Question about Sybase InfoMaker 9.0 for PC
Details of a sub-report is truncated when it expands beyond one page in length
We have a problem with Sybase Infomaker reports, where the details of a sub-report is truncated when it expands beyond one page in length.. Any help in this regard would be highly appreciated. Thanking in anticipation! Munshi Verma.
2 Suggested Answers
SOURCE: ERROR WHILE CONNECTING DATABASE
Hi Ravindra,
send the error log details.
Posted on Jan 19, 2009
Are you looking for Antibody **** Conjugates Research Reports.
Majorly, antibody drugs are used to treat patients suffering from cancer. Antibody mainly destroys cancer cells and does not allow healthy cell to get affected. That is why, these drugs are prescribed by almost every oncology department. Especially if there is any surgical case, then these drugs create miracles.
The increasing demand of these drugs has affected the market positively and expanded the market size, claimed RNCOS in its Antibody **** Conjugates Research Reports.
Owners planning to expand their business in Bi-specific antibodies can use our Antibody **** Conjugate Market Reports, for an effective idea about the whole market. For details about any specific part, Antibody **** Conjugates Customized Research Reports are ideal for you. Our reports have always influenced business expansion.
https://goo.gl/xX2TuR
Apr 04, 2018 | Health & Beauty
How do I set my canon image class d1350 to print a tx received report after a fax has been sent?
The imageClass D1350 should have a report button above the 3 in the number pad. This is to the left of the Energy Saver button. If you don't have that button, please check the model number. Once this button is pressed, you should see the header Report Settings. Select TX Report and set this option to ON.
This is shown in the manual for the D1350 which is available on Canon's support page: https://www.usa.canon.com/internet/portal/us/home/support/details/printers/black-and-white-laser/d1350 . Click on the Manuals tab. The direct link to the Basic Operation Guide is http://gdlp01.c-wss.com/gds/0/0300007490/02/D1370_1350_1320_BASIC_en-us_R_1.pdf . See page 10-7 (page 169 of the PDF) for accessing the Reports setting menu. The buttons on the D1350 are shown on page 1-4 (page 28 of the PDF).
I hope this helps.
Mar 21, 2017 | Canon Office Equipment & Supplies
Why does Xerox 7335 truncates output from Oracle PDF?
It may not be the printer and I did some research on Oracle and this seems to be a common issue.
I pulled this information off an Oracle knowledgebase it may not resolve your issue and there is more info on the following site if you want to investigate further:
http://docs.oracle.com/cd/E23943_01/bi.1111/b32121/pbr_uxprt009.htm#RSPUB75727
NOTE:
If you're printing to the Xerox MFD with a PS (postscript printer driver) you could try installing and printing using the Xerox PCL driver for your computers operating system. If you printing reports from a mainframe this may be an issue at the mainframe level in which case I would engage your companies IT department for assistance.
Any one of a number of possible causes may account for the truncation of fields.
  • Check the field and determine if it is allowed to expand.
    1. In Oracle Reports Builder, double-click the field in the Paper Design or Paper Layout view to display the Property Inspector.
    2. Find the Horizontal Elasticity property.
    3. If it is set to Fixed, you should change it to Variable or Expand.
    4. Run the report to the printer.
    5. If it still truncates, it could be that the field requires multiple lines.
    6. Return to the Property Inspector for the field and check its Vertical Elasticity.
    7. If it is set to Fixed, you should change it to Variable or Expand.
    8. Run the report to the printer again.
  • If the right most fields on the page are always the ones truncating, it could be an issue with the printable area of the printer. If you are using a PCL printer, then you will have to estimate the size of the printable area and resize your margins accordingly:
    1. Open the report in Oracle Reports Builder.
    2. Go to the Paper Layout view.
    3. Click the Margin tool on the top tool bar. A thick black line appears indicating where the body of your report ends and the margin begins.
    4. Click and drag the black line to the left approximately 0.5 inches.
    5. Save and run the report to the printer again.
    6. If necessary, repeat steps 4 and 5 to determine approximately where the printable area boundary is located and then ensure that your report body fits within that area.
  • If you are using a PostScript printer, you can get the printable area boundary to appear in the Paper Layout view as follows:
    2. Choose File > Page Setup.
    3. Verify that the margins are small and that the orientation is correct.
    4. Click OK. The Paper Layout view should now be able to read the boundary.
    5. Go to the Paper Layout view.
    6. Click the Margin tool on the top tool bar. A thick black line appears indicating where the body of your report ends and the margin begins. A black hashed line also appears indicating the boundary of the printable area.
    7. Ensure that the thick black line is inside of the black hashed line. If it is not, click and drag the black line inside the printable area.
    8. Click the Margin tool to leave margin mode.
    9. If necessary, reposition your fields to fit within the new body boundaries.
    10. Save and run the report to the printer.
  • For PCL, if it is still truncating, try using a fixed space font instead of a proportional font. Sometimes PCL printers have problems interpreting proportional space fonts and it leads to truncation. You should try using a fixed space font, such as Courier, and possibly font aliasing.
    Note:
    Default layouts are built against a generic printer. Each printer has its own printable area. As a result, you may have to reset the report to fit the printer. Ideally, if you know the various printers you will be using, you can design the report from the start to fit the printer with the smallest printable area.
Mar 10, 2015 | Xerox Office Equipment & Supplies
Remove problems on fixya
There is no way to remove a problem. You could report it by clicking the report flag on the problem page. Just enter some reason why you are reporting and the page will be reviewed by the Fixya Support Team.
Additionally, you can visit the contact page and send a message to the Support Team directly. Just be sure to include the URL of the page and any additional details. http://www.fixya.com/contact
Hope that helps!
Aug 05, 2012 | FixYa Computers & Internet
How do I withdraw a question from FixYa?
You can report the problem by clicking the report abuse flag at the top right of the problem page. Just make sure you enter details on why the problem should be removed. After reporting the problem, your request will be reviewed by the Fixya Support Team.
Hope that helps!
Mar 26, 2012 | FixYa Computers & Internet
How can i generate a confirmation page from the HP CM3530fs
Information menu
Menu item: Fax Reports
Sub-menu item: Fax Call Report
Sub-menu item: When to Print Report Never auto print
Print after any fax job
Print after fax send jobs
If this answer solves your problem, please be sure to leave a positive feedback please
Feb 18, 2011 | Office Equipment & Supplies
How can I print a fax confirmation on a specific outgoing fax
Checking a report for the transmission result (?TX Report? function) A report containing the transmission results can be printed. The machine can be set to either print or not print the transmission report or to print it according to the machine setting or only when a transmission fails. To print the transmission report 1 Press the [Fax/Scan] key to display the Fax mode screen. 2 Touch [FAX Menu]. 3 Touch [TX Report] on the Set 1 tab. 4 Select how to output the report, and then touch [Enter]. ? Default: The transmission report is printed according to the previously specified method. For details, refer to ?Specifying report output settings (Report Settings)? on page 10-48. ? ON: The transmission report is printed with each transmission. ? If TX Fails: The transmission report is printed only if the fax could not be sent. ? OFF: The transmission report is not printed, regardless of the transmission result.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 10, 2009 | Minolta bizhub 200 Copier
How do i check the how many pages were printed out
dear friend
just press menu
then you will find reports press ok
then you will find config report or something like that
press ok
you will get the print
thanks
Apr 10, 2009 | HP LaserJet 3055 All-In-One Printer
Sybase InfoMaker 9.0 for PC Logo
48 people viewed this question
Top Sybase Computers & Internet Experts
David Payne
David Payne
Are you a Sybase Computer and Internet Expert? Answer questions, earn points and help others
