Home | Sharp | FO-DC525 Laser Fax | Sharp FO-DC525 FAX Key...
Sharp FO-DC525 Laser Fax
Problem for Sharp FO-DC525 Laser Fax
Sharp FO-DC525 FAX Key number
By rmcneil on Apr 17, 2009
I need the product key to enable the scanner expansion kit. I have the instruction sheet for once I have the number.
Thanks,
Ron
Solution #1
posted on May 25, 2009
Not Rated)
rburlsull73
Rank: Wiz
Rating: 92%, 20 votes
Your product key should be on the front cover of your NIC owners manual not your fax manual. If you have lost or did not receive a NIC owners manual you will have to call SHARP and give them your NIC serial number S/N. You will receive your product key within 3 business days. Try calling this number they MIGHT be able to help you. 1-800-847-0281. Before you call you need to printout a NIC settings list which contains your NIC serial number. Press menu 2 down arrow(which is below your green start key) to network settings, press start, then down arrow to network setting list, press start. print either list. If the instructions are wrong I'm sure SHARP should be able to help you out.
Was this helpful?
Yes
No
Popular Solutions for Sharp FO-DC525 Laser Fax
Questions and Unsolved Problems for Sharp FO-DC525 Laser Fax
Do you recommend Sharp FO-DC525 Laser Fax?
Answer
Answer
my brothers 1960c color fax will not register a cartridge. I have reinstalled 100 times and it says... (More)
Answer
The faxes arent printing. It isnt the paper or the ribbon. Any suggestions please?
Answer
i have a ux-185 fax i can make copy i can sain a fax but i can not rev a fax
Answer
I have a brother fax machine 565 I need to change the setting form manual to fax/telephone
Answer
Hi.. My workcentre Pro 665 is saying ''Check Line-1'' on the Free memory line in standby mode.... I... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp FO-DC525 Laser Fax:
Top Fax Machine Experts
Rank: Guru Guru
Solutions: 1503
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Fax Machine Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
