dryer sheets coat the automatic dry sensors and fool the unit into thinking the clothing is dry,,,,replace the sensor or try to clean it if possable with a green scrubbie,,,,also try the time cycle it dose not use the sensor.......www.myabcspace.com/washerwizzards
May 17, 2010 | Dryers
My dryer will automaticall start the auto dry
appears that timer is not timing out or shutting off at end of cycle.correct ,the timer itself appears to be the problem.
Oct 16, 2009 | Dryers
My dryer is four years old and will dry moderately well for 20 minutes or so, then won't dry an longer.
Is your motor running? If it is I would start at thermostats They may not be cycling right.Motor may also be heating up than shutting off If so replace motor.
Apr 22, 2009 | Dryers
Maytag LDG 712 shuts off before clothes are dry.
First, The most common part would be the over limit safety, it will be mounted to the element housing. Second, there is a thermal fuse usually a small disk with a little fuse inside. You can find these (with your model no.) at www.Repairclinic.com .Good luck.
Apr 20, 2009 | Whirlpool LER5636P Electric Dryer
Dryer cuts off before clothes are dry.
Might be the thermal protector in the motor that is shutting down the dryer, if motor overheats this is what will happen. Make sure there is no lint build up around the motor, if not the motor is bad. does the dryer start right away after shutting off or do you have to wait? If you have to wait the motor is bad.
Jan 13, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Dryer 90 Series shutting down. overheat?
Your motor is very likely overheating and needs replacement. A simple test is the motor will be so hot you cannot even touch it. Hope this helps!
Jan 05, 2009 | Kenmore 62602 Electric Dryer
GE Profile Harmony DPGT750EC Electric Dryer Logo
373 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
