Question about Bose Lifestyle 48 System
Bose lifestyle 48 says format unsupported for audio cds
After loading about 50 cds music center says format unsupportedMusic CDs recently burned produce statement on my Bose 3-2-1 that format is unsupported.  Apparently the same problem affects my IDVD burns for slideshows with music background.  Frustration is getting control of my fun with new Mac.
These CDs and DVDs all play perfectly in the test mode prior to burning.   Please advise correction to problem.
  • 10,515 Answers
Hi Johnxxlt,
According to Bose, the message that you have is due to dust in the system ....
They have offered 3 ways :-
Try cleaning the CD or DVD, as follows:
  • Use a soft, dry, lint-free cloth to remove stains or fingerprints from the disc surface
  • Wipe in straight movements from the center of the disc to the outside
  • Do not use any chemical cleaning products. They can damage the disc.
If the above will not fix the problem, you need to call them to repair the system.
I know its frustrating, However, we cannot play more with Bose as it might void the warranty if any.
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied.
Posted on Apr 17, 2009
Bose lifestyle 48 power went now not switching on..
Bose Lifestyle Problem - ecoustics.com
www.ecoustics.com > ... > Home Theater in a Box Forum
May 27, 2006 - My Bose lifestyle 38 will not switch-off completely and the "Saving your music ... On the phone they said power down and check cables and ... Here we goagain with more Lifestyle 38 problems . We are now unable to watch DVDs or listen to CDs without ... Recently bought a TV and Lifestyle 48 system. Archive through April 10, 2009 - How to DIY Repair a Bose ...
Jan 19, 2009
Archive through January 06, 2008 - How to DIY Repair a Bose ...
Dec 26, 2006
How to open the bose lifestyle 25 receiver
Aug 14, 2005
Archive through December 25, 2006 - How to DIY Repair a Bose ...
Mar 7, 2005
More results from www.ecoustics.com
Oct 24, 2015 | Bose Audio Players & Recorders
My Bose Lifestyle 28 is having trouble playing CDs everytime I put a cd it says format unsupported. How do I fix this?
Most likely you have a problem with your CD drive in the Lifestyle system. I suggest to contact Bose, to ask for a repair.
Feb 11, 2015 | Bose Lifestyle 28 System
Burning CDs from MP3 downloads
Try Nero Buring Rom. Select audio cd and burn the music.
If you need further assistance please post.
Mar 15, 2010 | Computers & Internet
Unsupported format message for normal CDs
Have you tried completely powering down the system, removing the power cord from the wall socket? If not, please try that. Wait two minutes. Then plug it in and power up the system. If this does not clear the problem, contact Bose, to get the latest firmware disk. The firmware disk will reprogram your Lifestyle sound system. Then, everything should work properly.
Jan 17, 2010 | Bose Lifestyle 48 System
My bose was playing stored music and then for no reason it has stopped. can play cds ok
My bose stereo system plays a cd for a few minutes then stops, what is this, and it says failed code, call Bose. How do I fix this.
Aug 01, 2009 | Bose Lifestyle 48 System
Bose lifestyle fault code 802 hi there- i have a bose lifestyle 48 and on display it reads format unsupported when i try to listen to cd's gut not on dvd's - in addition i am unable to store music into the...
Unfortunately, an 802 error is bad. That means hard drive (HDD) failure. This can happen to any hard disc drive, and there's no way to predict it and no way to fix it from home.
If you even try to troubleshoot it (reset etc), you could loose more data (music you've already stored to the system). If you try to access 'stored' music- the error will continue. Also, every time you turn the system off, it checks your HDD, and will probably cause the 802 or 801 errors to display again.
The "Format Unsupported" message may be related, but usually temporary. The 802 (and also 801) errors mean irreversible HDD damage so it doesn't matter.
Call Bose tech support immediately.. They can repair it for $165 and give a new 1 year warranty. And if it's already under warranty they will repair for free. In either case they will replace your HDD with a new one, and transfer any salvaged music files from your existing drive to the new drive.
May 31, 2009 | Bose Lifestyle 48 System
Everytime I want to play an audio cd, it says format unsupported. This is happening very often. And I have also cleaned the cds,but still there is no difference. What is the solution?
Apr 08, 2009 | Bose Lifestyle 48 System
Storing music in BOSE 38 system
The Bose uMusic system is a very powerful music management tool. The uMusic storage process involves pulling information from your CD (approximately 3-5 minutes per CD) then storing this information into a buffer area for processing. The buffer area will hold approximately 10 CDs worth of data. After the buffer is full, it must stop taking new data and process the data already in the buffer. The processing time is about 30 minutes per CD.
This means 5 - 6 hous of processing per 10 CDs. So be patient. This is not unusual. Other "media servers" such at Escient and Audio Request take 24 - 48 hours to process a full buffer. There is a lot of data processing going on during this time period and the result is amazing music management once completed.
I recommend clients load 10 CDs in the morning and let it process till after lunch. Then another 10 CDs and let it process until after dinner. Then another 10 CDs and let it process overnight. This routine completes 30 CDs per day.
If you have 100 to 400 CDs an automated services is available from HouseSys.com. This is the only automated service available for this system.
Jan 20, 2008 | Bose Lifestyle 38 System
Not an Audio CD/Format Unsupported
Clean the CD and try again. Also, if DVD displays "not supported", call Bose and ask to recieve an update disc. These updates are released every 6 months. Document your remote control settings before loading the update as they may be erased by the update and will require re-entering settings after the update.
Dec 24, 2007 | Bose Lifestyle 38 System
Bose Lifestyle 48 System Logo
719 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
