Question about Maytag MMV5207A Microwave Oven
Maytag Microwave Power Outage - Model MMV5000BAB
Ok...first. My microwave is a Maytag, but not the model number above. It is MMV5000BAB. I could not find a category for that in your options. It is 1,600 Watts and 14.6 Amps. The other night one of my kids went to use it and thought she had pressed the timer function...to time something else she was cooking in the kitchen. Instead...she pressed "cook." Well, 40 minutes later after "cooking" with "nothing" inside it, it shutdown and hasn't worked since. I looked downstairs and it didn't blow the breaker or anything. I checked the plug and that looks fine. Is there some type of fuse in the unit I should be checking and if so, do you know where that might be? The unit is mounted above our gas stove and I only have a manual, which doesn't tell me much of anything. When we bought our house the microwave was here. It has a fan/vent and again is mounted above the stove. Before I just blindly dig into, I thought you guys might have a suggestion. Since there's no schematic in the operational book, I'm not sure where to turn. Also...it shows how to replace a bulb, replace the fan filter, but nothing about a fuse or even where it is. Please let me know your thoughts when you get a chance. I would very much appreciate it and by the way "great web site too!" Thanks. Brian
  • Anonymous Jan 17, 2008
    I have a Maytag MMV5207AAQ over the stove microwave that was
    installed in my new home in 2004. Went to use it and no power. Checked
    the outlet it has power. Need to know what steps I can take to check
    further before calling for technical assistance
  • Anonymous Dec 29, 2008
    My wife did the same thing (she left it on with nothing in it). I would think if the magnetron was bad, though, you should at least get basic keypad function. Am I right anyone?
  • Maytag Master
  • 9,174 Answers
It's almost certain that your magnetron has failed and/or thermostat which is mounted on it. Fist, unplug the oven from the pwer. Then open the door and remove the stirrer cover in the ceiling of the oven. Look for any dark brown burns, charred spots, or "rusty" looking areas. This would indicate that the waveguide has burned, which means the microwave needs to be disposed of. If it passes that test, I'd say the magnetron and/or thermostat area bad. You can find helpful exploded view diagrams and the wiring diagram and order parts by entering your model number here: http://tinyurl.com/gv383 We have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Sep 22, 2007
2 Suggested Answers
SOURCE:
MicrowaveSvc
  • 9174 Answers
SOURCE: Maytag Microwave Power Outage - Model MMV5000BAB
Found this under GE instead of Maytag, but can answer for you here.
It may be the internal fuse, but more likely it is the thermostat on the magnetron.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Nov 22, 2007
How do you access the fuse in a Maytag Model#MMV5000BAB
The fuse is inside. You have to remove the outer cabinet to get to it but be aware that dangerous, possibly fatal, voltages lurk inside, even with power disconnected.
Oct 23, 2016 | Maytag Microwave Ovens
Model NE-9970. After a storm-caused power outage, why does the microwave have no power to the control board?
Usually the microwave is plugged into a ground fault protected outlet. Push the buttons on the receptical and power should come on. The ground fault may be above your counter top and protects the plug your microwave is pluffed into.
Nov 18, 2015 | Microwave Ovens
My amana model number amv1150vas is not working after a power outage
Unplug for 60 seconds to see if it will reset, if no! the fuse in the microwave has opened/ or if the model is the new type, it is the keypad control board or smart board.
Apr 05, 2012 | Amana Microwave Ovens
We recently had a power outage & my Maytag Microwave model #CME90108BAE is the only appliance that will not turn on. Is there a fuse with this model?
the fuse is usually mounted inside the unit on the same side as the control panel near the back end where the power cord is.......the cover must be removed to get access to it.
Jun 25, 2010 | Maytag 2.0 Cu. Ft. Over-the-Range...
I have a maytag microwave and the handle is broken, the model number is MMV5207BAW, I have searched for hours on the internet and cannot find a replacement handle, it is the white color microwave. Please...
You need too go too www.maytag.com and look for the microwaves, and look for a link for parts, if not you can call the maytag company and order one by giveing your model number.............
May 03, 2009 | Maytag MMC5000 Microwave Oven
Maytag Microwave
Mine is a model UMC5200AAW. Same problem as above, no power. Is there a reste button?
Nubi541
Oct 07, 2008 | Maytag MMV5207A Microwave Oven
Microwave on the blink after power outage in the neighborhood
There may be a fuse either inside the bottom cover or the back cover.
May 30, 2008 | Hotpoint Microwave Ovens
Maytag microwave removal
If you're talking about an over the range model, it's recommended that two people do it so they can either work together or have one be a spotter.
I'd need the model number to get the weight, but the critical part is when it's up in the air, well above your center of gravity.
You may be able to find the installation instructions on their site at http://maytag.com/support/manuals_literature.jsp
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 31, 2008 | Maytag MMV5165 Microwave Oven
Not working model # jvm1339bw 002
Check the main internal fuse. Unplug it, unscrew and take off the cover, the fuse should be easily found in the back by the power cord. It looks like a regular fuse but is white instead of clear glass because microwave fuses are special. You'll have to measure it with a meter as a result and be sure to replace it with the same kind. (try finding them at radio shack) Hopefully there isn't something more serious also.
Hope ya fix it!
Jan 30, 2008 | GE JVM1340AW/BW/WW Microwave Oven
Nov 21, 2007 | GE JVM1190SY/WY/AY/BY Microwave Oven
Maytag MMV5207A Microwave Oven Logo
689 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
